CO-XG-SFP-T Small & Medium Enterprise Networking - 1
CO-XG-SFP-T Small & Medium Enterprise Networking - 2
CO-XG-SFP-T Small & Medium Enterprise Networking - 3
CO-XG-SFP-T Small & Medium Enterprise Networking - 4
CO-XG-SFP-T Small & Medium Enterprise Networking - 5
CO-XG-SFP-T Small & Medium Enterprise Networking - 6
CO-XG-SFP-T Small & Medium Enterprise Networking - 7
Model CO-XG-SFP-T CO-XG-SFP-SR-MM850 CO-XG-SFP-LR-SM1310 CO-GE-SFP-SX-MM850 CO-GE-SFP-LX-SM1310
Basic Parameters
Data rate 10.3125 Gbps 10.3125 Gbps 10.3125 Gbps 1.25 Gbps 1.25 Gbps
Form factor SFP+ SFP+ SFP+ SFP SFP
Connector type RJ45 Duplex LC Duplex LC Duplex LC Duplex LC
Fiber type Cat 6A/7 MMF SMF MMF SMF
Fiber end face finish type N/A UPC UPC UPC UPC
Core/Cladding diameter N/A 50/125 μm 9/125 μm 50/125 μm 9/125 μm
Modal bandwidth N/A OM3 MMF: 2000 MHz·km
OM4 MMF: 4700 MHz·km
N/A N/A N/A
Transmitter type N/A VCSEL DFB VCSEL DFB
Receiver type N/A PIN PIN PIN PIN
Maximum reach 30 m (98.43 ft) OM3: 300 m (984.25 ft)
OM4: 400 m (1312.34 ft)
10 km (32808.40 ft ) OM2: 550 m (1804.46 ft) 10 km (32808.40 ft )
Pre-FEC BER N/A 1.00E-12 1.00E-12 1.00E-12 1.00E-12
Data diagnostics (DDM/DOM) No Yes Yes Yes Yes
EMC N/A Yes Yes Yes Yes
Power consumption ≤1.8 W ≤1.5 W ≤1.5 W ≤1.5 W ≤1.5 W
Protocol IEEE 802.3an, SFF8472 IEEE 802.3ae, SFF8472 IEEE 802.3ae, SFF8472 IEEE802.3z, INF-8074i IEEE802.3z, INF-8074i
Operating wavelength N/A 850 nm 1310 nm 850 nm 1310 nm
Maximum transmit power (AVG) N/A –1 dBm 0.5dBm 0dBm –3dBm
Minimum transmit power (AVG) N/A –7.3 dBm –8.2 dBm –9.5dBm –11dBm
Minimum extinction ratio N/A ≥3.0 dB ≥3.5 dB ≥9dB ≥9 dB
Receive sensitivity (OMA) N/A <–11.1 dBm <–12.6 dBm <–17 dBm <–19 dBm
Overload optical power (AVG) N/A –1 dBm 0.5 dBm 0 dBm –3 dBm
Operating temperature 0°C to 70°C (32°F to 158°F) 0°C to 70°C (32°F to 158°F) 0°C to 70°C (32°F to 158°F) 0°C to 70°C (32°F to 158°F) 0°C to 70°C (32°F to 158°F)
Operating humidity 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing) 10% to 90% RH (non-condensing)
Storage temperature –40°C to 85°C (–40°F to 185°F) –40°C to 85°C (–40°F to 185°F) –40°C to 85°C (–40°F to 185°F) –40°C to 85°C (–40°F to 185°F) –40°C to 85°C (–40°F to 185°F)
Storage humidity 10% to 90% (non-condensing) 10% to 90% (non-condensing) 10% to 90% (non-condensing) 10% to 90% (non-condensing) 10% to 90% (non-condensing)
Dimensions (W x D x H) 68 mm x 14 mm x 8.5 mm
(2.68 in. x 0.55 in. x 0.33 in.)
56.5 mm x 13.5 mm x 8.5 mm
(2.22 in. x 0.53 in. x 0.33 in.)
Weight 37 g (0.08 lbs) 31 g (0.07 lbs) 31 g (0.07 lbs) 31 g (0.07 lbs) 31 g (0.07 lbs)
Compliance and Certification
Compliance and certification CE CB CE CB CE CB CE CB CE CB
