RG-CAP72-I Ruijie Cybrey Wi-Fi 7 BE3600 Ceiling Mount Access Point
BE3600 Wi-Fi 7 Speed
1 -
Provides low-latency performance for hotel lobbies, conference areas, open-plan offices, and warehouse sorting areas.
4096-QAM for Higher Peak Rates
2 -
Wi-Fi 7 with 4096‑QAM modulation delivers 20% higher peak data rates than Wi‑Fi 6.
3
MRU for Multi-User Performance
3 -
Multi‑Resource Unit improves channel utilization in crowded environments and reduces latency when many clients are connected.
2.5GE RJ45 + 2.5G SFP
4 -
Features two 2.5G ports — RJ45 for copper and SFP for fiber. The SFP port supports long-distance fiber connnection over hundreds of meters.
5
Enterprise Security
Enterprise Security
5 -
Enterprise Security
Supports GPSK-based dynamic VLAN assignment, WIDS/WIPS threat detection and prevention, WPA2/WPA3 encryption, plus physical security with a Kensington lock and securing latch.
6
Responsive Roaming Experience
6 -
The RG-CNC series coordinates APs to steer wireless clients to suitable access points for improved roaming performance.
7
Load Balancing
Load Balancing
7 -
Load Balancing
Balances clients across APs and steers them between 2.4 GHz and 5 GHz radios, enabling consistent performance in high-density areas.
Cloud-Edge Collaborative Wireless Network
8 -
Cloud AI provides global visibility and planning. The RG-CNC series executes decisions locally for real-time control. The RG-CAP series reports real-time data and enforces decisions onsite. Together, they enhance wireless experience across the network.
In the Box
RG-CAP72-I
× 1
Mounting bracket
× 1
ST4.2 x 25 mm Phillips tapping screws
× 4
φ6.3 x 25 mm plastic expansion anchors
× 4
Alignment sticker
× 1
Key to security lock slot
× 1
Mount It Steady. Keep It Clean. — Suspended Ceiling Mounting Accessories
- Ceiling Tile Mounting
- T-bar/Grid Mounting
Ceiling Backing Plate
Standard mounting has its limits — APs can loosen and become unstable over time.With a Ceiling Backing Plate, you can deploy heavy APs with rock-solid stability — built to last.
Ceiling Backing Plate sold separately — not included with the product.
T-bar Clip
Wall mounting spoils a clean ceiling. Grid mounting looks better.With a T-bar Clip, the AP mounts directly onto the ceiling grid for a secure, stable installation — while keeping the ceiling clean and tidy.
T-bar Clip sold separately — not included with the product.
Ruijie Cybrey Cloud-Edge Collaborative Wireless Network
Cybrey Cloud
AI Intelligence Brain: Analyzes the Wi-Fi environment and recommends optimization policies. AI Network Tools: AI Heatmap, AI HawkEye, AI Optimization, AI Diagnosis
RG-CNC Controller
Local Command Center: Makes local decisions and directs AP actions for on-site Wi-Fi optimization.
3
High-Performance Wireless APs
Frontline Soldiers: Execute RF and client actions and report field feedback.
3
