RG-CNC105 Small & Medium Enterprise Networking - 1
RG-CNC105 Small & Medium Enterprise Networking - 2
RG-CNC105 Small & Medium Enterprise Networking - 3
RG-CNC105 Small & Medium Enterprise Networking - 4
RG-CNC105 Small & Medium Enterprise Networking - 5
RG-CNC105 Small & Medium Enterprise Networking - 6
RG-CNC105 Small & Medium Enterprise Networking - 7
RG-CNC105 Small & Medium Enterprise Networking - 8
RG-CNC105 Small & Medium Enterprise Networking - 9
RG-CNC105, Routing · Wireless Control · PoE Switching · Authentication, 4-in-1 Edge Controller
  • 4-in-1 edge controller integrating a router, a wireless controller, a 2.5G PoE switch, and an authentication server.
  • Four 2.5G PoE ports with up to 120 W output for direct AP powering.
  • Multi-vendor management for rapid fault localization in complex networks.
  • Built-in portal and 802.1X authentication using RADIUS, with support for TACACS+ and third-party integration.
  • AP load balancing to avoid overload and ensure steady performance in high-density areas.
  • Continued local authentication and roaming during WAN outages.
Key Specifications
RG-CNC105 4-in-1 Edge Controller
Branch Office Networking — Routing · Wireless Control · PoE Switching · Authentication, 4-in-1
    Integrates an edge router, wireless controller, 2.5G PoE switch, and authentication server.
    2.5G PoE Ports
    2.5G PoE Ports
    2.5G PoE Ports
    Features four 2.5G PoE Out ports with up to 120 W output, powering APs directly without extra switches or adapters.
  • 3
    Multi‑Vendor Management
    3
    Collects and manages multi‑vendor device information, and serves as the central hub for rapid fault localization in complex networks.
    Unified Authentication
    Featuring a built‑in portal and 802.1X authentication server, the RG-CNC series supports RADIUS, TACACS+, and integration with Cisco ISE and Aruba ClearPass.
  • 5
    Load Balancing
    Load Balancing
    5
    Load Balancing
    The RG-CNC series monitors AP loads and distributes clients across neighboring APs. This helps avoid overload and enables steady performance in high-density areas.
  • 6
    Responsive Roaming Experience
    6
    The RG-CNC series coordinates APs to steer wireless clients to suitable access points for improved roaming performance.
  • 7
    WAN Outage Resilience
    7
    Supports continued local authentication and roaming when Internet connectivity fails.
  • 8
    Cloud-Edge Collaborative Wireless Network
    Cloud AI provides global visibility and planning. The RG-CNC series executes decisions locally for real-time control. The RG-CAP series reports real-time data and enforces decisions onsite. Together, they enhance wireless experience across the network.
In the Box
  • RG-CNC105
    × 1
  • Power adapter
    × 1
  • Power cord
    × 1
  • Rack-mount bracket
    × 2
  • M3 x 6 mm Phillips countersunk head machine screws
    × 6
  • Rubber pad
    × 1
Ruijie Cybrey Cloud-Edge Collaborative Wireless Network
    Cybrey Cloud
    AI Intelligence Brain: Analyzes the Wi-Fi environment and recommends optimization policies. AI Network Tools: AI Heatmap, AI HawkEye, AI Optimization, AI Diagnosis
    RG-CNC Controller
    Local Command Center: Makes local decisions and directs AP actions for on-site Wi-Fi optimization.
  • 3
    High-Performance Wireless APs
    Frontline Soldiers: Execute RF and client actions and report field feedback.
  • 5 x 10/100/1000/2.5GBASE-T ports, with ports 2–5 supporting IEEE 802.3af/at-compliant PoE output.
  • 1 x RJ45 console port
LED
  • 1 x system LED
    5 x port LEDs
    4 x PoE LEDs
    1 x power LED
Reset button
  • 202 mm x 108 mm x 28 mm (7.95 in. x 4.25 in. x 1.10 in., without rack-mount brackets)
Packaging dimensions (W x D x H)
  • 214 mm x 197 mm x 67 mm (8.43 in. x 7.76 in. x 2.64 in.)
  • 1 RU
  • 0.63 kg (1.39 lbs)
Packaging weight
  • 1.49 kg (3.28 lbs)
  • Gray
  • 512 MB
RAM
  • 1 GB DDR4
  • DC adapter input:
    ● Rated input voltage: 100 V AC to 240 V AC, 50 Hz or 60 Hz
    ● Rated input current: 2.0 A
    DC adapter output:
    ● Rated output voltage: 54 V DC
    ● Maximum output current: 2.5 A
Power output
  • Supported
    ● The Ethernet port provides 54 V/30 W power output.
    ● The USB port provides 5 V/0.5 A power output.
DC power supply
  • DC power adapter
  • 132 W
  • 120 W
  • Operating altitude: –500 m to +4,000 m (–1,640.42 ft. to +13,123.36 ft.)
  • Desktop placement, rack-mount, and wall-mount
  • 400,000 hours
  • 10% RH to 90% RH (non-condensing)
  • 0°C to 45°C (32°F to 113°F)
    Note: At altitudes ranging from 3,000 m (9,842.52 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 220 m (721.78 ft.) increase in elevation.
Certification and Regulatory Compliance
Certification
  • CE, CB
EMC compliance
  • EN 55032
    EN 300386
Safety compliance
  • IEC 62368-1
Bandwidth Features
Bandwidth control
  • AP-based bandwidth control
    Client-based bandwidth control
    Intelligent dynamic bandwidth control based on channel utilization
    Intelligent dynamic bandwidth control based on critical services
    SSID-based bandwidth control
Client Management
Client limit
  • Radio-based client limit
    SSID-based client limit
Dynamic blocklist/allowlist
  • Dynamic blocklist
Smart steering
  • AP load balancing
    Configuring load balancing based on client count
    Configuring load balancing based on client traffic
Static blocklist/allowlist
  • Static allowlist
    Static blocklist
Radio Management
SSID management basics
  • SSID hiding
Roaming Features
Layer 2 roaming
  • Layer 2 roaming
    Inter-AC Layer 2 roaming
    Intra-AC Layer 2 roaming
Layer 3 roaming
  • Layer 3 roaming
    Inter-AC Layer 3 roaming
    Intra-AC Layer 3 roaming
Security Features
Client security
  • Hotspot2.0 authentication
    WPA-802.1X authentication
    WPA-PSK authentication
    WPA-WPA2 authentication
    WPA2-802.1X authentication
    WPA2-PSK authentication
    WPA2-WPA3 authentication
    WPA3-Enterprise
    WPA3-Enterprise (uses Suite-B 192-bit, GCMP-256)
    WPA3-Enterprise with AES-CCMP-128
    WPA3-OWE authentication
    WPA3-Personal
    WEP authentication
802.1X
  • Dynamic ACL assignment
Client identification
  • Client identification
  • CPP
MAB
  • MAB
  • NFPP
RADIUS
  • RADIUS
  • Web authentication
    Captive portal
RF security
  • WIDS
    AC-based client isolation
    AP-based client isolation
Layer 3 Features
  • ICMPv6
    IPv6 basic features
    Neighbor discovery
    Ping over IPv6
NAT
  • NAT
Management Features
SNMP
  • SNMPv1/v2c/v3
    SNMP
Alerts
  • Alerts
Cloud-based management
  • Cloud-based management
SON
  • SON
SSH
  • SSH
Syslog
  • Syslog
Telnet
  • Telnet
Web-based management
  • Web-based management
IP Services
DHCP
  • DHCPv4 client
NTP
  • NTP client
    NTP server
Routing Features
IPv4 routing basics
  • Static routing
IPv6 routing basics
  • Static IPv6 routing
VPN Features
  • IPsec VPN
  • PPPoE client
Application Protocol Features
TFTP
  • TFTP
Device Management
Device IP management
  • Obtaining an IP address through DHCP
Device IP Management
  • Static IPv4 address
Multicast Features
IGMP snooping
  • Multicast-to-unicast conversion
Centralized Management
Forwarding mode
  • Local forwarding
    Centralized forwarding
Capacity Specifications
VPN Features
Number of IPsec tunnels
  • 100
Layer 2 Features
Maximum number of created VLANs
  • 4094
Layer 3 Features
Maximum number of ARP entries
  • 3000
Software ACE capacity
  • 4096
Client Management
Maximum number of managed clients per AC
  • 500
Number of configurable APs
  • 256
Number of pre-installed AP licenses per AC
  • 32
Maximum number of connected APs
  • 64
Maximum number of managed online APs
  • 32
Number of managed CAPWAP tunnels
  • 64
IP Services
Number of DHCP address pools
  • 2000
Security Features
Number of 802.1X authenticated clients
  • 64
Number of portal authenticated clients
  • 64
Cloud-based Management of Third-Party Devices
Number of third-party devices
  • 16
Package Contents
Device
Main unit
Accessories
Power adapter
Power cord
Rack-mount bracket
  • 2 x rack-mount brackets (W x D x H: 140 mm x 30 mm x 43 mm / 5.51 in. x 1.18 in. x 1.69 in.)
Rubber pad
Screw
  • 6 x M3 x 6 mm Phillips countersunk head machine screws
Manual
User Manual
Warranty Card
Videos
How to Configure Wired and Wireless Networks on the Cybrey Platform?
Oct. 29, 2026
How to Onboard Cybrey Devices through Cloud, eWeb, and App?
Oct. 29, 2026
How to Manage Third Party Devices on Cybrey Cloud?
Oct. 29, 2026
How to Integrate Microsoft Entra ID with SSE for Portal and 802.1X Authentication?
Oct. 29, 2026
Views
