RG-S6160-28VS8CQ-X Switches - 1
RG-S6160-28VS8CQ-X Switches - 2
RG-S6160-28VS8CQ-X Switches - 3
RG-S6160-28VS8CQ-X Switches - 4
RG-S6160-28VS8CQ-X Switches - 5
RG-S6160-28VS8CQ-X Switches - 6
RG-S6160-28VS8CQ-X Series Next-Generation 28-Port 10GE All-Optical Layer 3 Core/Aggregation Switch with 100 Gbps Uplinks
Designed for the aggregation layer of large-sized networks, core layer of small and medium-sized networks, and data center server access, this switch delivers high performance, comprehensive end-to-end quality of service (QoS), and flexible security configurations to fully meet the needs of high-speed, secure, and intelligent enterprise networks.
  • Rich port options, 24 x 1GE/2.5GE/10GE/25GE SFP28 ports, 4 x 25GE SFP28 ports, and 8 x 40GE/100GE QSFP28 ports
  • Virtual Switch Unit (VSU) for flexible networking and high performance
  • Multiple hardware-level protections for continuous operation and stable connectivity
  • Layer 3 routing capabilities for diverse services and efficient and reliable transmission
  • Various network security policies and real-time monitoring, delivering enhanced network robustness
  • Paired with an SDN controller for simplified and efficient O&M
Layer 3 10GE All-Optical Core/Aggregation Switch
RG-S6160-28VS8CQ-X
Recommended for the aggregation layer of large-sized networks and core layer of small and medium-sized networks, the RG-S6160-28VS8CQ-X supports 28 x 25GE service ports (enabled via license) and 8 x 100GE uplink ports, delivering flexible access capabilities to meet high-performance network requirements and enable a smooth migration to 10GE campus networks.
VSU for Flexible Networking and High Performance
Fault Recovery in Milliseconds
When the aggregate link between the VSU and peripheral devices fails, traffic can switch over in milliseconds, ensuring uninterrupted network services.
Multiple Hardware-Level Protections for Continuous Operation
Hot-Swappable Power Modules + Smart Fan Modules
Hardware-Level Dual Boot
Optical Port Fault Isolation
Power modules can be replaced without interrupting network services, while intelligent fan speed adjustment ensures efficient heat dissipation for enhanced system protection.
Layer 3 Routing Capabilities for Diverse Services and Efficient and Reliable Transmission
Rich Multicast Protocols
Hardware-based dual-stack forwarding supports high-speed traffic exchange and facilitates a smooth transition from IPv4 to IPv6 in campus networks, greatly improving address capacity and network security.
Various Network Security Policies and Real-Time Monitoring, Delivering Enhanced Network Robustness
CPU Protection Policy (CPP)
Large volumes of disordered traffic are processed by CPP before reaching the CPU, preventing direct attacks on the CPU, ensuring stability under high-load operation, and effectively improving device security.
RG-S6160-28VS8CQ-X
RG-S6160-48VS8CQ-X
RG-S6160-48XMG4VS2CQ-UP-X
24 x 1G/2.5G/10G/25G (25G supported by the license) SFP28 ports
4 x 25G SFP28 ports
8 x 40G/100G QSFP28 ports (Each 40G port can be split into four 10G ports or each 100G port can be split into four 25G ports.)
48 x 1G/2.5G/10G/25G (25G supported by the license) SFP28 ports
48 x 100M/1G/2.5G/5GE/10G RJ45 ports with auto-negotiation
4 x 10G/25G SFP28 ports
2 x 40G/100G QSFP28 ports
4 x fan module slots
RG-PA550I II-F
RG-PA550I II-F
M2SFAN II-F
M2SFAN II-F
M2SFAN II-F
1 x MGMT port
1 x console port
3Tbps
4Tbps
1.56Tbps
915Mpps
915Mpps
915Mpps
Quad-core CPU, 2 cores with the clock speed of 2.0 GHz and 2 cores with the clock speed of 1.5 GHz
16MB
16MB
16MB
8GB
8GB
8GB
4GB DDR
4GB DDR4
4GB DDR4
14MB
14MB
14MB
RG-PA550I II-F (AC input):
● Rated input voltage: 100 V AC to 240 V AC
● Maximum input voltage: 90 V AC to 264 V AC
● Frequency: 50 Hz/60 Hz
RG-PA550I II-F (HVDC input):
● Rated input voltage: 240 V DC
● Maximum input voltage: 192 V DC to 288 V DC
● Rated current per circuit: 8 A
● RG-PA1000I-P-F (AC input):
Ports 1 to 48 support PoE/PoE+ power supply. Ports 1 to 24 support PoE++ power supply. Maximum output power of a port: 90 W
Maximum Power Consumption
270 W
300 W
Without PoE load: 280 W
Full PoE load: 1,480 W
442 mm x 420 mm x 44 mm (17.40 in. x 16.54 in. x 1.73 in.)
2+1 redundancy
Fan cooling, front、right and left-to-rear airflow
Automatic speed adjustment
RG-S6160-X Series
800 Gbps
128,000
9,0000
54,000
192,000 (shared with IPv6 routes)
30,000 (shared with IPv4 routes)
In: 21,000 Out:8,000
RG-S6160-X Series
4K 802.1Q VLANs
Port-based VLAN
QinQ
Link aggregation
LACP (802.3ad)
Spanning tree protocols
DHCP
DHCP relay agent
IPv6 DHCP server
IPv6 DHCP snooping
IPv6 DHCP relay
Basic IPv6 protocols
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, Stateless Auto Configuration, and Path MTU Discovery
OSPFv2, OSPFv3, IS-ISv4, and IS-ISv6
Equal-Cost Multi-Path (ECMP)
MCE
IGMPv1/v2/v3 and IGMP proxy
MLD snooping and MLD
PIM for IPv6
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
Ethernet Virtual Private Network (EVPN) VXLAN
ACL&
Flexible and diversified hardware ACLs:
Time range-based ACLs
ACL 80
ACL&
Queue scheduling: Strict Priority (SP), Deficit Round Robin (DRR), SP+DRR, and Random Early Detection (RED)/Weighted Random Early Detection (WRED)
MAB
Portal and Portal 2.0 authentication
RADIUS and TACACS+ authentication
SSH
Management features
SNMP, CLI (Telnet/console), RMON, SSH, syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnetv6, FTP/TFTP v6, DNSv6, NTP for v6, Traceroute v6
Management features
sFlow, which utilizes the random sampling technology to sample flow information of traffic on a switch
Management via the public cloud platform and RG-UNC
High reliability
VSU (virtualizing multiple devices into one device) GR for RIP, OSPF, BGP, and other routing protocols BFD ERPS (G.8032) REUP RLDP 1+1 power redundancy Hot swapping of power modules
Zero-touch provisioning (ZTP)
Protocol Compliance
Organization
Standards and Protocol
IETF
RFC 1157 A Simple Network Management Protocol (SNMP)
RFC 1305 Network Time Protocol Version 3 (NTP)
RFC 1349 Internet Protocol (IP)
RFC 1350 TFTP Protocol (revision 2)
RFC 1519 CIDR
RFC 1591 Domain Name System Structure and Delegation
RFC 1643 Ethernet Interface MIB
RFC 1757 Remote Network Monitoring (RMON)
RFC 1812 Requirements for IP Version 4 Router
RFC 1901 Introduction to Community-based SNMPv2
RFC 1902-1907 SNMP v2
RFC 1918 Address Allocation for Private Internet
RFC 2131 Dynamic Host Configuration Protocol (DHCP)
RFC 2132 DHCP Options and BOOTP Vendor Extensions
RFC 2571 SNMP Management Frameworks
RFC 2863 The Interfaces Group MIB
RFC 2865 Remote Authentication Dial In User Service (RADIUS)
RFC 2925 Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations (Ping only)
RFC 3046 DHCP Option82
RFC 3417 (SNMP Transport Mappings)
RFC 3418 Management Information Base (MIB) for the Simple Network Management Protocol (SNMP)
RFC 3575 IANA Considerations for RADIUS
RFC 3579 RADIUS Support For EAP
RFC 4022 MIB for TCP
RFC 768 User Datagram Protocol (UDP)
RFC 783 TFTP Protocol (revision 2)
RFC 792 Internet Control Message Protocol (ICMP)
RFC 793 Transmission Control Protocol (TCP)
RFC 813 Window and Acknowledgement Strategy in TCP
RFC 815 IP datagram reassembly algorithms
RFC 826 Ethernet Address Resolution Protocol (ARP)
RFC 854 Telnet Protocol
RFC 959 File Transfer Protocol (FTP)
RFC 1058 Routing Information Protocol (RIP)
RFC 1583 OSPF Version 2
RFC 1981 Path MTU Discovery for IP version 6
RFC 1997 BGP Communities Attribute
RFC 2236 IGMP
RFC 2328 OSPF Version 2
RFC 2385 Protection of BGP Sessions via the TCP MD5 Signature Option
RFC 2439 BGP Route Flap Damping
RFC 2460 Internet Protocol, Version 6 (IPv6)
RFC 2461 Neighbor Discovery for IP Version 6 (IPv6)
RFC 2462 IPv6 Stateless Address Auto configuration
RFC 2463 Internet Control Message Protocol for IPv6 (ICMPv6)
RFC 2545 Use of BGP 4 Multiprotocol Extensions for IPv6 Inter Domain Routing
RFC 2711 IPv6 Router Alert Option
RFC 2787 Definitions of Managed Objects for the Virtual Router Redundancy Protocol
RFC 2918 Route Refresh Capability for BGP 4
RFC 2934 Protocol Independent Multicast MIB for IPv4
RFC 3065 Autonomous System Confederation for BGP
RFC 3101 OSPF Not so stubby area option
RFC 3137 OSPF Stub Router Advertisement sFlow
RFC 3509 Alternative Implementations of OSPF Area Border Routers
RFC 3513 IP Version 6 Addressing Architecture
RFC 3623 Graceful OSPF Restart
RFC 3768 VRRP
RFC 3810 Multicast Listener Discovery Version 2 (MLDv2) for IPv6
RFC 3973 PIM Dense Mode
RFC 4271 A Border Gateway Protocol 4 (BGP 4)
RFC 4273 Definitions of Managed Objects for BGP 4
RFC 4360 BGP Extended Communities Attribute
RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP)
RFC 4486 Subcodes for BGP Cease Notification Message
RFC 4552 Authentication/Confidentiality for OSPFv3
RFC 4724 Graceful Restart Mechanism for BGP
RFC 4750 OSPFv2 MIB partial support no SetMIB
RFC 4760 Multiprotocol Extensions for BGP 4
RFC 4940 IANA Considerations for OSPF
RFC 5065 Autonomous System Confederation for BGP
RFC 5187 OSPFv3 Graceful Restart
RFC 5340 OSPFv3 for IPv6
RFC 5492 Capabilities Advertisement with BGP 4
RFC 6620 FCFS SAVI
IEEE
IEEE 802.2 Logical Link Control
IEEE 802.1ab Link Layer Discovery Protocol
IEEE 802.1ad Provider Bridges
IEEE 802.1ax/IEEE802.3ad Link Aggregation
IEEE 802.1D Media Access Control (MAC) Bridges
IEEE 802.1D Spanning Tree Protocol
IEEE 802.1Q Virtual Bridged Local Area Networks (VLAN)
IEEE 802.1s Multiple Spanning Tree Protocol
IEEE 802.1w Rapid Spanning Tree Protocol
IEEE 802.3ad Link Aggregation Control Protocol (LACP)
IEEE Std 802.3x Full Duplex and flow control
Before ordering a power module or optical transceiver, contact the online customer service personnel for the latest support information about it.
Main Unit
RG-S6160-28VS8CQ-X
24 x 1G/2.5G/10G SFP28 ports (default rate of 10 Gbps, which can be upgraded to 25 Gbps through licensing), 4 x 25G SFP28 ports, 8 x 40G/100G QSFP28 ports (a 40G port can be split into four 10G ports or a 100G port can be split into four 25G ports), 4 x fan module slots, and 2 x power module slots, with at least one RG-PA550I II-F power module required
RG-S6160-48VS8CQ-X
48 x 1G/2.5G/10G/25G SFP28 ports (default rate of 10 Gbps, which can be upgraded to 25 Gbps through licensing), 8 x 40G/100G QSFP28 ports, 4 x fan module slots, and 2 x power module slots, with at least one RG-PA550I II-F power module required
48 x 100M/1G/2.5G/5G/10G RJ45 ports with auto-negotiation, 4 x 10G/25G SFP28 ports, 2 x 40G/100G QSFP28 ports, 3 x fan module slots, and 2 x power module slots, with at least one RG-PA600I-P-F or RG-PA1000I-P-F power module required
Power Module
RG-PA550I II-F
550 W AC power module
1,000 W AC power module
\*RG-PA2200I-P-F
2,200 W AC power module
 Models marked with asterisks (*) in the ordering information will be available in the future.
Fan Module
M2SFAN II-F
License
RG-24VS-LIC
License for 25GE ports 1--24, one license per device, which is applicable to the RG-S6160-28VS8CQ-X and RG-S6150-24VS8CQ-X
RG-48VS-LIC
License for 25GE ports 1--48, one license per device, which is applicable to the RG-S6160-48VS8CQ-X and RG-S6150-48VS8CQ-X
Optical Transceivers
1GE Optical Transceivers
The port needs to be configured with auto-negotiation.
2.5GE Optical Transceivers
10GE Optical Transceivers
10GBASE-SR, SFP+ transceiver, 850 nm, Duplex LC, 300 m over MMF
10GBASE-LR, SFP+ transceiver, 1310 nm, Duplex LC, 10 km over SMF
10GBASE-ER, SFP+ transceiver, 1550 nm, Duplex LC, 40 km over SMF
XG-SFP-T
25GE Optical Transceivers
VG-SFP-AOC7M(M)
40GE Optical Transceivers
40G-AOC-10M
40GBASE, QSFP+ active optical cable (AOC), 10 m, including one cable and two optical transceivers
100GE Optical Transceivers
100G-AOC-1M
100GBASE, QSFP28 active optical cable (AOC), 1 m, including one cable and two optical transceivers
