RG-PA550I-FC Small & Medium Enterprise Networking - 1
RG-PA550I-FC Small & Medium Enterprise Networking - 2
RG-PA550I-FC Small & Medium Enterprise Networking - 3
RG-PA550I-FC Small & Medium Enterprise Networking - 4
RG-PA550I-FC Small & Medium Enterprise Networking - 5
RG-PA550I-FC Small & Medium Enterprise Networking - 6
RG-PA550I-FC Small & Medium Enterprise Networking - 7
RG-PA550I-FC Small & Medium Enterprise Networking - 8
RG-PA550I-FC Small & Medium Enterprise Networking - 9
Model RG-PA150IB-FC RG-PA550I-FC RG-PA600I-P-FC RG-PA1000I-P-FC
Rated voltage range 100 V to 240 V 100 V to 240 V 100 V to 240 V 100 V to 240 V
Maximum voltage range 90 V to 264 V 90 V to 264 V 90 V to 264 V 90 V to 264 V
Maximum output power 150 W 550 W 600 W 100 VAC to 130 VAC: 930 W
200 VAC to 240 VAC: 1000 W
Input current 3 A 7.2 A 8 A 100 VAC to 130 VAC: 12 A
200 VAC to 240 VAC: 8 A
Output voltage 12 V 12 V 56 V 56 V
Maximum output current 12.5 A 45 A 10.72 A 100 V to 130 V: 16.61 A
200 V to 240 V: 17.86 A
Leakage current 3.5 mA 3.5 mA 3.5 mA 3.5 mA
Interface Specifications
LED 1 x Status LED 1 x Status LED 1 x Status LED 1 x Status LED
Dimensions (W x D x H) 196 mm x 50.5 mm x 40 mm
(7.72 in. x 1.99 in. x 1.57 in.)
185 mm x 73.5 mm x 39 mm
(7.28 in. x 2.89 in. x 1.54 in.)
196 mm x 90 mm x 40 mm
(7.72 in. x 3.54 in. x 1.57 in.)
Net weight 0.80 kg (1.76 lbs) 1.21 kg (2.67 lbs) 1.08 kg (2.38 lbs) 1.25 kg (2.76 lbs)
Shipping weight 3.75 kg (8.27 lbs) 2.94 kg (6.48 lbs) 2.56 kg (5.64 lbs) 2.9 kg (6.39 lbs)
Airflow direction Rear-to-front: Air intake from the connector and air outlet from the front panel
Operating temperature –10°C to +55°C (–14°F to +131°F) –10°C to +55°C (–14°F to +131°F) –10°C to +55°C (–14°F to +131°F) –10°C to +55°C (–14°F to +131°F)
Storage temperature –40ºC to +70ºC (–40°F to +158°F) –40ºC to +70ºC (–40°F to +158°F) –40ºC to +70ºC (–40°F to +158°F) –40ºC to +70ºC (–40°F to +158°F)
Operating humidity 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing)
Storage humidity 10% to 90% RH (non-condensing) 5% to 95% RH (non-condensing) 5% to 95% RH (non-condensing) 5% to 95% RH (non-condensing)
Operating altitude –500 m to +5000 m
(–1640.42 ft. to +16404.20 ft.)
–500 m to +5000 m
–500 m to +5000 m
–500 m to +5000 m
Power cord 10 A power cord 10 A power cord 10 A power cord 10 A power cord
Compliance and Certification
Compliance and certification CE CB CE CB CE CB CE CB
