RG-AP6930-D Wireless - 1
RG-AP6930-D Wireless - 2
RG-AP6930-D Wireless - 3
RG-AP6930-D Wireless - 4
RG-AP6930-D Wireless - 5
RG-AP6930-D Wireless - 6
RG-AP6930-D, Wi-Fi 7 Dual-Radio 3.570 Gbps Outdoor Access Point
Recommended for outdoor scenarios in education, enterprise, government, healthcare, finance, commerce, and other industries, providing long-range and focused wireless coverage.
  • Multi-service ports for flexible networking
  • Enterprise-class Wi-Fi 7 delivering a data rate of up to 3.570 Gbps
  • Built-in directional antennas for strong and focused coverage
  • Industrial-grade design for challenging outdoor environments
  • WIS digital twin network for superior network O&M efficiency
RG-AP6930-D Wi-Fi 7 Series Outdoor Access Point
The RG-AP6930-D is a Wi-Fi 7 outdoor AP designed by Ruijie for outdoor scenarios. It delivers the combined peak data rate of 3.570 Gbps, and features IP68-rated protection and a wide operating temperature range of –40°C to +55°C. With built-in directional antennas, it provides long-range and focused wireless coverage.
Multi-Service Ports for Flexible Networking
The multi-service port design enables flexible adaptation to different network architectures with a single deployment. The RG-AP6930-D provides one 5G SFP port that supports Ruijie SOE Solution, enabling long-distance fiber transmission in outdoor environments. It also provides one 2.5G Ethernet port for compatibility with existing Ethernet infrastructure.
Enterprise-Class Wi-Fi 7 Delivering a Data Rate of Up to 3.570 Gbps
The RG-AP6930 supports 4096-QAM modulation, delivering a 20% performance improvement over the 1024-QAM used by Wi-Fi 6. Combined with OFDMA multi-user access technology, the RG-AP6930 achieves the combined peak data rate of 3.570 Gbps, meeting high-bandwidth requirements of applications such as HD video and real-time interactive services.
Built-in Directional Antennas for Strong and Focused Coverage
Featuring a built-in directional antenna design, the RG-AP6930-D delivers strong, focused wireless beams over long distances, meeting connectivity needs of outdoor scenarios such as pedestrian streets, long and narrow corridors, and long-distance backhaul for security surveillance.
Industrial-Grade Design for Challenging Outdoor Environments
WIS integrates intelligent O&M functions, including visualized fault locating, along with local, service and key area network optimization. These capabilities aim to improve operational efficiency and enhance the user experience for wireless networks.
Go to WIS >
RG-AP6930-D
Channel:
2 spatial streams
● Radio 2 – 5 GHz: 2x2 downlink MU-MIMO, two spatial streams
Channel:
Radio 2 – 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
Radio technologies: OFDM
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
Channel:
Radio technologies: Uplink/Downlink Orthogonal Frequency-Division Multiple Access (OFDMA)
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
802.11be
Channel:
Radio technologies: Uplink/Downlink OFDMA
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● 2.4 GHz: two built-in directional antennas, with peak antenna gain of 9.4 dBi. Horizontal lobe angle of 35° and vertical lobe angle of 65°.
● 5 GHz: two built-in directional antennas, with peak antenna gain of 16.5 dBi. Horizontal lobe angle of 15° and vertical lobe angle of 30°.
● One built-in omnidirectional antenna, with the peak antenna gain of 5.9 dBi
1 x 10/100/1000/2.5GBASE-T port, supporting IEEE 802.3af/at power input
1 x 5GE SFP port, which is compatible with 2.5GE and 1GE SFP transceivers
1 x Bluetooth 5.3
LED
● 1 x system status LED
● 3 x signal strength LEDs
● Press the button for less than 2s. Then the device restarts.
● Press the button for more than 5s. Then the device is restored to factory defaults.
GPS
Main unit: 251 mm x 173 mm x 56 mm (9.88 in. x 6.81 in. x 2.20 in.)
Shipping: 489 mm x 422 mm x 347 mm (19.25 in. x 16.61 in. x 13.66 in.)
Main unit: 1.37 kg (3.02 lbs)
Mounting plate assembly: 0.35 kg (0.77 lbs)
Mounting bracket for wall/pole mounting: 0.15 kg (0.33 lbs)
Shipping: 12.36 kg (27.25 lbs)
Wall/Pole mounting
● 48 V DC/0.35 A power input over the DC connector
● PoE/PoE+ input, in compliance with 802.3af/at
● You are advised to power the AP using 802.3at (PoE+) so that the AP can deliver the optimal performance.
● When powered via 802.3af, the AP's default transmit power on both the 5 GHz and 2.4 GHz radios is reduced to 60%, with the duty cycle reduced by 50%. In this case, the wired port must be the RJ45 port.
● 802.3af power is not supported when the XG-SFP-TDM-BIDI-E transceiver is used.
Maximum power consumption: 15.5 W
● DC power: 15.5 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
When the XG-SFP-TDM-BIDI-E transceiver is used, the maximum power consumption is 16.5 W, enabling the AP to operate in optimal performance mode. In this case, the wired port can be the RJ45 or SFP port.
● 802.3at (PoE+): 15.5 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● 802.3af (PoE): 12.95 W
The AP's default transmit power on both the 5 GHz and 2.4 GHz radios is reduced to 60%, with the duty cycle reduced by 50%. In this case, the wired port must be the RJ45 port.
● Idle mode: 6.3 W
Operating temperature: –40°C to +55°C (–40°F to +131°F)
25,000 hours at the operating temperature of 25°C (77°F)
512 MB DRAM, 256 MB flash
2.4GHz
● Maximum transmit power: 28 dBm (630.96 mW)
The following table lists the radio frequency performance of Wi-Fi including different frequency bands, protocols, and data rates. It is country-specific, and Ruijie Networks reserves the right of interpretation.
Wi-Fi Radio Performance
RG-AP6930-D
2.4 GHz 802.11g
25 dBm
–96 dBm
2.4 GHz 802.11g
24 dBm
–84 dBm
2.4 GHz 802.11g
24 dBm
2.4 GHz 802.11g
–78 dBm
2.4 GHz 802.11n (HT20)
25 dBm
–95 dBm
21 dBm
–75 dBm
2.4 GHz 802.11n (HT40)
25 dBm
21 dBm
–73 dBm
2.4 GHz 802.11ax (HE20)
25 dBm
–96 dBm
–67 dBm
2.4 GHz 802.11ax (HE40)
25 dBm
–93 dBm
–64 dBm
2.4 GHz 802.11be (EHT40)
25 dBm
–92 dBm
–63 dBm
5 GHz 802.11a
25 dBm
–96 dBm
5 GHz 802.11a
24 dBm
–87 dBm
5 GHz 802.11a
24 dBm
5 GHz 802.11a
–78 dBm
5 GHz 802.11n (HT20)
25 dBm
–96 dBm
21 dBm
–76 dBm
5 GHz 802.11n (HT40)
25 dBm
–92 dBm
21 dBm
–73 dBm
5 GHz 802.11ac (VHT20)
25 dBm
–97 dBm
21 dBm
–74 dBm
5 GHz 802.11ac (VHT40)
25 dBm
–94 dBm
–69 dBm
5 GHz 802.11ac (VHT80)
25 dBm
–92 dBm
19 dBm
–66 dBm
5 GHz 802.11ax (HE20)
25 dBm
–97 dBm
–68 dBm
5 GHz 802.11ax (HE40)
25 dBm
–94 dBm
–63 dBm
5 GHz 802.11ax (HE80)
25 dBm
19 dBm
–67 dBm
–61 dBm
5 GHz 802.11ax (HE160)
25 dBm
–88 dBm
19 dBm
–64 dBm
–58 dBm
5 GHz 802.11be (EHT80)
25 dBm
19 dBm
–67 dBm
–62 dBm
MCS13
–56 dBm
5 GHz 802.11be (EHT160)
25 dBm
–88 dBm
19 dBm
–65 dBm
–58 dBm
MCS13
–55 dBm
Basic Functions
RG-AP6930-D
RGOS11.9(6)W8B2 or later
Recommended number of STAs
Maximum number of WLAN IDs
Control And Provisioning of Wireless Access Points (CAPWAP)
CAPWAP through Network Address Translation (NAT)
Mobile unit (MU) locating
Application management
PSK, web-based, 802.1X, WPA, WPA2, and WPA3 authentication
MAB
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), WPA3
Dynamic policy
CPU Protection Policy (CPP)
Static MAC address, MAC address filtering, and MAC address limiting
MAC address table size: 1,024
Jumbo frame length: 1,518
Optical transceiver information display, alarms about faults, and diagnosis parameter measurement (QSFP+/SFP+/SFP)
Maximum number of SVIs: 256
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarms
Web management (eWeb)
When the AP works in cloud mode, it can be managed through WIS Cloud.
The following value-added software functions can be achieved when the RG-AP6930-D is used with RG-WIS and the AC.
RG-AP6930-D
Network operation analysis such as device stability and signal coverage
Measuring user network experience based on indicators including latency, packet loss, RSSI, and channel utilization, with visualized network experience results
Statistics on the number of online and offline failures of STAs associated with different APs, average RSSI, and other parameters
Note: These functions are supported only when the RG-AP6930-D works in Fit mode.
Network performance optimization, including one-click network optimization and optimization solution setting based on different scenarios
Sticky client roam steering and experience indicator comparison
Remote association steering and experience indicator comparison
One-click diagnosis for analyzing problems and providing suggestions
Baseline analysis, recording changes in configuration, software version, and other parameters, and tracking changes in network KPIs
Time capsule for analyzing the history of device version and configuration changes
Cloud site survey
Batch generation of building floor information, floor plan upload, and drag-and-drop AP placement
One-click health check report and generation of reports on the overall network operating status
Unauthorized Wi-Fi signal locating and classified display, as well as countermeasure capabilities
Uniformly connecting, managing, and maintaining APs, ACs, and other devices
Batch device configuration and upgrade
ZTP deployment, creating configuration templates, and automatically applying configured templates
Discovering wired and wireless network topology with one click and generating the topology
Portal authentication page
Customizing Portal authentication pages for PCs and mobile phones
Interworking with Guodu and Alibaba Cloud SMS gateways
Big data capabilities
Data warehouse building based on Hive, data model conversion, and integration
Hierarchical and role-based access control
Administrators at different sites have different operation permissions.
System management functions including account operations, authorization configuration, email configuration, configuration backup, and exception alarms
Note: For details, refer to the latest hybrid cloud management solution of Ruijie Networks.
RG-AP6930-D
EN 55032, EN 55035, EN 301 489-1, EN 301 489-17, IEC 62368-1, and EN 62368-1
● EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP6930-D] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
● UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP6930-D] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at https://www.ruijie.com/.
● The functions of Wireless Access Systems (WAS) including Radio Local Area Networks (RLANs) within the band 5,150–5,350 MHz for this device are restricted to indoor use only within European Union countries and other relevant European regions (BE/BG/CZ/DK/DE/EE/IE/EL/ES/FR/HR/IT/CY/LV/LT/LU/HU/MT/NL/AT/PL/PT/RO/SI/SK/FI/SE/TR/NO/CH/IS/LI/UK(NI)).
● Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
RG-AP6930-D
Wi-Fi 7 (802.11be) dual-radio outdoor access point
Up to four spatial streams and peak data rate of 3.570 Gbps
● Radio 1 – 2.4 GHz: Two spatial streams, 2x2 MU-MIMO, peak data rate of 688 Mbps
● Radio 2 – 5 GHz: Two spatial streams, 2x2 MU-MIMO, peak data rate of 2.882 Gbps
It complies with 802.11a/b/g/n/ac/ax/be, and supports switchover among Fat, Fit, and cloud modes.
It provides IEEE 802.3af/802.3at-compliant (PoE/PoE+) and DC power supply.
● The Ethernet power supply device needs to be purchased separately.
● The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.35 A.
