RG-SG7008L Switches - 1
RG-SG7008L Switches - 2
RG-SG7008L Switches - 3
RG-SG7008L Switches - 4
RG-SG7008L Switches - 5
RG-SG7008L Switches - 6
RG-SG7008L Switches - 7
RG-SG7008L Switches - 8
RG-SG7008L Switches - 9
RG-SG7008L Fixed 10GE ODON Master Device Applied in ODON Solution
Interworking with remote units as a core/aggregation switch in Small and Medium-Sized networks, enabling flexible networking
  • ODON Master Device with Multi-Service Integration
  • Modular Design for Flexible Combination of Line Cards, Meeting Diverse Network Needs
  • Clos Architecture for Shorter, Interference-Free Data Transmission
  • Streamlined O&M with Embedded RG-INC-EMB and WIS Cloud
RG-SG7008L, Fixed 10GE ODON Master Device
The ODON master device serves as a core or aggregation device in Small and Medium-Sized networks, providing 1GE and 10GE optical ports. It integrates switching, wireless, routing, and basic security features, with indoor remote units, serving the whole campus through one network.
Dimentions
Designed for Small and Medium-Sized campus scenarios, One Device for One Network (ODON) Solution adopts a combination of an ODON Master Device and remote units to simplify the network architecture and reduce deployment costs, meeting the demands of rapid secure access and efficient data transmission on campus networks.
Integrating the functions of switches, wireless access controllers (ACs), routers, and software-defined networking (SDN) platforms for multi-purpose use, the RG-SG7008L works with in-room switches, access switches as a core or aggregation switch in Small and Medium-Sized networks, enabling flexible networking.
The device supports a flexible combination of various line cards. You can purchase different types of line cards as needed. Each line card has independent calculating modules and is separated from others, meeting various service deployment requirements.
The advanced Clos architecture adopts an orthogonal design for the switch fabric module and line cards.
Data is transmitted to the switch fabric module directly without traversing the backplane, shortening the signal transmission path.
Signal transmission and anti-interference capabilities are improved, ensuring interference-free data transmission.
VSU, Delivering Flexible Networking Capabilities and High
Performance
The VSU technology virtualizes multiple physical devices into ore logical unit.
The devices are operated and managed in a unified manner, significantly reducing network nodes and simplifying O&M.
Link failover in milliseconds ensures uninterrupted transmission of critical services.
The ODON Master Device integrated with either a cloud-based or local O&M platform offers the plug and play capability. This simplifies maintenance and enables rapid deployment, allowing network-wide management with a single switch.
RG-SG7008L
Fixed ports
Management ports
1 x console port, 1 x USB port, compliant with the USB 2.0 standard
Module slots
6 x common service card slots (slots 1--6)
2 x multi-service module slots (slots 7 and 8)
2 x power module slots (slots PWR1 and PWR2)
1 x hard disk slot
Built-in switch fabric unit (SFU) and fan modules
Multi-service card slots
M7000L-6XS (6 x 10GE optical interface ports)
M7008L-RCM (routing card)
M7008L-WSM (wireless card)
Common service card slots
M7000L-8GT (8 x GE Ethernet interface card)
M7000L-8SFP (8 x GE optical interface card)
Hard disk slot
M7000L-HDD-1T (1 TB hard disk can be expanded.)
416 Gbps
310 Mpps
Chassis without cable management arm (2 U): 442 mm x 320 mm x 88 mm (17.40 in. x 12.60 in. x 3.46 in.)
Chassis with cable management arm (3 U): 442 mm x 406 mm x 131.5 mm (17.40 in. x 15.98 in. x 5.18 in.)
Net weight: about 5.95 kg (13.12 lbs.)
Power Supply and Fan
RG-PA180I-F:
Input: 90 V--290 V AC
Output power: 180 W (12 V/180 W)
Power redundancy
Support 1+1 redundancy and current sharing.
Fixed fan modules
3 x built-in fan modules
Fan speed adjustment and fan failure alarming are supported.
0°C to 45°C (32°F to 113°F)
--40°C to +70°C (--40°F to +158°F)
5% RH to 95% RH
● Long-term operating altitude: 0 m to 1800 m (0°C to 45°C, 32°F to 113°F)
Note: At an altitude from 1800 m (5906 ft) to 5000 m (16404 ft), the maximum temperature decreases by 1°C (1.8°F) each time the altitude increases by 220 m (722 ft).
● Operating altitude: up to 5000 m (16404 ft)
Storage altitude: up to 5000 m (16404 ft)
Product Feature
RG-SG7008L
Switching module
4000 IEEE 802.1Q VLANs
Port-based VLAN
QinQ
Flexible QinQ
Link aggregation
Spanning tree protocols
The hardware supports Virtual Extensible LAN (VXLAN). Through software upgrade in the future, a logical Layer 2 network can be built on the basis of the Layer 3 network.
DHCP
IPv6 DHCP server
IPv6 DHCP snooping
IPv6 DHCP relay
OSPFv2, OSPFv3, IS-ISv4, and IS-ISv6
IGMPv1/IGMPv2/IGMPv3 and IGMP proxy
MLD Snooping and MLD
PIM for IPv6
Flexible and diversified hardware ACLs
MAC-based extended ACLs
Basic security features
802.1x authentication based on the port number and MAC address
ARP check, ARP packet rate limiting, gateway-targeted ARP spoofing prevention
Hierarchical management and password protection of administrators
RADIUS and TACAS+
SSHv2 to provide a secure, encrypted connection for user login
BPDU Guard
Attack defense, DoS/DDoS defense, fragmentation attack defense, SYN attack defense, and IP spoofing attack defenseL2TP, IPsec VPN, GRE
Management features
SNMP, CLI (Telnet/Console), RMON, SSH, syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSH over IPv6, Telnetv6, FTPv6/TFTPv6, DNSv6, NTP for IPv6, and Traceroute for IPv6
CLI configurations including the console port, auxiliary port, Telnet, or SSH
File transfer protocols such as FTP, TFTP, and XMODEM
sFlow, which utilizes the random sampling technology to sample flow information on the traffic of a switch
WIS-based management
High reliability
VSU (virtualizing multiple devices into one device)
1+1 power redundancy
Hot swapping of power modules
Routing module
IPv4 features
LLDP, 802.1Q, 802.1p, 802.3ad, and other Ethernet features
Static routing, RIPv1/RIPv2, OSPFv2, BGP, IS-IS, PBR, and routing policies
VRRP, FTP, and TFTP
ECMP and WCMP
Static and dynamic NAT, static and dynamic NAPT, and VPN NAT
DNS resolution and smart DNS
NTP server and NTP client
IPv6 features
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, Stateless Auto Configuration, and Path MTU Discovery
Static routing, RIPng, OSPFv3, BGP4+, IS-ISv6, ECMP, and PBR
VRRPv3, BFDv6, and 6VPE
IPv6 ACL, NAT64, NAT-PT, DHCPv6, DNSv6, FTPv6, and TFTPv6
Manual tunnel, automatic tunnel, ISATAP, and GRE tunnel
MPLS forwarding, MPLS VPN/VPLS
MPLS VPN inter-AS option A/B/C
SSL VPN
Enabled by default; supporting access on the web page and iOS, macOS, Windows, and Android clients
Egress features
User management, ACE based on user groups, and rate limiting for individual users
Egress routing, ISP address library, Reverse Path Limited (RPL), domain name-based routing, and multi-link load balance (MLLB)
DNS proxy, reverse DNS proxy, and DNS redirect
Flow table-based attack prevention, single-user session limit, flow attack log, and flow table memory optimization
Configuration backup and one-click recovery
Flow log and URL log
Security zone
Security zone division based on the IP address
Security zone division based on the logical interface
Attack defense domain (global protection policies, protocol policies, and domain policies)
Security audit (attack defense domain log audit, security zone log audit, and management log audit)
URL filtering
Self-defined URL and URL logs
Automatic remote upgrade of URL library through HTTP
Local storage of logs and storage on external log servers (including NAT logs, flow logs, and URL logs)
Attack prevention
ARP attack prevention
LAN attack prevention and WAN attack prevention
Secure address binding
Port scan attack prevention
Segmentation packet attack prevention
ICMP flood attack prevention
Smurf attack prevention
Teardrop attack prevention
ICMP redirect attack prevention
ICMP unreachable attack prevention
Application Identification
Self-developed application identification function that can identify various application types, customizable application identification protocol
P2P applications
Streaming media software
Chat software
Game software
Internal enterprise applications
Content audit
Email content audit
IM audit
BBS forum content audit
Search engine audit
Wireless module (M7008L-WSM)
Default number of managed APs
0
Note: The default number of APs that can be managed by the M7008L-WSM is subject to the AP model. For details, see the Ordering Information.
Maximum number of managed APs
512
Note: The maximum number of APs that can be managed by the M7008L-WSM is subject to the AP model. For details, see the Ordering Information.
Intra-AC roaming handoff time
< 50 ms
IEEE 802.11 protocols
CAPWAP protocol
Roaming
AC-based user isolation
AP-based user isolation
WLAN-based user isolation
RSSI threshold for STA access
Wireless QoS
AP-based bandwidth limiting
WLAN-based bandwidth limiting
Fair scheduling
RF management
Coverage Hole Detection
Band selection
AP virtualization
EMB module
Device status query
Query device details, CPU/memory usage, interface status, temperature, power supply, fan, traffic, and bandwidth utilization
Network configuration
VLAN management, trunk management, port setting, aggregate port, port mirroring, port rate limiting, static routing, DHCP, DHCP snooping, STP loop guard, RLDP, and remote power supply management
Zero-configuration features
CPE WAN Management Protocol (CWMP)
Network management configurations
Syslog, Telnet, and SNMP
Diagnosis tools
Network detection and one-click information collection
Operations on devices
Upgrade, restart, configuration management, system time, log server, DNS server, system character set, and web console
Quick configuration
Quick configuration
Operation log
Log query, log type, and log management
Device upgrade
Device upgrade
Administrator account
Web administrator configuration
Data backup and recovery
Data backup download, data import and recovery
Hardware Specifications of M7008L-RCM
M7008L-RCM
Quad-core processor
BOOTROM
16 MB, and dual boot for active and standby chips
Flash Memory
4GB
SDRAM
4GB
External Port
1 x console port
1 x FUNC button
Hot Swapping
EMC Regulation
EN 55032: 2015+A1: 2020
EN 61000-3-3: 2013+A1: 2019+A2: 2021
EN IEC 61000-3-2: 2019+A1: 2021
EN 55035: 2017+A11: 2020
EN 300386 V2.2.1
BS EN 55035: 2017+A11: 2020
BS EN IEC 610000-3-2: 2019+A1: 2021
BS EN 61000-3-3: 2013+A1: 2019+A2: 2021
BS EN 55032: 2015+A1: 2020
Safety Regulation
BS EN 62368-1: 2014+A11: 2017
● Maximum operating altitude: 5000 m (16404.20 ft.)
● Maximum storage altitude: 5000 m (16404.20 ft.)
Operating Temperature
0°C to 45°C (32°F to 113°F) (0 m to 1800 m)
For the altitude in the range of 1800 m (5905.51 ft.) to 5000 m (16404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the operating temperature is decreased by 1°C (1.8°F).
Operating Humidity
Storage Temperature
-40°C to +70°C (-40°F to +158°F)
Storage Humidity
5% to 95% RH (non-condensing)
0.30 kg (0.66 lbs)
Without captive screws: 86 mm x 208 mm x 38 mm (3.39 in. x 8.19 in. x 1.50 in.)
With captive screws: 86 mm x 220 mm x 38 mm (3.39 in. x 8.66 in. x 1.50 in.)
Hardware Specifications of M7008L-WSM
M7008L-WSM
Quad-core processor
BOOTROM
Flash Memory
4GB
SDRAM
4GB
External Port
1 x console port
1 x FUNC button
Hot Swapping
EMC Regulation
EN 300386 V2.2.1
Safety Regulation
Operating Humidity
Storage Temperature
Storage Humidity
0.30 kg (0.66 lbs)
Hardware Specifications of M7000L-6XS
M7000L-6XS
Port Type
6 x SFP+ ports, supporting the 10G SFP+ module and 1G SFP module (there are slot limitations on the 1G SFP module)
Optical Module
SFP+ port
SFP modules and SFP BIDI modules
SFP+ modules, SFP+ cables, and SFP+ BIDI modules
LED
RDY, Link/ACT LED
EMC Standard
GB/T 9254.1
Hot Swapping
Operating Humidity
Storage Temperature
Storage Humidity
0.30 kg (0.66 lbs)
Without captive screws: 86 mm x 209 mm x 38 mm (3.39 in. x 8.23 in. x 1.50 in.)
Hardware Specifications of M7000L-8GT
M7000L-8GT
8 x 10/100/1000BASE-T RJ45 ports
Transmission Medium
10/100/1000BASE-T Category 5 UTP
LED
RDY function module status LED or 10/100/1000Base-T Ethernet port LED
Hot Swapping
EMC Regulation
EN 300386 V2.2.1
Safety Regulation
Operating Humidity
Storage Temperature
Storage Humidity
0.20 kg (0.44 lbs)
Without captive screws: 198 mm x 86 mm x 38 mm (7.80 in. x 3.39 in. x 1.50 in.)
With captive screws: 210 mm x 86 mm x 38 mm (8.27 in. x 3.39 in. x 1.50 in.)
Hardware Specifications of M7000L-8SFP
M7000L-8SFP
8 x SFP ports that support the 1G SFP module
Optical Module
LED
RDY function module status LED and SFP port LED
Hot Swapping
EMC Regulation
EN 300386 V2.2.1
Safety Regulation
Operating Humidity
Storage Temperature
Storage Humidity
0.25 kg (0.55 lbs)
Without captive screws: 199 mm x 86 mm x 38 mm (7.83 in. x 3.39 in. x 1.50 in.)
With captive screws: 210 mm 86 mm x 38 mm (8.27 in. x 3.39 in. x 1.50 in.)
RG-PA180I-F Power Module Specifications
RG-PA180I-F
Rated Voltage Range
110 V/220 V AC, 50 Hz to 60 Hz
Maximum Voltage Range
90 V AC to 290 V AC, 45 Hz to 65 Hz
Maximum Output Power
180 W
HVDC Parameters
192 V DC to 290 V DC, 2A Max., 180 W
0.45 kg (0.99 lbs)
Power Cord
10 A
Hardware Specifications of M7000L-HDD-1T
M7000L-HDD-1T
Hard Drive Type
Hard Disk Drive (HDD)
Capacity
1 TB
LED
DISK status LED
Hot Swapping
Not Supported
EMC Regulation
EN 300386 V2.2.1
Safety Regulation
For the altitude in the range of 1800 m (5905.51 ft.) to 5000 m (16404.20 ft.), every time the altitude increases by 200 m (656.17 ft.), the operating temperature is decreased by 1°C (1.8°F).
Operating Humidity
Storage Temperature
Storage Humidity
0.30 kg (0.66 lbs)
159 mm x 100.2 mm x 20.5 mm (6.30 in. x 3.94 in. x 0.81 in.)
RG-SG7008L
The RG-SG7008L chassis provides six common service card slots (slots 1--6), two multi-service card slots (slots 7--8), three built-in fixed fan modules, and two power module slots, common service cards, multi-service cards, and power modules support hot swapping and need to be purchased separately.
Multi-service Cards
M7008L-RCM
High-performance first-generation routing card of the RG-SG7008L
M7008L-WSM
High-performance first-generation wireless card of the RG-SG7008L
By default, no license is supported.
A generic AP consumes one license, while a wall-plate AP consumes 0.5 licenses. The number of licenses consumed by an i-Share AP is subject to the model. For details, see the Ordering Information in the datasheet of corresponding i-Share AP.
The M7008L-WSM can manage up to 512 devices in total, including generic APs, wall-plate APs, and micro APs.
Common Service Cards
M7000L-8GT
8 x GE Ethernet ports (RJ45)
M7000L-8SFP
8 x GE Optical ports (SFP and LC)
M7000L-6XS
6 x 10GE optical ports (SFP+ and LC)
Power Modules
RG-PA180I-F
Power module (AC, 180 W, 10 A)
