RG-CNC312 High‑Performance 20 Gbps Access Controller for Campus and Multi‑Site Networks
High‑Capacity for Large‑Scale Deployments
1 -
Manages up to 512 APs and up to 3,500 clients. Centralized control for complex networks.
20 Gbps Forwarding Performance
2 -
20 Gbps throughput helps mitigate congestion for bandwidth-hungry applications.
3
Multi‑Vendor Management
3 -
Collects and manages multi‑vendor device info. Central hub for rapid fault localization in complex networks.
Unified Authentication
4 -
Featuring a built‑in portal and 802.1X authentication server, the RG-CNC series supports RADIUS, TACACS+, and integration with Cisco ISE and Aruba ClearPass.
5
Load Balancing
Load Balancing
5 -
Load Balancing
The RG-CNC series monitors AP loads and distributes clients across neighboring APs. This helps avoid overload and enables steady performance in high-density areas.
6
Responsive Roaming Experience
6 -
The RG-CNC series coordinates APs to steer wireless clients to suitable access points for improved roaming performance.
7
WAN Outage Resilience
7 -
Supports continued local authentication and roaming when Internet connectivity fails.
Cloud-Edge Collaborative Wireless Network
8 -
Cloud AI provides global visibility and planning. The RG-CNC series executes decisions locally for real-time control. The RG-CAP series reports real-time data and enforces decisions onsite. Together, they enhance wireless experience across the network.
In the Box
RG-CNC312
× 1
Power cord
× 1
Console cable
× 1
Grounding wire
× 1
Rack-mount bracket
× 2
Rubber pad
× 1
Power cord retention clip
× 1
Cable tie
× 1
M4 x 8 mm Phillips countersunk head screws
× 6
Ruijie Cybrey Cloud-Edge Collaborative Wireless Network
Cybrey Cloud
AI Intelligence Brain: Analyzes the Wi-Fi environment and recommends optimization policies. AI Network Tools: AI Heatmap, AI HawkEye, AI Optimization, AI Diagnosis
RG-CNC Controller
Local Command Center: Makes local decisions and directs AP actions for on-site Wi-Fi optimization.
3
High-Performance Wireless APs
Frontline Soldiers: Execute RF and client actions and report field feedback.
3
