RG-S6990-128QC2XS Data Center Networking - 1
RG-S6990-128QC2XS Data Center Networking - 2
RG-S6990-128QC2XS Data Center Networking - 3
RG-S6990-128QC2XS Data Center Networking - 4
RG-S6990-128QC2XS Data Center Networking - 5
RG-S6990-128QC2XS Data Center Networking - 6
RG-S6990-128QC2XS – 128-Port 400GE Fixed Switch for AIGC Intelligent Computing Networks
128 x 400GE ports and 2 x 10GE ports, RDLB and GDLB of the AI-Fabric solution to improve the bandwidth and shorten the AI training time in AIGC intelligent computing scenarios
  • High-density 400GE switch with 128 x 100GE/200GE/400GE QSFP112 ports housed in a 4-RU enclosure
  • Eliminating packet loss during E2E communication through RDMA, building high-performance and low-latency data center networks
  • Hardware-level redundancy, ensuring service continuity and preventing network downtime
  • Nanosecond-level hardware failover, mitigating the impact of network faults on services and securing network stability
  • AI-powered intelligent O&M, making management easy and efficient
RG-S6990-128QC2XS – 128-Port 400GE Data Center Fixed Switch
The high-speed and high-density core switch provides 128 x 400GE ports housed in a 4-RU enclosure,
delivering scalable, high-performance, and high-bandwidth services for large-scale DCI networks.
Eliminating Packet Loss During E2E Communication Through RDMA, Building High-Performance and Low-Latency Data Center Networks
PFC and ECN are leveraged to implement intelligent data exchange and eliminate packet loss. With the RDMA technology, data does not need to be handled by the CPU during device communication. This reduces the CPU load
and addresses network latency issues, ensuring lossless transmission of data. In addition, Remote Dynamic Load Balancing (RDLB) and Global Dynamic Load Balancing (GDLB) of the AI-Fabric solution solve the ECMP conflict caused by flow-based load balancing, improving the bandwidth and shortening the AI training time in AIGC intelligent computing scenarios.
Hardware-Level Redundancy, Ensuring Service Continuity and Preventing Network Downtime
The switch supports 2+2 power redundancy, enables failover in seconds, and ensures network connectivity during power replacement. This provides dual protection for links.
AI-Powered Intelligent O&M
Making Management Easy and Efficient
The switch offers AI-powered automatic ECN tuning, real-time telemetry of key RoCE network metrics, visualization of endpoint status and RoCE services, along with congestion and packet loss analytics.
RG-S6990-128QC2XS
446 mm x 800 mm x 173.6 mm (17.56 in. x 31.5 in. x 6.84 in.)
4 RU
37.6 kg (82.89 lbs., empty chassis)
45 kg (99.21 lbs., a chassis with four power modules and five fan modules)
102.4 Tbps
21000 Mpps
Service port
128 x 100G/200G/400G QSFP112 ports
2 x GE/10GE SFP+ ports
Management port
4 x power module slots
5 x fan module slots
Maximum power consumption: 3160 W
Typical power consumption: 2432 W
Static power consumption: 433 W
RG-PA1600II-F (AC input):
Rated input current: 12 A (100 V AC to 127 V AC)
9.5 A (200 V AC to 240 V AC)
Power port type: C14
RG-PA1600II-F (HVDC input):
Rated input voltage: 240 V DC
Rated input current: 9.5 A
Note: At altitudes ranging from 1,800 m (5,905.51 ft.) to 5,000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft) increase in elevation.
Operating altitude ≤ 5,000 m (16,404.20 ft.)
Storage altitude ≤ 5,000 m (16,404.20 ft.)
RG-S6990-128QC2XS
Layer 2 protocols
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
Layer 3 protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, LPM Routing, Policy-based Routing, Route-policy, ECMP, WCMP, VRRP
Basic IPv6 protocols
Neighbor Discovery, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, IPv6 TCP/UDP, SNMPv6, IPv6 Ping/Traceroute, IPv6 RADIUS, IPv6 Telnet/SSH, IPv6 FTP/TFTP, NTPv6, IPv6 MIB for SNMP, IPv6 VRRP, IPv6 QoS
IPv6 features
Data center features
VXLAN, BGP-EVPN
RDMA
PFC, ECN
PFC deadlock prevention
AI ECN
ECN overlay
Global loading balancing, Remote Adaptive Load Balancing (RALB), Artificial Intelligence Scene Load Balancing (AILB), end-to-network load balancing (ENLB), source port-based load balancing (SPLB)
Visualization
Telemetry
INT, MOD
IEEE 802.1p, DSCP, and ToS mapping
Priority marking and re-marking
Multiple queue scheduling mechanisms, including SP, WRR, WFQ, DRR, SP+WRR, SP+WFQ, SP+DRR
High redundancy design
GR for RIP/OSPF/BGP, BFD, DLDP, REUP, Rapid Link Detection Protocol (RLDP), 2 + 2 power redundancy, fan redundancy, and hot swapping of line cards and power modules
Security features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), RADIUS/TACACS, IPv4/IPv6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet from specified IP addresses, broadcast packet suppression, and hierarchical user management
MLAG
Management mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, temperature alarm
Other protocols
DHCP Client, DHCP Relay, DHCP Server, DNS Client, ARP Proxy, and Syslog
RG-S6990-128QC2XS
Fixed 128 x 400GE ports, 2 x 10GE ports, four power module slots, and five fan module slots
RG-PA1600II-F
Power module, hot swappable 2 + 2 redundancy, front-to-rear airflow
FAN80-180F
Fan module, hot swappable 4 + 1 redundancy, front-to-rear airflow
1GE Optical Transceivers
1GE LX transceiver, SFP form factor, BIDI LC, 1550 nm, 20 km (65,616.80 ft.) over SMF
1GE LX transceiver, SFP form factor, BIDI LC, 1310 nm, 20 km (65,616.80 ft.) over SMF
1GE LX transceiver, SFP form factor, BIDI LC, 1550 nm, 3 km (9,842.52 ft.) over SMF
1GE LX transceiver, SFP form factor, BIDI LC, 1310 nm, 3 km (9,842.52 ft.) over SMF
1GE LH transceiver, SFP form factor, BIDI LC, 1550 nm, 40 km (131,233.59 ft.) over SMF
1GE LH transceiver, SFP form factor, BIDI LC, 1310 nm, 40 km (131,233.59 ft.) over SMF
1GE ZX transceiver, SFP form factor, duplex LC, 1550 nm, 80 km ( 262,467.20 ft.) over SMF
10GE Optical Transceivers
10GE AOC cable, SFP+ form factor, 5 m (16.40 ft.)
10GE LR transceiver, SFP+ form factor, duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF
XG-SFP-iLR-SM1310-I
10GE LR transceiver, SFP+ form factor, duplex LC, 1310 nm, 1.4 km (4,593.18 ft.) over SMF
100GE Optical Transceivers
100GE ER4 transceiver, QSFP28 form factor, duplex LC, 1310 nm, 40 km (131,233.59 ft.) over SMF
100GE iLR4 transceiver, QSFP28 form factor, duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF
100GE LR4 transceiver, QSFP28 form factor, duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF
100GE SR transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over OM4 MMF
200GE Optical Transceivers
200G-Q56-SR4-MM850(D)
200GE SR4 transceiver, QSFP56 form factor, MPO12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MPO MMF, CMIS-compliance
200G-Q56-SR4-MM850
200GE SR4 transceiver, QSFP56 form factor, MPO12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MPO MMF, SFF-8636-compliance
400GE Optical Transceivers
400G-Q112-DR4-SM1310
400GE DR4 transceiver, QSFP112 form factor, MPO-12 APC, 1310 nm, 500 m (1,640.42 ft.) over SMF
400G-Q112-VR4-MM850
400GE VR4 transceiver, QSFP112 form factor, MPO-12 APC, 850 nm, 50 m (164.04 ft.) over OM4 MMF
