RG-CR5016XS Small & Medium Enterprise Networking - 1
RG-CR5016XS Small & Medium Enterprise Networking - 2
RG-CR5016XS Small & Medium Enterprise Networking - 3
RG-CR5016XS Small & Medium Enterprise Networking - 4
RG-CR5016XS Small & Medium Enterprise Networking - 5
RG-CR5016XS Small & Medium Enterprise Networking - 6
RG-CR5016XS Small & Medium Enterprise Networking - 7
RG-CR5016XS Small & Medium Enterprise Networking - 8
RG-CR5016XS, Intelligent CR Series Router
Hotels, enterprises, schools, factories, hospitals, etc.
  • High Performance — Max 7,000 concurrent clients for large-scale deployments
  • Easy PMS Integration — Built-in PMS support, PMS connectivity, and free API access
  • Secure Wireless Screen Casting — One-touch screen casting with smart authentication
  • Precise Behavior Control — DPI-based traffic classification for granular user activity management, from URL filtering to application-level bandwidth shaping
  • AD & Entra ID Integration — Native integration with Microsoft AD & Entra ID authentication, with no middleware required
  • SD-WAN — Smarter paths, better connectivity, and enterprise-grade SD-WAN readiness
    Intelligent Multi-Service Gateway, Much More Than a Router
    RG-CR5016XS
    One Master Device with Multi-Service Capabilities
    The CR Series Intelligent Gateway is the network cornerstone for modern SMEs. It integrates high-concurrency processing, advanced routing, hotel PMS integration, secure wireless screen mirroring in guest rooms, precise access control, AD & AAD integration, and SD-WAN+ — all within a high-redundancy, enterprise-grade, fine-designed box. It delivers the stable, flexible connectivity your business deserves.
    Unique Value
    Optimized for large-scale scenarios, Up to 7000 concurrent clients.
    1 Auto Guest Wi-Fi Authentication
    2 Auto Check-out Cleanup
    3 Auto Guest Information Synchronization
    4 VIP Privileges
    1 PMS Integration, No Codes, No Hassle - The hotel PMS is integrated with the CR gateway to automatically bind guests' clients to their rooms, enabling secure screen mirroring with a single tap. PMS Integration, No Codes, No Hassle
    2 Scan the Room Code, No Passwords, No Downloads - No PMS integration is required. Guests scan the room QR code to finish the TV binding, and enable secure wireless screen mirroring with a single tap. Scan the Room Code, No Passwords, No Downloads
    High Concurrency
    Enterprise-Grade Hardware. NTOS Inside. High Concurrency Ready.
    Hotel PMS Integration
    Seamlessly connect with Property Management Systems for smarter hotel operations.
    Secure Wireless Screen Mirroring in Guest Rooms
    Let guests mirror content safely without exposing the corporate network.
    Precise Internet Access Control (URL Filtering & App Control)
    Granular policies for URLs and applications keep your business secure and productive.
    AD & AAD Integration
    Unified authentication with Active Directory and Azure Active Directory.
    SD-WAN+
    Intelligent path selection and link balancing for reliable branch connectivity.
    High Concurrency
    In the Box
    • RG-CR5016XS
      × 1
    • Power Cord
      × 1
    • Rack-mount bracket - front
      × 2
    • Rubber Pad
      × 1
    • Slide Rail with Mounting Ears
      × 2
    • Rack-mount bracket - back
      × 2
    • 0.06mm Screw
      × 8
    • 0.04mm Screw
      × 6
    • Grounding wire
      × 1
    • Power cord retention clip
      × 1
    Cybrey Cloud, Make Your Business Easy
    • Health Dashboard
    • Timeline Track
    • AI HawkEye
    • AI Insight
    Videos
    Local Accelerated Authentication Configuration Guide for RG-CR Routers and RG-CF Firewalls
    Nov. 5, 2026
    How to Configure AI Threat Detection for RG-CR Routers and RG-CF Firewalls?
    Nov. 5, 2026
    How to Configure Wired and Wireless Networks on the Cybrey Platform?
    Oct. 29, 2026
    How to Onboard Cybrey Devices through Cloud, eWeb, and App?
    Oct. 29, 2026
    How to Manage Third Party Devices on Cybrey Cloud?
    Oct. 29, 2026
    Load Balancing (Based on Source IP+Destination IP) Configuration for RG-CR Router and RG-CF Firewall
    Oct. 10, 2026
    Cross-VLAN Precise Casting Configuration for RG-CR Routers and RG-CF Firewalls
    Oct. 10, 2026
    Keyword Filtering Configuration Guide for RG-CR Router and RG-CF Firewall
    Oct. 10, 2026
    SD-WAN Configuration Guide for for RG-CR Routers and RG-CF Firewalls
    Oct. 10, 2026
    Block Specified Websites and Adult Websites Using URL Filtering for RG-CR Router and RG-CF Firewall
    Oct. 10, 2026
    Views
