RG-CAP73-I Small & Medium Enterprise Networking - 1
RG-CAP73-I Small & Medium Enterprise Networking - 2
RG-CAP73-I Small & Medium Enterprise Networking - 3
RG-CAP73-I Small & Medium Enterprise Networking - 4
RG-CAP73-I Small & Medium Enterprise Networking - 5
RG-CAP73-I Small & Medium Enterprise Networking - 6
RG-CAP73-I Small & Medium Enterprise Networking - 7
RG-CAP73-I Small & Medium Enterprise Networking - 8
RG-CAP73-I Small & Medium Enterprise Networking - 9
RG-CAP73-I Small & Medium Enterprise Networking - 10
RG-CAP73-I, Wi-Fi 7 BE9300 Ceiling Mount Access Point
  • BE9300 tri-band Wi-Fi 7 speed for hotel lobbies, open work areas, and high-density venues.
  • 4096-QAM for 20% higher peak data rates than Wi-Fi 6.
  • MRU for better channel utilization and lower latency in crowded environments.
  • 10G Combo + 2.5G port for high-capacity backhaul and wired connectivity.
  • Enterprise-grade security with GPSK, WIDS/WIPS, WPA2/WPA3, a Kensington lock slot, and a securing latch.
  • Full-time AI Radio mode with full-channel scanning for fast client steering.
  • Smart radio with 4 flexible modes (5 GHz, 6 GHz, high-density, AI Radio).
  • Load balancing across APs and between 2.4 GHz and 5 GHz radios.
Key Specifications
RG-CAP73-I Ruijie Cybrey Wi-Fi 7 BE9300 Ceiling Mount Access Point
    BE9300 Tri-Band Wi-Fi 7 Speed
    Provides high capacity for hotel lobbies, open work areas, and other high-density venues.
    4096-QAM for Higher Peak Rates
    Wi-Fi 7 with 4096‑QAM modulation delivers 20% higher peak data rates than Wi‑Fi 6.
  • 3
    MRU for Multi-User Performance
    3
    Multi‑Resource Unit improves channel utilization in crowded environments and reduces latency when many clients are connected.
    10G Combo + 2.5G Port
    Features one 10G RJ45/SFP+ combo port and a dedicated 2.5G port, delivering high-capacity backhaul and wired connectivity.
  • 5
    Enterprise Security
    Enterprise Security
    5
    Enterprise Security
    Supports GPSK-based dynamic VLAN assignment, WIDS/WIPS threat detection and prevention, WPA2/WPA3 encryption, plus physical security with a Kensington lock and securing latch.
  • 6
    Responsive Roaming Experience
    6
    The RG-CNC series coordinates APs to steer wireless clients to suitable access points for improved roaming performance.
  • 7
    Smart Radio with 4 Flexible Modes
    7
    The smart radio supports 5 GHz, 6 GHz, high-density, and AI radio modes, flexibly adapting to different scenarios.
  • 8
    Load Balancing
    Load Balancing
    Load Balancing
    Balances clients across APs and steers them between 2.4 GHz and 5 GHz radios, enabling consistent performance in high-density areas.
  • 9
    Cloud-Edge Collaborative Wireless Network
    9
    Cloud AI provides global visibility and planning. The RG-CNC series executes decisions locally for real-time control. The RG-CAP series reports real-time data and enforces decisions onsite. Together, they enhance wireless experience across the network.
Full-Time AI Radio for Responsive Roaming
AI Radio mode continuously monitors client status and intelligently steers clients to the suitable AP, enabling fast, low-latency roaming with smooth connectivity.
In the Box
  • RG-CAP73-I
    × 1
  • Mounting bracket
    × 1
  • ST4.2 x 25 mm Phillips tapping screws
    × 4
  • φ6.3 x 25 mm plastic expansion anchors
    × 4
  • Alignment sticker
    × 1
  • Key to security lock slot
    × 1
Mount It Steady. Keep It Clean. — Suspended Ceiling Mounting Accessories
  • Ceiling Tile Mounting
  • T-bar/Grid Mounting
Ceiling Backing Plate
Standard mounting has its limits — APs can loosen and become unstable over time.
With a Ceiling Backing Plate, you can deploy heavy APs with rock-solid stability — built to last.
Ceiling Backing Plate sold separately — not included with the product.
T-bar Clip
Wall mounting spoils a clean ceiling. Grid mounting looks better.
With a T-bar Clip, the AP mounts directly onto the ceiling grid for a secure, stable installation — while keeping the ceiling clean and tidy.
T-bar Clip sold separately — not included with the product.
Ruijie Cybrey Cloud-Edge Collaborative Wireless Network
    Cybrey Cloud
    AI Intelligence Brain: Analyzes the Wi-Fi environment and recommends optimization policies. AI Network Tools: AI Heatmap, AI HawkEye, AI Optimization, AI Diagnosis
    RG-CNC Controller
    Local Command Center: Makes local decisions and directs AP actions for on-site Wi-Fi optimization.
  • 3
    High-Performance Wireless APs
    Frontline Soldiers: Execute RF and client actions and report field feedback.
Wi-Fi standards
  • IEEE 802.11be (Wi-Fi 7), compatible with IEEE 802.11a/b/g/n/ac/ax
Wi-Fi standards (2.4 GHz)
  • IEEE 802.11b (Wi-Fi 1)
    IEEE 802.11g (Wi-Fi 3)
    IEEE 802.11n (Wi-Fi 4 )
    IEEE 802.11ax (Wi-Fi 6)
Wi-Fi standards (5 GHz)
  • IEEE 802.11a (Wi-Fi 2)
    IEEE 802.11ac (Wi-Fi 5)
Wi-Fi standards (6 GHz)
  • IEEE 802.11ax (Wi-Fi 6)
  • Mode 1: Tri-radio
    6 spatial streams
    ● Radio 1: 2.4 GHz, 2x2, MU-MIMO
    ● Radio 2: 5 GHz, 2x2, MU-MIMO
    ● Radio 3: 6 GHz, 2x2, MU-MIMO
    Mode 2: Tri-radio
    6 spatial streams
    ● Radio 2: 5 GHz (high band), 2x2, MU-MIMO
    ● Radio 3: 5 GHz (low band), 2x2, MU-MIMO
    Mode 3: Dual-radio
    6 spatial streams
    ● Radio 2: 5 GHz, 4x4, MU-MIMO
    Mode 4: Tri-radio
    6 spatial streams
    ● Radio 3 (AI radio): 5 GHz, 2x2, MU-MIMO
Data rates
  • Combined peak data rate: 9335 Mbps
    Mode 1:
    ● Radio 1: 2.4 GHz, 688 Mbps
    ● Radio 2: 5 GHz, 2882 Mbps
    ● Radio 3: 6 GHz, 5765 Mbps
    Mode 2:
    ● Radio 2: 5 GHz (high band), 2882 Mbps
    ● Radio 3: 5 GHz (low band), 2882 Mbps
    Mode 3:
    ● Radio 2: 5 GHz, 5765 Mbps
    Mode 4:
    ● Radio 3: 5 GHz, AI radio
Flexible radio
  • Mode 1: 2.4 GHz, 2x2 + 5 GHz, 2x2 + 6 GHz, 2x2
    Mode 2: 2.4 GHz, 2x2 + 5 GHz (high band), 2x2 + 5 GHz (low band), 2x2
    Mode 3: 2.4 GHz, 2x2 + 5 GHz, 4x4
    Mode 4: 2.4 GHz, 2x2 + 5 GHz, 2x2 + 5 GHz (AI radio), 2x2
Maximum transmit power
  • Frequency bands and maximum Effective Isotropic Radiated Power (EIRP):
    European Union & United Kingdom:
    2400–2483.5 MHz, EIRP ≤ 20 dBm
    5150–5350 MHz, EIRP ≤ 23 dBm
    5470–5725 MHz, EIRP ≤ 30 dBm
    5945–6425 MHz, EIRP ≤ 23 dBm
    Thailand:
    5725–5825 MHz, EIRP ≤ 30 dBm
    5945–6425 MHz, EIRP≤ 23 dBm
    Vietnam:
    2400–2483.5 MHz, EIRP ≤ 23 dBm
    5150–5350 MHZ, EIRP ≤ 23 dBm
    5725–5850 MHz, EIRP ≤ 30 dBm
Maximum transmit power (2.4 GHz)
  • Combined power: 26 dBm (single-stream power: 23 dBm)
Maximum transmit power (5 GHz)
Maximum transmit power (6 GHz)
  • Combined power: 24.5 dBm (single-stream power: 21.5 dBm)
  • 802.11b: BPSK, QPSK, CCK
    802.11a/g/n: BPSK, QPSK, 16-QAM, 64-QAM
    802.11be: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM
Operating frequency bands
  • Mode 1:
    ● Radio 1: 802.11b/g/n/ax/be, 2.400 GHz to 2.4835 GHz, EHT20/EHT40
    ● Radio 2: 802.11a/n/ac/ax/be, 5.150 GHz to 5.350 GHz, 5.470 GHz to 5.725 GHz, 5.725 GHz to 5.850 GHz, EHT20/EHT40/EHT80/EHT160
    ● Radio 3: 802.11ax/be, 5.925 GHz to 7.125 GHz, EHT20/EHT40/EHT80/EHT160/EHT320
    Mode 2:
    ● Radio 2: 802.11a/n/ac/ax/be, 5.470 GHz to 5.725 GHz, 5.725 GHz to 5.850 GHz, EHT20/EHT40/EHT80/EHT160
    ● Radio 3: 802.11a/n/ac/ax/be: 5.150 GHz to 5.350 GHz, EHT20/EHT40/EHT80/EHT160
    Mode 3:
    Mode 4:
    ● Radio 3: 802.11a/n/ac/ax/be, 5.150 GHz to 5.350 GHz, 5.470 GHz to 5.725 GHz, 5.725 GHz to 5.850 GHz, EHT20/EHT40/EHT80/EHT160
    Note: Country-specific restrictions apply. To use the preceding frequency bands, ensure that they are supported in your country or region.
Receive sensitivity
  • 802.11a: –91 dBm (6 Mbps), –85 dBm (24 Mbps), –72 dBm (54 Mbps)
    802.11b: –94 dBm (1 Mbps), –90 dBm (5.5 Mbps), –86 dBm (11 Mbps)
    802.11g: –91 dBm (6 Mbps), –85 dBm (24 Mbps), –80 dBm (36 Mbps), –74 dBm (54 Mbps)
    802.11n HT20: –88 dBm (MCS0), –70 dBm (MCS7)
    802.11n HT40: –85 dBm (MCS0), –67 dBm (MCS7)
    802.11ac VHT20: –88 dBm (MCS0), –65 dBm (MCS8)
    802.11ac VHT40: –85 dBm (MCS0), –60 dBm (MCS9)
    802.11ac VHT80: –82 dBm (MCS0), –57 dBm (MCS9)
    802.11ac VHT160: –79 dBm (MCS0), –54 dBm (MCS9)
    802.11ax HE20: –88 dBm (MCS0), –63 dBm (MCS9), –58 dBm (MCS11)
    802.11ax HE40: –85 dBm (MCS0), –60 dBm (MCS9), –55 dBm (MCS11)
    802.11ax HE80: –82 dBm (MCS0),–57 dBm (MCS9), –52 dBm (MCS11)
    802.11ax HE160: –79 dBm (MCS0), –54 dBm (MCS9), –49 dBm (MCS11)
    802.11be EHT20: –88 dBm (MCS0), –63 dBm (MCS9), –58 dBm (MCS11), –52 dBm (MCS13)
    802.11be EHT40: –85 dBm (MCS0), –60 dBm (MCS9), –55 dBm (MCS11), –49 dBm (MCS13)
    802.11be EHT80: –82 dBm (MCS0), –57 dBm (MCS9), –52 dBm (MCS11), –46 dBm (MCS13)
    802.11be EHT160: –79 dBm (MCS0), –54 dBm (MCS9), –49 dBm (MCS11), –43 dBm (MCS13)
    802.11be EHT320: –76 dBm (MCS0), –51 dBm (MCS9), –46 dBm (MCS11), –40 dBm (MCS13)
  • ● 2.4 GHz: 2 x built-in omnidirectional antennas
    ● 5 GHz: 2 x built-in omnidirectional antennas
    ● 6 GHz: 2 x built-in omnidirectional antennas (supporting both 5 GHz and 6 GHz bands)
    ● Bluetooth: 1 x built-in omnidirectional antenna
Antenna gain
  • 2.4 GHz: 5.2 dBi
    5 GHz: 6.3 dBi
    6 GHz: 5.8 dBi
    Bluetooth: 3.7 dBi
  • ● 1 x 10/100/1000/2.5G/5G/10GBASE-T port, supporting 802.3af/at/bt-compliant PoE input. It is paired with one 10GE SFP+ port as a combo port.
    ● 1 x 10GE SFP+ port, compatible with 2.5GE and 1GE optical transceivers. It is paired with one 10GE RJ45 port as a combo port.
    ● 1 x 10/100/1000/2500BASE-T port
  • 1 x RJ45 console port
LED
  • 1 x system LED
Reset button
Bluetooth Radio
  • Bluetooth 5.3
    ● Remote maintenance through a Bluetooth serial port
Maximum Bluetooth transmit power
  • 10 dBm
DC power supply
  • ● DC power adapter: 54 V, 0.7 A
    ● DC connector dimensions:
    Outer diameter: 5.5 mm (0.22 in.)
DC power input
  • Port restrictions: N/A
    Radio restrictions: N/A
    Other feature restrictions: N/A
PoE power supply
  • ● IEEE 802.3af (PoE)
    ● IEEE 802.3at (PoE+)
    ● IEEE 802.3bt (PoE++)
  • 24.7 W
IEEE 802.3af power input
  • Port restrictions: The downlink LAN port is unavailable.
    Radio restrictions: Only the 2.4 GHz and 5 GHz radios are available, with both radios limited to 1T1R and their transmit power limited to 50%.
IEEE 802.3at power input
IEEE 802.3bt power input
  • –10°C to +50°C (14°F to 122°F)
    Note: At altitudes ranging from 1,800 m (5,905.51 ft.) to 5,000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 220 m (721.78 ft.) increase in elevation.
  • 0% RH to 95% RH (non-condensing)
  • IP41
  • Kensington lock slot and securing latch
  • 400,000 hours
  • Ceiling-mount, wall-mount, and junction box-mount
  • 220 mm x 220 mm x 46.3 mm (8.66 in. x 8.66 in. x 1.82 in., without the mounting bracket)
Packaging dimensions (W x D x H)
  • 247.5 mm x 242 mm x 78 mm (9.74 in. x 9.53 in. x 3.07 in.)
  • Main unit: 1.20 kg (2.65 lbs)
    Mounting bracket: 0.12 kg (0.26 lbs)
Packaging weight
  • 1.53 kg (3.37 lbs)
  • 256 MB SPI NAND Flash
RAM
  • 1 GB DDR4
Certification and Regulatory Compliance
Certification
  • CE, CB, Wi-Fi Alliance
EMC compliance
  • EN 55032
    EN 301 489-3
    EN 301 489-17
Radio
  • EN 300 328
    EN 303 687
RF exposure
  • EN IEC 62311
Safety compliance
  • IEC 62368-1
Bandwidth Features
Bandwidth control
  • AP-based bandwidth control
    Client-based bandwidth control
    Intelligent dynamic bandwidth control based on channel utilization
    Intelligent dynamic bandwidth control based on critical services
    SSID-based bandwidth control
Client Management
Client limit
  • Radio-based client limit
    SSID-based client limit
Dynamic blocklist/allowlist
  • Dynamic blocklist
Smart steering
  • AP load balancing
    Configuring load balancing based on client count
    Configuring load balancing based on client traffic
Static blocklist/allowlist
  • Static allowlist
    Static blocklist
Radio Management
SSID management basics
  • SSID hiding
Roaming Features
Layer 2 roaming
  • Layer 2 roaming
Layer 3 roaming
  • Layer 3 roaming
Security Features
Client security
  • Hotspot2.0 authentication
    WPA-802.1X authentication
    WPA-PSK authentication
    WPA-WPA2 authentication
    WPA2-802.1X authentication
    WPA2-PSK authentication
    WPA2-WPA3 authentication
    WPA3-Enterprise
    WPA3-Enterprise (uses Suite-B 192-bit, GCMP-256)
    WPA3-Enterprise with AES-CCMP-128
    WPA3-OWE authentication
    WPA3-Personal
    WEP authentication
802.1X
  • Dynamic ACL assignment
Client identification
  • AI-based identification of client types, operating systems, operating system versions, vendors, and models
  • CPP
MAB
  • MAB
  • NFPP
RADIUS
  • RADIUS
  • Web authentication
Layer 3 Features
  • ICMPv6
    IPv6 basic features
    Neighbor discovery
    Ping over IPv6
NAT
  • NAT
    PPTP, SIP, FTP, DNS, and TFTP
Management Features
SNMP
  • SNMPv1/v2c/v3
    SNMP
Alerts
  • Alerts
Cloud-based management
  • Cloud-based management
SON
  • SON
SSH
  • SSH
Syslog
  • Syslog
Telnet
  • Telnet
Web-based management
  • Web-based management
IP Services
DHCP
  • DHCPv4 client
    DHCPv6 client
NTP
  • NTP client
    NTP server
Networking Features
RIPT
  • RIPT
Routing Features
IPv4 routing basics
  • Static routing
IPv6 routing basics
  • Static IPv6 routing
Device Management
AP mode management
  • Mode switching
Device IP management
  • Obtaining an IP address through DHCP
Device IP Management
  • Static IPv4 address
Multicast Features
IGMP snooping
  • Multicast-to-unicast conversion
Capacity Specifications
Client Management
Maximum number of associated clients per AP
  • 768
    Note: The number of associated clients varies according to the environment.
Recommended number of associated clients per AP
  • 100
Radio Management
Maximum number of BSSIDs per AP
  • 48
IP Services
Number of DHCP address pools
  • 2000
Package Contents
Device
Main unit
Accessories
Alignment sticker
Mounting bracket
  • 1 x mounting bracket (W x D x H: 130 mm x 143.5 mm x 6.5 mm / 5.12 in. x 5.65 in. x 0.26 in.)
Screw
  • 4 x ST4.2 x 25 mm Phillips tapping screws
    4 x φ6.3 x 25 mm plastic expansion anchors
Manual
User Manual
Warranty Card
Videos
How to Configure VAC on Ruijie Cybrey Devices?
Nov. 12, 2026
How to Maintain network connectivity for Ruijie Cybrey RG-CAP When AC Unreachable (V1.0)
Nov. 12, 2026
How to Configure Wired and Wireless Networks on the Cybrey Platform?
Oct. 29, 2026
How to Onboard Cybrey Devices through Cloud, eWeb, and App?
Oct. 29, 2026
How to Manage Third Party Devices on Cybrey Cloud?
Oct. 29, 2026
How to Integrate Microsoft Entra ID with SSE for Portal and 802.1X Authentication?
Oct. 29, 2026
Views
