RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 1
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 2
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 3
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 4
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 5
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 6
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 7
RG-CS65-12XS4VS2QXS-D Small & Medium Enterprise Networking - 8
RG-CS65-12XS4VS2QXS-D, Layer 3 Core/Aggregation Switches with 40G Uplinks
  • Flexible multi-rate access + ultra-high-bandwidth uplink
  • Supports operating temperatures up to 50°C
  • N+1 power supply and fan redundancy design
  • Dual flash, dual boot, and dual bin
  • Circuit isolation protection based on optical ports
  • Supports up to 8 devices in a VSU
  • Comprehensive Layer 3 service features
Key Specifications
Current RG-CS65-12XS4VS2QXS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24SFP/8GT4XS-D RG-CS65-24SFP/8GT4XS-D RG-CS65-24XS8VS2QXS-D RG-CS65-24XS8VS2QXS-D
Fixed service port 12 x 1GE/2.5GE/10GE SFP+ ports
4 x 10GE/25GE SFP28 ports
2 x 40GE QSFP+ ports
24 x 1GE SFP ports (Ports 17 to 24 are 10/100/1000BASE-T combo ports)
4 x 1GE/2.5GE/10GE SFP+ ports
24 x 1GE/2.5GE/10GE SFP+ ports
8 x 10GE/25GE SFP28 ports
Console port 1 1 1
MGMT port 1 1 1
USB 1 1 1
Switching capacity 600 Gbps (Gbit/s) 128 Gbps (Gbit/s) 1040 Gbps (Gbit/s)
Forwarding rate 446.4 Mpps 95.23 Mpps 773.76 Mpps
Unit dimensions (W x D x H) 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.) 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.) 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.)
Unit weight 5.3 kg (11.68 lbs) 5.40 kg (11.90 lbs) 5.81kg (12.81 lbs)
Maximum power consumption 110 V: 105 W
220 V: 104 W
110 V: 100 W
220 V: 99 W
110 V: 189 W
220 V: 186 W
Operating temperature 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F)
Fan 4 x hot-swappable fan modules (pre-installed) 3 x hot-swappable fan modules (pre-installed) 4 x hot-swappable fan modules (pre-installed)
Warranty 5 years 5 years 5 years
Aggregate interface LACP basics LACP basics LACP basics
    High‑Speed Multi‑Rate Ports
    Cybrey switches offer a combination of 1G/2.5G SFP, 10G SFP+, 25G SFP28, and 40G QSFP+ ports, delivering high switching capacity and forwarding performance for bandwidth‑intensive environments.
    Cybrey switches provide complete IPv4/IPv6 routing with OSPF, BGP, IS‑IS, and RIP. They are ideal for use as aggregation switches in large campus networks or core switches in SME networks, enabling flexible interconnection and service delivery.
  • 3
    8-Unit Stacking
    8-Unit Stacking
    3
    8-Unit Stacking
    8-unit stacking for flexible expansion helps maintain continuous service during device failures.
    Dual-boot & Dual-bin
    Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
  • 5
    Area-based Port Power Supply
    5
    When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
  • 6
    N+1 Redundancy
    N+1 Redundancy
    6
    N+1 Redundancy
    Cybrey switches provide full Layer 3 capabilities, supporting both Layer 2 flat deployment and Layer 3 networking. They deliver fast convergence and fault domain isolation, improve SLA performance, and reduce TCO.
In the Box
  • RG-CS65-12XS4VS2QXS-D
    × 1
  • Rack-mount bracket
    × 2
  • Rack-mount guide
    × 2
  • Rack-mount guide rail
    × 2
  • M4 x 8 mm screws
    × 10
  • Rubber pad
    × 1
  • Grounding wire
    × 1
Cybrey Cloud, Make Your Business Easy
  • Interface Configuration
  • MAC Address Management
  • Vlan Configuration
  • 802.1X Authentication
