RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 1
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 2
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 3
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 4
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 5
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 6
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 7
RG-CS62-48GT4XS-P Small & Medium Enterprise Networking - 8
RG-CS62-48GT4XS-P, Layer 3 Access Switches with 10G Uplinks
  • 10GE SFP+ uplink
  • 10 kV port surge protection
  • Supports operating temperatures up to 50°C
  • Dual flash, dual boot, and dual bin
  • Circuit isolation protection based on optical ports
  • Supports up to 8 devices in a VSU
  • Layer 3 service features
Key Specifications
Current RG-CS62-48GT4XS-P RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-24GT4XS-P RG-CS62-48GT4XS RG-CS62-48GT4XS
Fixed service port 48 x 10/100/1000BASE-T ports, supporting PoE/PoE+
4 x 1GE/2.5GE/10GE SFP+ ports
Console port 1 1 1 1
USB 1 1 1 1
Switching capacity 176 Gbps (Gbit/s) 128 Gbps (Gbit/s) 128 Gbps (Gbit/s) 176 Gbps (Gbit/s)
Forwarding rate 130.94 Mpps 95.23 Mpps 95.23 Mpps 130.94 Mpps
Unit dimensions (W x D x H) 440 mm x 262.8 mm x 43.6 mm (17.32 in. x 10.35 in. x 1.72 in.) 442 mm x 222.8 mm x 43.6 mm (17.4 in. x 8.77 in. x 1.72 in.) 442 mm x 222.8 mm x 43.6 mm (17.4 in. x 8.77 in. x 1.72 in.) 442 mm x 222.8 mm x 43.6 mm (17.4 in. x 8.77 in. x 1.72 in.)
Unit weight 4.3kg (9.48 lbs) 2.60 kg (5.73 lbs) 2.90 kg (6.39 lbs) 2.90 kg (6.39 lbs)
Maximum power consumption Full-load:
110 V: 456.65 W
220 V: 446.79 W
No-load:
110 V: 56.064 W
220 V: 55.438 W
110 V: 22.407 W
220 V: 22.163 W
Full-load:
110 V: 439.65 W
220 V: 428.56 W
No-load:
110 V: 34.179 W
220 V: 33.511 W
110 V: 45.414 W
220 V: 44.316 W
PoE Yes - Yes -
Operating temperature 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F)
Fan 2 x fixed fans Fanless design 1 x fixed fan 1 x fixed fan
Warranty 5 years 5 years 5 years 5 years
Aggregate interface LACP basics LACP basics LACP basics LACP basics
RG-CS62-48GT4XS-P
    Equipped with 10G uplinks, access switches eliminate congestion in high-concurrency traffic scenarios.
    8-Unit Stacking
    8-Unit Stacking
    8-Unit Stacking
    8-unit stacking for flexible expansion helps maintain continuous service during device failures.
  • 3
    Dual-boot & Dual-bin
    3
    Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
    Area-based Port Power Supply
    When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
  • 5
    Layer 3 Capabilities
    5
    Access switches with Layer 3 capabilities, including OSPF and 6,000 route entries, help contain the impact of network failures and enable faster recovery than traditional Layer 2 access switches.
  • 6
    10 kV Surge Protection & 50°C Operation
    6
    Compared with typical switches that support 6–8 kV surge protection and operation up to 45°C, Cybrey switches deliver 10 kV surge protection and stable performance at temperatures up to 50°C, making them suitable for harsh environments.
In the Box
  • RG-CS62-48GT4XS-P
    × 1
  • Power cord
    × 1
  • Rack-mount bracket
    × 2
  • M4 x 8 mm screws
    × 6
  • Rubber pad
    × 1
  • Grounding wire
    × 1
  • Power cord retention clip
    × 1
Cybrey Cloud, Make Your Business Easy
  • Interface Configuration
  • MAC Address Management
  • Vlan Configuration
  • 802.1X Authentication
Port Specifications RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Console port 1
USB 1
System Specifications RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Packet buffer size 12 Mbit
CPU Dual-core ARM A55 CPU frequency up to 1.0 GHz
SDRAM 2 GB
Flash memory 512 MB
BootROM 16 MB
Real-time clock (RTC) Yes
Dimensions and Weight RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Rack height 1 RU
Packaging dimensions (W x D x H) 560 mm x 377 mm x 150 mm (22.05 in. x 14.84 in. x 5.91 in.) 540 mm x 340 mm x 153 mm (21.26 in. x 13.39 in. x 6.02 in.) 540 mm x 340 mm x 153 mm (21.26 in. x 13.39 in. x 6.02 in.) 540 mm x 340 mm x 153 mm (21.26 in. x 13.39 in. x 6.02 in.)
Packaging weight 5.57 kg (12.28 lbs) 3.58 kg (7.89 lbs) 4.03 kg (8.88 lbs) 3.7 kg (8.16 lbs)
Power Supply and Consumption RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Power supply mode 1 x fixed power supply
110 V: 456.65 W
220 V: 446.79 W
No-load:
110 V: 56.064 W
220 V: 55.438 W
110 V: 22.407 W
220 V: 22.163 W
Full-load:
110 V: 439.65 W
220 V: 428.56 W
No-load:
110 V: 34.179 W
220 V: 33.511 W
110 V: 45.414 W
220 V: 44.316 W
Power input AC input
● Maximum input current: 6 A
● Maximum input current: 2 A
PoE Yes - Yes -
Number of PoE-out ports All RJ45 ports support PoE/PoE+ (IEEE802.3af/at) power supply - All RJ45 ports support PoE/PoE+ (IEEE802.3af/at) power supply -
PoE budget 370 W - 370 W -
PoE budget per port 30 W - 30 W -
PoE power cable pairs Mode A (1-2, 3-6 pairs) - Mode A (1-2, 3-6 pairs) -
Environment and Reliability RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Operating humidity 10% RH to 90% RH (non-condensing)
Storage humidity 5% RH to 95% RH (non-condensing)
Operating altitude 0 m to 5000 m (0 ft. to 16,404.20 ft.)
Cooling Air cooling, left-to-rear airflow Natural cooling Air cooling, left-to-right airflow Air cooling, left-to-right airflow
Noise 27°C (80.6°F): 40 dB - 27°C (80.6°F): 40 dB 27°C (80.6°F): 40 dB
Fan speed adjustment Intelligent speed adjustment - Intelligent speed adjustment Intelligent speed adjustment
Hot swapping of cables Yes
USB hot swapping Yes
Surge protection Service port: ±10 kV for common mode
Power connector: ±6 kV for common mode and ±6 kV for differential mode
Power connector: ±6 KV for common mode and ±6 kV for differential mode
ESD prevention Contact discharge: 6 kV
Air discharge: 8 kV
Temperature monitoring and protection Temperature monitoring, temperature alarm, and over-temperature protection
Fan monitoring Fault alarm - Fault alarm Fault alarm
MTBF > 400,000 hours
Energy efficiency Yes
Certification and Regulatory Compliance RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Safety regulations IEC 62368-1 EN 62368-1
EMC regulations EN 300386, EN 55032 Class A, EN 55035,
EN IEC 61000-3-2, EN 61000-3-3, EN 61000-4-2, EN IEC 61000-4-3,
EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN IEC 61000-4-11
Product Information RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Warranty 5 years
Layer 2 Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
VLAN IEEE 802.1Q
Port-based VLAN
MAC-based VLAN
IP/Subnet-based VLAN
Protocol-based VLAN
Super VLAN
Spanning tree IEEE802.1d STP
IEEE802.1w RSTP
Standard 802.1s MSTP
LLDP LLDP
LLDP-MED
Basic QinQ Basic QinQ
Transparent transmission of double-tagged packets
Selective QinQ Selective QinQ
REUP REUP
RLDP RLDP
ERPS(G.8032) ERPS(G.8032)
Layer 3 Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
ARP ARP
anyIP
ND Neighbor discovery
VRF IPv4 and IPv6 VRF
Routing Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Static routing IPv4 static routing
IPv6 static routing
OSPF OSPFv2 basics
OSPFv3 basics
RIP RIP
RIPv2
RIPng RIPng
PBR IPv4 PBR
IPv6 PBR
Multicast Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
IGMP snooping IGMP snooping v1/v2
IGMP snooping v3
IGMP IGMPv1/v2/v3
IGMP proxy
MLD snooping MLD snooping
MLD snooping v2
MLD MLDv1/v2
PIM-SMv4 PIM-SMv4
PIM-SSMv4
PIM-DMv4 PIM-DMv4
PIM-SMv6 PIM-SMv6
PIM-SSMv6
MSDP MSDP
ACL and QoS RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
ACL IP standard ACL
IP extended ACL
MAC extended ACL
Expert ACL
Time-based ACL
ACL-based redirection
QoS Traffic classification based on 802.1p priorities, DSCP priorities, and IP precedences
SP
WRR
SP+WRR
DRR
SP+DRR
WFQ
SP+WFQ
Traffic shaping (ingress/egress)
Security Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
802.1X Port-based authentication
MAC-based authentication
AAA AAA
Web-based authentication HTTP-based authentication
HTTPS-based authentication
IP source guard IP source guard
IPv6 source guard IPv6 source guard
SAVI SAVI
Global IP-MAC binding Configuring global IP-MAC binding entries
TACACS+ TACACS+
CPP Hardware CPP
Port isolation Port isolation
RADIUS RADIUS
Port Security Port Security
NFPP NFPP
High Availability RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
VSU Device virtualization
VRRP IPv4 VRRPv2
IPv4 VRRPv3
IPv6 VRRP
VRRP+ IPv4 VRRP+
IPv6 VRRP+
BFD BFD detection
DLDP DLDP
Interface Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Mirroring SPAN
RSPAN
Management Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
SNMP SNMPv1/v2c/v3
SSH SSHv2
SSHv1
sFlow sFlow
gRPC gRPC framework
NETCONF NETCONF
SON SON
Cybrey Cloud Cybrey Cloud
OAM Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
PoE Uninterrupted power supply upon warm start
PoE port priority
- Uninterrupted power supply upon warm start
PoE port priority
IP Services RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
DHCP DHCPv4 client
DHCPv4 server
DHCPv4 relay
DHCPv4 snooping
DHCPv6 client
DHCPv6 relay
ND snooping ND snooping
DNS DNS client
DNSv6 client
NTP NTP client
NTP server
SNTP SNTP client
SNTP
FTP FTP client
FTP server
TFTP TFTP client
TFTP server
System Features RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
USB USB 2.0
Capacity Specifications
Maximum number of global MAC addresses (The device must be able to learn the maximum number of MAC addresses in the full-mesh test model.) Default: 16000 (subject to the UFT capacity)
Maximum number of created VLANs 4094
Jumbo frame length / Port MTU 9216
Layer 2 traffic convergence time ≤ 200 ms
Maximum number of ARP entries 4000
IPv4 routing table size 6000
IPv6 routing table size 2000
Maximum number of IPv4 multicast routing table entries 1000
Number of multicast groups x Number of outbound interfaces ≤ 1000
Maximum number of IPv6 multicast routing table entries 900
Maximum number of inbound ACE entries 1750
Maximum number of outbound ACE entries 800 (The capacity can reach 800 when only Layer 2 match fields, excluding inner tags, are used. If other match fields are added, the capacity may decrease to 350.)
Maximum number of QoS hardware queues 8 (shared by unicast and multicast traffic)
Maximum number of VSU members 8
Package Contents
Device RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Main unit 1
Accessories RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
Power cord 1
Rack-mount bracket 2
Screw 6 x M4 x 8 mm screws
Rubber pad 4
Grounding wire 1
Power cord retention clip 1
Manual RG-CS62-48GT4XS-P RG-CS62-24GT4XS RG-CS62-24GT4XS-P RG-CS62-48GT4XS
User Manual 1
Warranty Card 1
