M7000L-12GT-RU Switches - 1
M7000L-12GT-RU Switches - 2
M7000L-12GT-RU Switches - 3
M7000L-12GT-RU Switches - 4
M7000L-12GT-RU Switches - 5
M7000L-12GT-RU Switches - 6
M7000L-12GT-RU Switches - 7
M7000L-12GT-RU Switches - 8
M7000L-12GT-RU Switches - 9
M7000L-12GT-RU,12-Port GE Remote Unit for ODON Master Device, Supporting PoE
Applicable to general education, enterprises, schools, and government offices, catering to the need for rapid and secure secure access, and efficient data transmission in small- and medium-sized campus networks
  • Compact Design for Multi-Scenario Deployment
  • In-Room Deployment for Easy Terminal Access and Streamlined Cabling
  • Fanless Design: As Silent As a Falling Leaf
  • Zero-Touch Provisioning & Replacement with Embedded RG-INC-EMB and WIS Cloud
12-Port 1GE In-Room Remote Unit for ODON Master Device M7000L- 12GT-RU
Designed for Ruijie's One Device for One Network (ODON) Solution, these remote units provide a cost-effective option for transmitting data from the integrated switch to terminals.
They deliver nearby access and ultra-high bandwidth to support a wide range of IP-based endpoints.
This compact in-room remote unit supports multiple mounting methods, including 86 mm junction box mounting, wall mounting, and mounting on/under a workbench, enabling flexible deployment across diverse scenarios with high reliability and cost-effectiveness.
Campus Networks
Designed for Small and Medium-Sized campus scenarios, One Device for One Network (ODON) Solution adopts a combination of an ODON Master Device and remote units to simplify the network architecture and reduce deployment costs, meeting the demands of rapid secure access and efficient data transmission on campus networks.
Streamlined Cabling
As part of the ODON Solution, the remote units are installed indoors to provide near-end terminal access, significantly reducing cable usage and simplifying cabling.
With its fanless mechanical structure, the in-room remote unit ensures low-noise operation, preserving a quiet and undisturbed office environment.
*Meet the testing requirements in a standard laboratory environment.
The in-room remote units for the ODON Master Device support plug-and-play functionality for both network deployment and O&M, enabling users to manage operations independently without relying on professional after-sales support.
System Specifications M7000L-5GT-RU M7000L-8GT-RU M7000L-12GT-RU
Fixed ports 5 x 10/100/1000M auto-negotiation electrical ports, including one uplink port supporting PoE 8 x 10/100/1000M auto-negotiation electrical ports, including one uplink port supporting PoE 12 x 10/100/1000M auto-negotiation electrical ports, including one uplink port supporting PoE
Switching capacity 10Gbps 16Gbps 24Gbps
Packet forwarding rate 8Mpps 12Mpps 18Mpps
Dimensions (W x D x H) 86 mm x 86 mm x 24 mm (3.39 in. x 3.39 in. x 0.94 in.) 172 mm x 87 mm x 26 mm (6.77 in. x 3.43 in. x 1.02 in.) 230 mm x 87 mm x 30 mm (9.06 in. x 3.43 in. x 1.18 in.)
Weight 0.12 kg (0.26 lbs, including the decorative cover) 0.25 kg (0.55 lbs, including the decorative cover) 0.42 kg (0.93 lbs, including the decorative cover)
Power supply Uplink PoE complying with 802.3af/802.3at, with a rated voltage of 48 V Uplink PoE complying with 802.3af/802.3at, with a rated voltage of 48 V Uplink PoE complying with 802.3af/802.3at, with a rated voltage of 48 V
Power consumption < 4 W < 6 W < 9 W
PoE output Not supported Not supported Not supported
Fan Fanless design, natural cooling
Operating temperature Installed on a workbench or wall, or under a workbench: 0ºC to 40ºC (32ºF to 104ºF) at a height below 1,800 m (1.12 miles) above the sea level
Note: At a height ranging from 1,800 m (1.12 miles) to 5,000 m (3.11 miles) above the sea level, the maximum operating temperature decreases by 1°C (1.8°F) for every increase in altitude of 220 m (721.78 ft.).
Storage humidity 10% to 90% RH, non-condensing
Operating humidity 5% to 95% RH
Intelligent temperature control The over-temperature alarm and overheat protection functions are supported.
EMC Regulation EN 55032:2015+A1:2020, BS EN 55032:2015+A1:2020
EN 61000-3-3: 2013+A1:2019+A2:2021
BS EN 61000-3-3: 2013+A1: 2019+A2:2021
EN IEC 61000-3-2: 2019+A1:2021, BS EN IEC 61000-3-2: 2019+A1:2021
EN 55035: 2017+A11:2020, BS EN 55035: 2017+A11:2020
EN 300386 V2.2.1
Safety Regulation BS EN 62368-1: 2014+A11: 2017
Software Specifications M7000L-5GT-RU
M7000L-8GT-RU
M7000L-12GT-RU
RSTP Supported
Max. number of MAC address entries 16K
802.1Q VLAN 4K IEEE 802.1Q VLANs
Port-based VLAN
Security Filtering of invalid MAC addresses
Password protection
EEE APD port dormancy
Management CLI-based configuration and management not required, visualized Web management
IoT MQTT
Syslog/Debug, NTP/SNTP
M7000L-5GT-RU
5 x 10/100/1000M auto-negotiation electrical ports, including one uplink port supporting PoE only, fanless design
M7000L-8GT-RU
8 x 10/100/1000M auto-negotiation electrical ports, including one uplink port supporting PoE only, fanless design
M7000L-12GT-RU
12 x 10/100/1000M auto-negotiation electrical ports, including one uplink port supporting PoE only, fanless design
M7000L-8GT-RUBOX
Optional, cable cover, an accessory installed on the cable outlet side of the M7000L-8GT-RU RU
M7000L-12GT-RUBOX
Optional, cable cover, an accessory installed on the cable outlet side of the M7000L-12GT-RU RU
