A redundant, hot-swapping power supply and fan, dual flash storage providing system-level backup and rapid recovery, and a dedicated console port enable continuous, stable O&M across diverse deployment scenarios.
Dual-boot and dual-bin mechanisms enable version redundancy and fault tolerance, supporting hot patch upgrades without service interruption. Dual links with up to eight-node stacking and VRRP, combined with BFD bidirectional detection, load balancing, and millisecond-level failover ensure network continuity. Cloud-based early warning and one-click fault isolation via SNMP and Syslog, combined with proactive monitoring, enable preemptive risk mitigation.
Gigabit access supports 2.5G uplinks, significantly enhancing stacking performance and uplink throughput; the entire series operates reliably within a temperature range of 0–50°C (32–122°F) and at altitudes up to 5 km (3.11 miles), offering excellent environmental adaptability; 24/48-port Gigabit all-optical and 24/48-port 25G all-optical products are provided, combined with multi-rate uplinks to deliver comprehensive networking solutions; MAC table capacity is substantially increased, addressing the needs of medium-sized enterprises and diverse service scenarios.
High-performance Layer 3 core switching with flexible multi-rate access and high-bandwidth uplinks. N+1 redundancy and 8-device VSU help maximize network availability and simplify management—less downtime, lower TCO.
Reliable Layer 3 access switching built for demanding environments: 10 kV surge protection and a wide operating temperature range keep it running where standard switches fail. VSU stacking up to 8 devices simplifies management and scaling—stable edge performance at lower TCO.
