RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 1
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 2
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 3
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 4
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 5
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 6
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 7
RG-CS63-24MG4XS-UPD Small & Medium Enterprise Networking - 8
RG-CS63-24MG4XS-UPD, Layer 3 Access Switches with 10G Uplinks
  • Class 8 90 W high-power PoE
  • 10 kV port surge protection
  • Supports operating temperatures up to 50°C
  • Hot-swappable dual power supplies
  • Dual flash, dual boot, and dual bin
  • Circuit isolation protection based on optical ports
  • Supports up to 8 devices in a VSU
  • Comprehensive Layer 3 service features
Key Specifications
RG-CS63-24MG4XS-UPD
Layer 3 Access Switches with Multi‑Gig Ports and 10G SFP+ Uplinks
    Equipped with 24 x 10/100/1000/2.5GBASE-T ports and 4 x 10G SFP+ uplinks, the access switches deliver high‑speed access for next‑gen Wi‑Fi 8 APs and bandwidth‑hungry clients.
    90 W PoE (Class 8)
    90 W PoE (Class 8)
    90 W PoE (Class 8)
    Class 8 90 W PoE powers high‑power devices like industrial cameras, smart displays, and Wi-Fi 7 APs.
  • 3
    8-Unit Stacking
    8-Unit Stacking
    3
    8-Unit Stacking
    8-unit stacking for flexible expansion helps maintain continuous service during device failures.
    Dual-boot & Dual-bin
    Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
  • 5
    Area-based Port Power Supply
    5
    When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
  • 6
    Layer 3 Capabilities
    6
    Cybrey switches provide full Layer 3 capabilities, supporting both Layer 2 flat deployment and Layer 3 networking. They deliver fast convergence and fault domain isolation, improve SLA performance, and reduce TCO.
  • 7
    10 kV Surge Protection & 50°C Operation
    7
    Compared with typical switches that support 6–8 kV surge protection and operation up to 45°C, Cybrey switches deliver 10 kV surge protection and stable performance at temperatures up to 50°C, making them suitable for harsh environments.
In the Box
  • RG-CS63-24MG4XS-UPD
    × 1
  • Rack-mount bracket
    × 2
  • Rack-mount guide
    × 2
  • Rack-mount guide rail
    × 2
  • M4 x 8 mm screws
    × 10
  • Rubber pad
    × 1
  • Grounding wire
    × 1
Cybrey Cloud, Make Your Business Easy
  • Interface Configuration
  • MAC Address Management
  • Vlan Configuration
  • 802.1X Authentication
  • 24 x 10/100/1000/2.5GBASE-T ports, supporting PoE/PoE+/PoE++
Console port
MGMT port
  • 200 Gbps (Gbit/s)
  • 148.8 Mpps
Packet buffer size
  • 64 Mbit
  • Quad-core ARM A55 CPU frequency up to 1.2 GHz
SDRAM
  • 2 GB+4 bit ECC
  • 512 MB
  • 16 MB
  • 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.)
  • 1 RU
Packaging dimensions (W x D x H)
  • 570 mm x 565 mm x 200 mm (22.44 in. x 22.24 in. x 7.87 in.)
  • 5.1 kg (11.24 lbs)
Packaging weight
  • 7.57 kg (16.69 lbs)
  • RG-PA600I-P-FC
    RG-PA1000I-P-FC
Power supply mode
  • 2 x pluggable power modules (not pre-installed)
  • Full-load:
    110 V: 1900 W
    220 V: 1850 W
    No-load:
    110 V: 93.5 W
    220 V: 90.9 W
  • RG-PA600I-P-FC (AC input):
    ● Maximum input current: 8 A
    RG-PA1000I-P-FC (AC input 1):
    ● Rated input voltage: 100 V AC to 130 V AC, 50 Hz to 60 Hz
    ● Maximum input voltage: 90 V AC to 143 V AC, 47 Hz to 63 Hz
    ● Maximum input current: 12 A
    RG-PA1000I-P-FC (AC input 2):
    ● Rated input voltage: 200 V AC to 240 V AC, 50 Hz to 60 Hz
    ● Maximum input voltage: 180 V AC to 264 V AC, 47 Hz to 63 Hz
Number of PoE-out ports
  • All RJ45 ports support PoE/PoE+ and PoE++ power supply (IEEE 802.3af/at and 802.3bt).
  • The PoE budget varies depending on the power modules used:
    ● 1 x RG-PA600I-P-FC: 470 W
    ● 1 x RG-PA1000I-P-FC: 800 W
    ● 2 x RG-PA600I-P-FC: 940 W
    ● 2 x RG-PA1000I-P-FC: 1600 W
    Note: Mixed use of the RG-PA600I-P-FC and RG-PA1000I-P-FC power modules will be supported after a device software upgrade.
PoE budget per port
  • 90 W
  • Four pairs (1-2, 3-6, 4-5, and 7-8 pairs)
  • 0°C to 50°C (32°F to 122°F)
  • 10% RH to 90% RH (non-condensing)
Operating altitude
  • 0 m to 5000 m (0 ft. to 16,404.20 ft.)
  • Air cooling, front-to-rear airflow, left-to-rear airflow
  • 3 x fixed fans
Noise
  • 27°C (80.6°F): 61 dB
  • Intelligent speed adjustment
Power redundancy
    2 x RG-PA1000I-P-FC: 1+1 power redundancy (only PoE load ≤ 800 W)
    2 x RG-PA600I-P-FC: 1+1 power redundancy (only PoE load ≤ 470 W)
Hot swapping of power modules
Hot swapping of cables
  • Service port:±10 kV for common mode
    MGMT port:±10 kV for common mode
    Power connector: ±6 kV for common mode and ±6 kV for differential mode
ESD prevention
  • Contact discharge: 6 kV
    Air discharge: 8 kV
Temperature monitoring and protection
  • Temperature monitoring, temperature alarm, and over-temperature protection
  • Fault alarm
  • Monitoring of power supply model and status
  • > 400,000 hours
Energy efficiency
Certification and Regulatory Compliance
Safety regulations
  • IEC 62368-1 EN 62368-1
EMC regulations
  • EN 300386, EN 55032 Class A, EN 55035,
    EN IEC 61000-3-2, EN 61000-3-3, EN 61000-4-2, EN IEC 61000-4-3,
    EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN IEC 61000-4-11
  • 5 years
Layer 2 Features
  • IEEE 802.1Q
    Port-based VLAN
    MAC-based VLAN
    IP/Subnet-based VLAN
    Protocol-based VLAN
    Super VLAN
Spanning tree
  • IEEE802.1d STP
    IEEE802.1w RSTP
    Standard 802.1s MSTP
  • LLDP
    LLDP-MED
  • Basic QinQ
    Transparent transmission of double-tagged packets
  • Selective QinQ
  • REUP
  • RLDP
ERPS(G.8032)
  • ERPS(G.8032)
Layer 3 Features
  • ARP
    anyIP
ND
  • Neighbor discovery
VRF
  • IPv4 and IPv6 VRF
Routing Features
  • IPv4 static routing
    IPv6 static routing
OSPF
  • OSPFv2 basics
    OSPFv3 basics
BGP4
  • BGP4 basics
BGP4+
  • BGP4+ basics
IS-ISv4
  • IS-ISv4 basics
IS-ISv6
  • IS-ISv6 basics
RIP
  • RIP
    RIPv2
RIPng
  • RIPng
PBR
  • IPv4 PBR
    IPv6 PBR
Multicast Features
IGMP snooping
  • IGMP snooping v1/v2
    IGMP snooping v3
IGMP
  • IGMPv1/v2/v3
    IGMP proxy
MLD snooping
  • MLD snooping
    MLD snooping v2
MLD
  • MLDv1/v2
PIM-SMv4
  • PIM-SMv4
    PIM-SSMv4
PIM-DMv4
  • PIM-DMv4
  • PIM-SMv6
    PIM-SSMv6
  • MSDP
  • IP standard ACL
    IP extended ACL
    MAC extended ACL
    Expert ACL
    Time-based ACL
    ACL-based redirection
  • Traffic classification based on 802.1p priorities, DSCP priorities, and IP precedences
    SP
    WRR
    SP+WRR
    DRR
    SP+DRR
    WFQ
    SP+WFQ
    Traffic shaping (ingress/egress)
Security Features
802.1X
  • Port-based authentication
    MAC-based authentication
  • AAA
Web-based authentication
  • HTTP-based authentication
    HTTPS-based authentication
  • IP source guard
IPv6 source guard
  • IPv6 source guard
  • SAVI
  • Configuring global IP-MAC binding entries
  • TACACS+
  • Hardware CPP
  • Port isolation
RADIUS
  • RADIUS
Port Security
  • Port Security
  • NFPP
High Availability
  • Device virtualization
  • IPv4 VRRPv2
    IPv4 VRRPv3
    IPv6 VRRP
VRRP+
  • IPv4 VRRP+
    IPv6 VRRP+
  • BFD detection
  • DLDP
Interface Features
Aggregate interface
  • LACP basics
Mirroring
  • SPAN
    RSPAN
Management Features
SNMP
  • SNMPv1/v2c/v3
SSH
  • SSHv2
    SSHv1
  • sFlow
  • gRPC framework
  • NETCONF
SON
  • SON
Cybrey Cloud
  • Cybrey Cloud
OAM Features
  • Uninterrupted power supply upon warm start
    PoE port priority
IP Services
DHCP
  • DHCPv4 client
    DHCPv4 server
    DHCPv4 relay
    DHCPv4 snooping
    DHCPv6 client
    DHCPv6 relay
ND snooping
  • ND snooping
  • DNS client
    DNSv6 client
NTP
  • NTP client
    NTP server
SNTP
  • SNTP client
    SNTP
FTP
  • FTP client
    FTP server
TFTP
  • TFTP client
    TFTP server
System Features
  • USB 2.0
Capacity Specifications
Layer 2 Features
Maximum number of global MAC addresses (The device must be able to learn the maximum number of MAC addresses in the full-mesh test model.)
  • Default: 64000 (subject to the UFT capacity)
Maximum number of created VLANs
  • 4094
Jumbo frame length / Port MTU
  • 9216
Layer 2 traffic convergence time
  • ≤ 200 ms
Layer 3 Features
Maximum number of ARP entries
  • Recommended default: 30000 (subject to the UFT capacity)
Routing Features
IPv4 routing table size
  • 32000
IPv6 routing table size
  • 8000 (resources shared with IPv4 routing)
Multicast Features
Maximum number of IPv4 multicast routing table entries
  • 4000
Maximum number of IPv6 multicast routing table entries
  • 4000
Maximum number of inbound ACE entries
  • 4500
Maximum number of outbound ACE entries
  • 1000
Maximum number of QoS hardware queues
  • 8 unicast queues + 8 multicast queues
High Availability
  • 8
Package Contents
Device
Main unit
Accessories
Rack-mount bracket
Rack-mount guide
Screw
  • 10 x M4 x 8 mm screws
Rubber pad
Grounding wire
Manual
User Manual
Warranty Card
