RG-SAP845-SP Wireless - 1
RG-SAP845-SP Wireless - 2
RG-SAP845-SP Wireless - 3
RG-SAP845-SP Wireless - 4
RG-SAP845-SP Wireless - 5
RG-SAP845-SP Wireless - 6
RG-SAP845-SP Wireless - 7
RG-SAP845-SP Wireless - 8
RG-SAP845-SP Wireless - 9
RG-SAP845-SP Wireless - 10
RG-SAP845-SP, Wi-Fi 6 Dual-Radio 5.378 Gbps High-Density Enhanced Indoor Access Point
Indoor high-density network scenarios in the higher education, medical industry, government and commerce
  • 5 Gbps combo port for flexible networking
  • Upgraded to Wi-Fi 6, high-speed access at 5.378 Gbps
WaaS Series High-Density Wi-Fi 6 Indoor Access Point
RG-SAP845-SP
5 Gbps Optical Port
PoE/DC Power Supply
Bluetooth 5.1
Ceiling/Wall-Mount
WIS Cloud Management
5 Gbps Optical Port and 5 Gbps Electrical Port, Flexible Networking
The 5 Gbps optical port is designed for Ruijie All-Optical i-Share+ Solution, unleashing the bandwidth performance to achieve ultra-gigabit access. Moreover, one 5 Gbps electrical port is provided for wired connection, satisfying networking requirements.
Upgraded to Wi-Fi 6, Up to 5.378 Gbps Data Rate
5.378
Gbps
High Concurrency
OFDMA and MU-MIMO technologies, ensuring stable connections for multiple clients
Low Latency
OFDMA technology, reducing latency to 20 ms when data is transmitted to multiple clients
High Security
High Speed
1024-QAM, 25% higher transmission rate than 802.11ac
160 MHz Channel Width and Six Spatial Streams,
Superior User Experience
Compared with 80 MHz channel width, 160 MHz channel width increases the data throughput per unit of time.
Dual-radio design and six spatial streams enable robust capabilities for data transmission and reception.
WIS Cloud enables network-wide configuration and optimization, eliminating the need for on-site operations.
Network issue warnings allow wireless networks to be monitored anytime and anywhere.
Go to WIS ->
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
RG-SAP845-SP
Six spatial streams
Channels:
Combined peak data rate: 900 Mbps
Four spatial streams
Channels:
Six spatial streams
● Radio 2 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channels:
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.9 dBi.
● 5 GHz: four built-in omnidirectional antennas, with peak antenna gain of 6.2 dBi.
1 x 10/100/1000BASE-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Shipping: 284 mm x 262 mm x 124 mm (11.18 in. x 10.31 in. x 4.89 in.)
Main unit: 1.0 kg (2.20 lbs)
Shipping: 1.25 kg (2.76 lbs)
● DC power: 40 W, 2.4 GHz radio 2x2, 5 GHz radio 4x4, LAN 2 for PoE supply, and USB port enabled
● 802.3bt (PoE++): 40 W, 2.4 GHz radio 2x2, 5 GHz radio 4x4, LAN 2 for PoE supply, and USB port enabled
● 802.3at (PoE+): 22 W, 2.4 GHz radio 2x2, 5 GHz radio 4x4, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● 802.3af (PoE): 12.95 W, 2.4 GHz radio 1x1, 5 GHz radio 1x1, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● Idle mode: 10.3 W
External power
supply
512 MB DRAM, 128 MB flash
● Maximum transmit power: 27 dBm (501.19 mW)
● Maximum transmit power: 29 dBm (794.33 mW)
RG-SAP845-SP
24 dBm
–96 dBm
24 dBm
–95 dBm
–93 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–62 dBm
24 dBm
–88 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–68 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–63 dBm
24 dBm
24 dBm
–90 dBm
24 dBm
–86 dBm
–56 dBm
–83 dBm
5 GHz, 802.11ax (HE160)
–81 dBm
–51 dBm
 Note Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
Basic Functions
RG-SAP845-SP
RGOS11.9(6)W3B3 or later
160
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
PSK and web authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP, GCMP)
MAC address table size: 2,048
Maximum number of static MAC addresses: 2,048
Maximum number of filtered MAC addresses: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
Maximum number of ARP entries: 2,048
NAT, FTP ALG and DNS ALG
Maximum number of static IPv6 routes: 1,000
NTP server and NTP client
RG-SAP845-SP
Big data capabilities
RG-SAP845-SP
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-SAP845-SP] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-SAP845-SP] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
RG-SAP845-SP
Dual radios, six spatial streams, peak data rate of 5.378 Gbps
● Radio 2: 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
802.11a/b/g/n/ac/ax, switching between Fat, Fit, and cloud modes, and 802.3at/bt PoE and local DC power supply
1000BASE-SX mini-GBIC module
1000BASE-LX mini-GBIC module
