RG-AP7136-R Wireless - 1
RG-AP7136-R Wireless - 2
RG-AP7136-R Wireless - 3
RG-AP7136-R Wireless - 4
RG-AP7136-R Wireless - 5
RG-AP7136-R Wireless - 6
RG-AP7136-R, Wi-Fi 7 Quad-Radio Indoor Access Point
Ideal for scenarios including small and medium-sized offices, conference rooms, and classrooms.
  • Enterprise-class Wi-Fi 7 revolution, delivering a data rate of up to 9.335 Gbps
  • Seamless roaming with AI radio: continuous service guaranteed
  • 10G optical uplink supports Ruijie SOE Solution, enabling high-bandwidth connectivity and centralised management
  • WIS digital twin network for superior network O&M efficiency
RG-AP7136-R Wi-Fi 7 Quad-Radio Indoor AP
The RG-AP7136-R is ideal for scenarios including small and medium-sized offices, conference rooms, and classrooms. It supports versatile high-bandwidth applications and can be flexibly deployed to suit specific spatial layouts.
Delivering a Data Rate of Up to 9.335 Gbps
Empowering seamless high-bandwidth applications with next-generation wireless performance
Seamless Roaming with AI Radio: Service Continuity Guarantee
The built-in AI Radio independently scans and sends the STA status to the AC, which then steers STAs to quickly connect to the optimal AP based on neighboring AP scans. This ensures strong signals, minimal roaming latency, zero freezes, and nonstop services during roaming.
10G Optical Uplink Supports Ruijie SOE Solution, Enabling High-Bandwidth Connectivity and Centralised Management
The RG-AP7136-R, with a 10G optical uplink port, supports the all-optical architecture. When paired with the optical i-Share master AP and hybrid cable, it enables indoor long-haul data and power transmission with the distance of over 1,100 m (0.68 miles), delivering up to 10 Gbps indoor bandwidth. This AP also enables flat network architecture and elastic upgrades, while simplifying deployment and cabling to reduce costs.
Go to WIS Digital Twin Network>
RG-AP7136-R
Six spatial streams
● Radio 4 -- AI Radio, 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 4 -- AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
● Radio 4 -- AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
Four spatial streams
● Radio 4 -- AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 4 -- AI Radio, 5 GHz: 20 MHz and 40 MHz
● Radio 2 -- 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
● Radio 4 -- AI Radio, 5 GHz: AI Radio for scanning only
Eight spatial streams
● Radio 2 -- 5 GHz: 2x2 uplink/downlink MIMO, two spatial streams
● Radio 3 -- 6 GHz: 2x2 uplink/downlink MIMO, two spatial streams
● Radio 4 -- AI Radio, 2.4 GHz/5 GHz: 2x2 uplink/downlink MIMO, two spatial streams
Channels:
● Radio 3 -- 6 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
Combined peak data rate: 5.378Gbps
● Radio 1 -- 2.4 GHz: 7.3 Mbps to 0.574 Gbps (MCS0 to MCS11)
● Radio 3 -- 6 GHz: 7.3 Mbps to 2.402 Gbps (MCS0 to MCS11)
802.11be
Six spatial streams
Channels:
● Radio 3 -- 6 GHz: 20 MHz, 40 MHz, 80 MHz, 160MHz, and 320 MHz
Combined peak data rate: 9.335 Gbps:
● Radio 1 -- 2.4 GHz: 7.3 Mbps to 0.688 Gbps (MCS0 to MCS13)
● Radio 3 -- 6 GHz: 7.3 Mbps to 5.765 Gbps (MCS0 to MCS13)
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
● 5 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
● 6 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
● One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 3 dBi.
1 x 100/1000/2.5G/5GBASE-T port, shared with one 10GE SFP+ port
1 x 10GE SFP+ port, compatibility with 1GE/2.5GE/10GE modules, shared with one 5GE RJ45 port
1 x 10/100/1000BASE-T port, supplying IEEE 802.3af power to an IoT unit
1 x USB 2.0 (Type-A connector)
1 x Bluetooth 5.3
● AP power-on status
● Uplink service interface status
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Dimensions (W x H x D)
Main unit: 220 mm x 220 mm x 42.7 mm (8.66 in. x 8.66 in. x 1.68 in.)
Shipping: 495mm x 379mm x 261mm (19.49 in. x 14.92 in. x 10.28 in.)
Main unit: 1.2 kg (2.65 lbs.)
Shipping: 13.98 kg (30.82 lbs.)
Ceiling/Wall-mount (a mounting bracket is delivered with the main unit)
● 54 V DC/1.25 A power input over DC connector
● PoE/PoE+/PoE++ input, in compliance with IEEE 802.3af/at/bt standard
Maximum power consumption: 51 W
● DC power: 51 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (6 GHz) 2x2, Radio 4 (AI Radio) 2x2, LAN 1 for PoE power supply (48 V/12.95 W), USB port for external power supply (5 V/2.5 W)
● 802.3bt (PoE++): 51 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (6 GHz) 2x2, Radio 4 (AI Radio) 2x2, LAN 1 for PoE power supply (48 V/12.95 W), USB port for external power supply (5 V/2.5 W)
● 802.3at (PoE+): 25.5 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (6 GHz) 2x2, Radio 4 (AI Radio) is disabled, LAN 1 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
● 802.3af (PoE): 12.95 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) , Radio 3 (6 GHz) , Radio 4 (AI Radio) is disabled, LAN 1 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
● Idle mode: 12.2 W
External power supply
● The USB port can source 5 V/2.5 W power to an attached device.
● The LAN 1 port can source IEEE 802.3af power to an IoT unit.
Operating temperature: -10°C to +50°C (14°F to 122°F)
Note: At an altitude in the range of 3,000-5,000 m (9,842.52-16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
1024 MB DRAM, 256 MB flash
● Maximum transmit power: 23 dBm (199.53 mW)
● Minimum transmit power: 6 dBm (3.98 mW)
● Minimum transmit power: 6dBm (3.98 mW)
6 GHz
● Maximum transmit power: 22 dBm (158.49 mW)
● Adjusting the transmit power by percentage (recommended) and in 1dBm increments.
● The transmit power is limited by local regulatory requirements. For details, see [*WLAN Country or Region Codes and Channel Compliance*](http://www.ruijienetworks.com/support/documents/slide_wlan-country-codes-overview).
RG-AP7136-R
2.4 GHz 802.11g
-91 dBm
-85 dBm
-80 dBm
21 dBm
-74 dBm
2.4 GHz 802.11n (HT20)
-85 dBm
-67 dBm
2.4 GHz 802.11n (HT40)
-82 dBm
-64 dBm
2.4 GHz 802.11ax (HE20)
-85 dBm
17 dBm
-58 dBm
2.4 GHz 802.11ax (HE40)
23dBm
-82 dBm
17dBm
-54 dBm
2.4 GHz 802.11be(EHT20)
-85 dBm
MCS13
-52 dBm
2.4 GHz 802.11be (EHT40)
23dBm
-82 dBm
MCS13
16dBm
-49 dBm
5 GHz 802.11a
-91 dBm
-85 dBm
-80 dBm
21 dBm
-74 dBm
5 GHz 802.11n (HT20)
-85 dBm
-67 dBm
5 GHz 802.11n (HT40)
-82 dBm
-64 dBm
5 GHz 802.11ac (VHT20)
-85 dBm
-60 dBm
5 GHz 802.11ac (VHT40)
-82 dBm
-57 dBm
5 GHz 802.11ac (VHT80)
-82 dBm
-56 dBm
5 GHz, 802.11ac (VHT160)
--79 dBm
--53 dBm
5 GHz 802.11ax (HE20)
-85 dBm
17 dBm
-58dBm
5 GHz 802.11ax (HE40)
-82dBm
17 dBm
-54dBm
5 GHz 802.11ax (HE80)
-82 dBm
-56 dBm
17 dBm
-52dBm
5 GHz 802.11ax (HE160)
-79 dBm
-53 dBm
17 dBm
-50 dBm
5 GHz 802.11be (EHT80)
-82 dBm
-56 dBm
17 dBm
-52 dBm
MCS13
15 dBm
-46 dBm
5 GHz 802.11be (EHT160)
-79 dBm
-53 dBm
17 dBm
-50 dBm
MCS13
15 dBm
-44 dBm
6 GHz, 802.11ax (HE20)
--88 dBm
--58dBm
6 GHz, 802.11ax (HE40)
--85dBm
--55dBm
6 GHz, 802.11ax (HE80)
--82 dBm
--57 dBm
--52 dBm
6 GHz, 802.11ax (HE160)
--79 dBm
--54 dBm
--49 dBm
6 GHz, 802.11be (EHT20)
--88 dBm
--58dBm
6 GHz, 802.11be (EHT40)
--85dBm
--55dBm
6 GHz, 802.11be (EHT80)
--82 dBm
--57 dBm
--52 dBm
MCS13
--46 dBm
6 GHz, 802.11be (EHT160)
--79 dBm
--54 dBm
--49 dBm
MCS13
--43 dBm
6 GHz, 802.11be (EHT320)
--76 dBm
--51 dBm
--46 dBm
MCS13
--40 dBm
RG-AP7136-R
RGOS 11.9(6)W5B10 or later
768 (up to 256 STAs per radio)
100
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
PSK, PPSK, Web, 802.1X, WPA, WPA2, and WPA3 authentication
QR code-based guest authentication, SMS-based authentication, and MAC address bypass (MAB) authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP, GCMP), WPA3-OWE
Dynamic Policy
MAC address table size: 4,096
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1--4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarming
RG-AP7136-R
One-click diagnosis -- analyzing problems and providing suggestions
Baseline analysis -- recording the configuration, version, and other changes, and tracking network KPI changes
Time capsule -- analyzing the device version and configuration change history
Batch generation of building floor information -- uploading floor plans, and dragging and dropping AP positions
One-click health report -- generating a report on the overall operation of a network
Deployment through Zero Touch Provisioning (ZTP) -- creating configuration templates and automatically applying configured templates
Big data capabilities
Note:Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
Note:Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see [*Ruijie Default Protocols and Ports for Wireless Products*](https://www.ruijie.com/en-global/support/documents/slide_wlan-network-protocol-port/). Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
RG-AP7136-R
Wi-Fi 7 Quad-radio indoor access point
Up to eight spatial streams, peak data rate of 9.335 Gbps
  • Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO,peak data rate of 0.688 Gbps
  • Radio 2: 5 GHz: two spatial streams, 2x2 uplink/downlink MIMO, peak data rate of 2.882 Gbps
  • Radio 3: 6 GHz: two spatial streams, 2x2 uplink/downlink MIMO, peak data rate of 5.765 Gbps
  • Radio4 : AI Radio, 2.4 GHz/5 GHz: 2 spatialstreams, 2x2 MIMO, for scanning only
The AP consumes one license of an AC.
Fat/Fit/Cloud mode switching.
IEEE802.3af/at/bt-compliant (PoE/PoE+/PoE++) and DC power supply
  • The power source equipment (PSE) needs to be purchased separately.
  • The DC power supply needs to be purchased separately, and the output voltage/current must be 54 V/1.25 A.
SFP BIDI Transceiver-TX1550/RX1310, 20km, LC
2.5G-SFP-LX03-SM1550-BIDI
SFP 2.5G BIDI Transceiver-TX1550/RX1310, 3km, LC
SFP+ BIDI Transceiver-TX1330/RX1270, 10km, LC
