RG-CAP72-O Small & Medium Enterprise Networking - 1
RG-CAP72-O Small & Medium Enterprise Networking - 2
RG-CAP72-O Small & Medium Enterprise Networking - 3
RG-CAP72-O Small & Medium Enterprise Networking - 4
RG-CAP72-O Small & Medium Enterprise Networking - 5
RG-CAP72-O Small & Medium Enterprise Networking - 6
RG-CAP72-O, Wi-Fi 7 BE3600 Outdoor Access Point
  • BE3600 Wi-Fi 7 speed for hotel beach resorts, industrial parks, and logistics yards.
  • 4096-QAM for 20% higher peak data rates than Wi-Fi 6.
  • MRU for better channel utilization and lower latency in crowded environments.
  • Dual 2.5G ports (RJ45 + SFP) with fiber support for long-distance deployment
  • Built-in antennas and support for external directional antennas to expand coverage.
  • Flexible power supply options: PoE, DC, and Power over Fiber (PoF).
  • IP68-rated dust and water protection with F2-grade UV-resistant materials.
  • Built-in 6 kV surge protection for reliable outdoor operation.
  • Enterprise-grade security with GPSK, WIDS/WIPS, WPA2/WPA3 encryption, and a Kensington lock slot.
Key Specifications
RG-CAP72-O Ruijie Cybrey Wi-Fi 7 BE3600 Outdoor Access Point
    BE3600 Wi‑Fi 7 Speed
    Provides low-latency connectivity for hotel beach resorts, large industrial parks, and logistics yards.
    4096‑QAM for Higher Peak Rates
    Features two 2.5G ports — RJ45 for copper and SFP for fiber. The SFP port supports long-distance fiber connnection over several kilometers.
  • 3
    MRU for Multi‑User Performance
    3
    MRU for Multi‑User Performance Multi‑Resource Unit improves channel utilization in crowded environments and reduces latency when many clients are connected.
    2.5GE RJ45 + 2.5G SFP
  • 5
    Flexible Antenna Options
    5
    Features built-in antennas for standard coverage, with external antenna support for directional long-distance coverage. This expands coverage and reduces deployment costs.
  • 6
    Flexible Power Supply Options
    6
    Supports PoE, DC, and Power over Fiber (PoF), enabling flexible device deployment.
  • 7
    Dust & Water Resistance
    7
    Provides IP68-rated dust and water protection, and features F2-grade UV-resistant materials.
  • 8
    Outdoor Surge Protection
    Built-in 6 kV surge protection enables reliable operation in harsh outdoor conditions.
  • 9
    Enterprise Security
    Enterprise Security
    9
    Enterprise Security
    Supports GPSK-based dynamic VLAN assignment, WIDS/WIPS threat detection and prevention, WPA2/WPA3 encryption, plus physical security with a Kensington lock.
  • 10
    Responsive Roaming Experience
    10
    The RG-CNC series coordinates APs to steer wireless clients to suitable access points for improved roaming performance.
  • 11
    Cloud-Edge Collaborative Wireless Network
    11
    Cloud AI provides global visibility and planning. The RG-CNC series executes decisions locally for real-time control. The RG-CAP series reports real-time data and enforces decisions onsite. Together, they enhance wireless experience across the network.
In the Box
  • RG-CAP72-O
    × 1
  • Adjustable mounting bracket
    × 1
  • M8 x 60 mm Expansion anchors
    × 2
  • M5 x 10 mm Dacromet-coated screws
    × 4
  • Cable gland assemblies for Ethernet cable and DC power cord
    × 2
  • Cable gland assemblies for optical fiber and hybrid cable
    × 2
  • Hose clamp
    × 2
  • 2 m (6.56 ft.) Grounding wire
    × 1
  • Terminal block
    × 1
Ruijie Cybrey Cloud-Edge Collaborative Wireless Network
    Cybrey Cloud
    AI Intelligence Brain: Analyzes the Wi-Fi environment and recommends optimization policies. AI Network Tools: AI Heatmap, AI HawkEye, AI Optimization, AI Diagnosis
    RG-CNC Controller
    Local Command Center: Makes local decisions and directs AP actions for on-site Wi-Fi optimization.
  • 3
    High-Performance Wireless APs
    Frontline Soldiers: Execute RF and client actions and report field feedback.
Wi-Fi standards
  • IEEE 802.11be (Wi-Fi 7), compatible with IEEE 802.11a/b/g/n/ac/ax
Wi-Fi standards (2.4 GHz)
  • IEEE 802.11b (Wi-Fi 1)
    IEEE 802.11g (Wi-Fi 3)
    IEEE 802.11n (Wi-Fi 4 )
    IEEE 802.11ax (Wi-Fi 6)
Wi-Fi standards (5 GHz)
  • IEEE 802.11a (Wi-Fi 2)
    IEEE 802.11ac (Wi-Fi 5)
    ● Radio 1: 2.4 GHz, 2x2, MU-MIMO
    ● Radio 2: 5 GHz, 2x2, MU-MIMO
Data rates
  • Combined peak data rate: 3570 Mbps
    ● Radio 1: 2.4 GHz, 688 Mbps
    ● Radio 2: 5 GHz, 2882 Mbps
External antenna connectors
  • 2 RP-SMA female antenna connectors
    ● ANT1 (2.4G&5G) and ANT2 (2.4G&5G) correspond to Radio 1 and Radio 2, respectively.
Maximum transmit power
  • Frequency bands and maximum Effective Isotropic Radiated Power (EIRP):
    European Union & United Kingdom:
    2400–2483.5 MHz, EIRP ≤ 20 dBm
    5470–5725 MHz, EIRP ≤ 30 dBm
    Myanmar:
    2400–2483.5 MHz, EIRP ≤ 23 dBm
    5725–5825 MHz, EIRP ≤ 30 dBm
    Thailand:
    Indonesia:
    2400–2483.5 MHz, EIRP ≤ 36 dBm
    5725–5825 MHz, EIRP ≤ 36 dBm
    Egypt:
    5150–5350 MHz, EIRP ≤ 23 dBm
    Vietnam:
    5725–5850 MHz, EIRP ≤ 30 dBm
Maximum transmit power (2.4 GHz)
  • Combined power: 28 dBm (single-stream power: 25 dBm)
Maximum transmit power (5 GHz)
  • 802.11b: BPSK, QPSK, CCK
    802.11a/g/n: BPSK, QPSK, 16-QAM, 64-QAM
    802.11be: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM
Operating frequency bands
  • ● Radio 1: 802.11b/g/n/ax/be, 2.400 GHz to 2.4835 GHz, EHT20/EHT40
    ● Radio 2: 802.11a/n/ac/ax/be, 5.150 GHz to 5.350 GHz, 5.470 GHz to 5.725 GHz, 5.725 GHz to 5.850 GHz, EHT20/EHT40/EHT80/EHT160
    Note: Country-specific restrictions apply. To use the preceding frequency bands, ensure that they are supported in your country or region.
Receive sensitivity
  • 802.11a: –91 dBm (6 Mbps), –85 dBm (24 Mbps), –74 dBm (54 Mbps)
    802.11b: –96 dBm (1 Mbps), –93 dBm (5.5 Mbps), –89 dBm (11 Mbps)
    802.11g: –91 dBm (6 Mbps), –85 dBm (24 Mbps), –80 dBm (36 Mbps), –74 dBm (54 Mbps)
    802.11n HT20: –88 dBm (MCS0), –70 dBm (MCS7)
    802.11n HT40: –85 dBm (MCS0), –67 dBm (MCS7)
    802.11ac VHT20: –88 dBm (MCS0), –65 dBm (MCS8)
    802.11ac VHT40: –85 dBm (MCS0), –60 dBm (MCS9)
    802.11ac VHT80: –82 dBm (MCS0), –57 dBm (MCS9)
    802.11ac VHT160: –79 dBm (MCS0), –54 dBm (MCS9)
    802.11ax HE20: –88 dBm (MCS0), –63 dBm (MCS9), –58 dBm (MCS11)
    802.11ax HE40: –85 dBm (MCS0), –60 dBm (MCS9), –55 dBm (MCS11)
    802.11ax HE80: –82 dBm (MCS0),–57 dBm (MCS9), –52 dBm (MCS11)
    802.11ax HE160: –79 dBm (MCS0), –54 dBm (MCS9), –49 dBm (MCS11)
    802.11be EHT20: –88 dBm (MCS0), –63 dBm (MCS9), –58 dBm (MCS11), –52 dBm (MCS13)
    802.11be EHT40: –85 dBm (MCS0), –60 dBm (MCS9), –55 dBm (MCS11), –49 dBm (MCS13)
    802.11be EHT80: –82 dBm (MCS0), –57 dBm (MCS9), –52 dBm (MCS11), –46 dBm (MCS13)
    802.11be EHT160: –79 dBm (MCS0), –54 dBm (MCS9), –49 dBm (MCS11), –43 dBm (MCS13)
  • ● 2.4 GHz: 2 x built-in omnidirectional antennas, switching between built-in and external antennas
    ● 5 GHz: 2 x built-in omnidirectional antennas, switching between built-in and external antennas
    Note: When external antennas are used, the access point uses two external RP-SMA female antenna connectors. The external antenna connectors are labeled ANT1(2.4G&5G) and ANT2(2.4G&5G).
    ● Bluetooth: 1 x built-in omnidirectional antenna
Antenna gain
  • 2.4 GHz: 2.60 dBi
    5 GHz: 3.10 dBi
    Bluetooth: 1.90 dBi
  • ● 1 x 10/100/1000/2.5GBASE-T port, supporting IEEE 802.3af/at-compliant PoE input
    ● 1 x 2.5GE SFP port, compatible with 1GE optical transceiver
  • 1 x RJ45 console port
LED
  • 1 x system LED
    1 x RSSI LED
Reset button
Bluetooth Radio
  • Bluetooth 5.3
    ● Remote maintenance through a Bluetooth serial port
Maximum Bluetooth transmit power
  • 10 dBm
DC power supply
  • ● DC power adapter: 54 V, 0.6 A
    ● DC connector dimensions:
    Outer diameter: 5.5 mm (0.22 in.)
DC power input
  • Port restrictions: N/A
    Radio restrictions: N/A
    Other feature restrictions: N/A
PoE power supply
  • ● IEEE 802.3af (PoE)
    ● IEEE 802.3at (PoE+)
PoF power supply
    1. If both DC power and PoE are available, DC power is preferred.
    2. If PoF input is adopted, the AP must be used with a dedicated PSE.
  • 18 W
IEEE 802.3af power input
  • Port restrictions: The 2.5GE SFP port is unavailable.
    Radio restrictions: The transmit power of both 2.4 GHz and 5 GHz radios is limited to 60%, and their data rates are limited to 50%.
IEEE 802.3at power input
    Note: At altitudes ranging from 1,800 m (5,905.51 ft.) to 5,000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 220 m (721.78 ft.) increase in elevation.
  • 0% RH to 100% RH (non-condensing)
  • –40°C to +85°C (–40°F to +185°F)
Corrosion resistance
  • IEC 62368-1
    IEC 60950-22
  • IP68
  • Kensington lock slot
  • 400,000 hours
  • Wall-mount and pole-mount
  • 248 mm x 78 mm x 163 mm (9.76 in. x 3.07 in. x 6.42 in., without the mounting bracket)
Packaging dimensions (W x D x H)
  • 346 mm x 311 mm x 143 mm (13.62 in. x 12.24 in. x 5.63 in.)
  • Main unit: 1.4 kg (3.09 lbs)
    Mounting bracket: 1.35 kg (2.98 lbs)
Packaging weight
  • 3.3 kg (7.28 lbs)
  • 256 MB SPI NAND Flash
RAM
  • 1 GB DDR4
Certification and Regulatory Compliance
Certification
  • CE, CB, Wi-Fi Alliance
EMC compliance
  • EN 55032
    EN 301 489-3
    EN 301 489-17
Radio
  • EN 300 328
RF exposure
  • EN IEC 62311
Safety compliance
  • IEC 62368-1
Bandwidth Features
Bandwidth control
  • AP-based bandwidth control
    Client-based bandwidth control
    Intelligent dynamic bandwidth control based on channel utilization
    Intelligent dynamic bandwidth control based on critical services
    SSID-based bandwidth control
Client Management
Client limit
  • Radio-based client limit
    SSID-based client limit
Dynamic blocklist/allowlist
  • Dynamic blocklist
Smart steering
  • AP load balancing
    Configuring load balancing based on client count
    Configuring load balancing based on client traffic
Static blocklist/allowlist
  • Static allowlist
    Static blocklist
Radio Management
SSID management basics
  • SSID hiding
Roaming Features
Layer 2 roaming
  • Layer 2 roaming
Layer 3 roaming
  • Layer 3 roaming
Security Features
Client security
  • Hotspot2.0 authentication
    WPA-802.1X authentication
    WPA-PSK authentication
    WPA-WPA2 authentication
    WPA2-802.1X authentication
    WPA2-PSK authentication
    WPA2-WPA3 authentication
    WPA3-Enterprise
    WPA3-Enterprise (uses Suite-B 192-bit, GCMP-256)
    WPA3-Enterprise with AES-CCMP-128
    WPA3-OWE authentication
    WPA3-Personal
    WEP authentication
802.1X
  • Dynamic ACL assignment
Client identification
  • AI-based identification of client types, operating systems, operating system versions, vendors, and models
  • CPP
MAB
  • MAB
  • NFPP
RADIUS
  • RADIUS
  • Web authentication
Layer 3 Features
  • ICMPv6
    IPv6 basic features
    Neighbor discovery
    Ping over IPv6
NAT
  • NAT
    PPTP, SIP, FTP, DNS, and TFTP
Management Features
SNMP
  • SNMPv1/v2c/v3
    SNMP
Alerts
  • Alerts
Cloud-based management
  • Cloud-based management
SON
  • SON
SSH
  • SSH
Syslog
  • Syslog
Telnet
  • Telnet
Web-based management
  • Web-based management
IP Services
DHCP
  • DHCPv4 client
    DHCPv6 client
NTP
  • NTP client
    NTP server
Networking Features
RIPT
  • RIPT
Routing Features
IPv4 routing basics
  • Static routing
IPv6 routing basics
  • Static IPv6 routing
Device Management
AP mode management
  • Mode switching
Device IP management
  • Obtaining an IP address through DHCP
Device IP Management
  • Static IPv4 address
Multicast Features
IGMP snooping
  • Multicast-to-unicast conversion
Capacity Specifications
Client Management
Maximum number of associated clients per AP
  • 1024
    Note: The number of associated clients varies according to the environment.
Recommended number of associated clients per AP
  • 64
Radio Management
Maximum number of BSSIDs per AP
  • 32
IP Services
Number of DHCP address pools
  • 2000
Package Contents
Device
Main unit
Accessories
Cable gland assembly
  • 2 x cable gland assemblies for Ethernet cable and DC power cord
    2 x cable gland assemblies for optical fiber and hybrid cable
Grounding wire
  • 1 x 2 m (6.56 ft.) grounding wire
Hose clamp
Mounting bracket
  • 1 x adjustable mounting bracket (W x D x H: 126 mm x 106 mm x 215 mm / 4.96 in. x 4.17 in. x 8.46 in.)
Screw
  • 4 x M5 x 10 mm Dacromet-coated screws
    2 x M8 x 60 mm expansion anchors
Terminal block
Manual
User Manual
Warranty Card
Videos
How to Configure VAC on Ruijie Cybrey Devices?
Nov. 12, 2026
How to Maintain network connectivity for Ruijie Cybrey RG-CAP When AC Unreachable (V1.0)
Nov. 12, 2026
How to Integrate Microsoft Entra ID with SSE for Portal and 802.1X Authentication?
Oct. 29, 2026
Views
