RG-RSR830W-P Routers - 1
RG-RSR830W-P Routers - 2
RG-RSR830W-P Routers - 3
RG-RSR830W-P 10-Port Mobile Router, Supporting PoE and Wi-Fi 6
RG-RSR830W-P, 10-Port Mobile Router
The router integrates routing, switching, wireless, and other network functions, supports PoE and Wi-Fi 6, and is applicable to customers with multiple branches, such as retail stores, chain stores, logistics, and offices.
RG-RSR830
RG-RSR830W
RG-RSR830-P
RG-RSR830W-P
Forwarding performance
0.5 Mpps
0.5 Mpps
0.5 Mpps
0.5 Mpps
Uplink WAN ports:
2 x 10/100/1000BASE-T ports
Downlink LAN ports:
Uplink WAN ports:
Downlink LAN ports:
Uplink WAN ports:
Downlink LAN ports:
Uplink WAN ports:
Downlink LAN ports:
Flash Memory
4 GB
4 GB
4 GB
4 GB
400 Mbps
400 Mbps
400 Mbps
400 Mbps
Number of IPsec VPN Tunnels
100
100
100
100
Expansion Module
● SIC-LTE-GS
● SIC-LTE-GD
● SIC-5G-G
● SIC-2SFP
Wi-Fi Port
802.11 b/g/n/ac/ax
802.11 b/g/n/ac/ax
Unit Dimensions (W x D x H)
0.95 kg (2.09 lbs)
1.04 kg (2.29 lbs)
1.05 kg (2.31 lbs)
1.14 kg (2.51 lbs)
Maximum Power Consumption
36 W (including module power)
36 W Power Adapter:
36 W Power Adapter:
150 W Power Adapter:
Recommended number of user
300
300
300
300
External Power Supply
IP30
IP30
IP30
IP30
RG- RSR830 Series
Frame format: Ethernet II
LAN/WAN switching
WAN/LAN mode switching
HQoS: DSCP/IP-PRE/COS
Option 43/52/138
Option 138
Option 43
Option 82
interface)
Trusted interface
DNS client
FTP client
NTP client
NTP server
TFTP client
TFTP server
DHCPv6 client
Option 18
Option 37
DHCPv6 server
Option 52
DHCPv6 Snooping
ND Snooping
FTP server
TFTP server
TFTP client
NTP server
NTP client
Layer 2 features
MAC address filter
Static MAC address
Global MAC address learning
MAC address aging time
Port based VLAN
802.1QVLANTagging
PPTP/L2TP
Spanning Tree Protocol
Layer 3 features
Proxy ARP
ARP entry aging
Ping
Traceroute
GRE tunnel
IPv4 & IPv6 VRF
Static IP
BGP4/BGP4+
IS-IS v4/v6
OSPF v2/v3
RIP v1/v2
PBR
NAT features
NAT sessions:75000
NAT Throughtput
:up to 940 Mbps (1500Bytes)
VAG
Intelligent routing
Load balancing
Controller management
Disaster recovery
WLAN features
WLAN services:
SSID configuration
SSID-based VLAN configuration
UTF8 SSID
Wireless security: WPA3
RF resources:
Channel configuration
Channel width configuration
Power configuration
WMM configuration
802.11 b/g/n/ac/ax
WLAN details:
Dual Radio, 4 spatial streams
Operating Frequency Bands:
~5.350GHz, 5.725GHz~5.850GHz
Maximum Access Rate:
Radio 1: 2.4GHz, 575Mbps
Radio 2: 5GHz, 1.2Gbps
Modulation Types:
Security features
AAA and web authentication
VPN features
Management features
gRPC framework
TACACS
SSH
Syslog
HTTP server V1.1
HTTPS server
Out-of-the-box web management
Eweb 2.0
Hostname configuration
YANG model
USB-based deployment
RG-RSR830
RG-RSR830W
RG-RSR830-P
RG-RSR830W-P
Expansion Module
SIC-5G-G
SIC-LTE-GD
 SIC-LTE-GS
 SIC-2SFP
