10G SR module,SFP+ form factor, Duplex LC,300 m over OM3 / 400 m over OM4 MMF
CO-XG-SFP-LR-SM131010G LR module,SFP+ form factor,Duplex LC,10 km over SMF
CO-GE-SFP-SX-MM8501G SX module,SFP form factor,Duplex LC,550 m over OM2 MMF
CO-GE-SFP-LX-SM13101G LX module,SFP form factor,Duplex LC,10 km over SMF
CO-XG-SFP-T10G copper module,SFP+ form factor,RJ45,30 m over Cat 6A/7
| Model | CO-XG-SFP-T | CO-XG-SFP-SR-MM850 | CO-XG-SFP-LR-SM1310 | CO-GE-SFP-SX-MM850 | CO-GE-SFP-LX-SM1310 |
| Basic Parameters | |||||
| Data rate | 10.3125 Gbps | 10.3125 Gbps | 10.3125 Gbps | 1.25 Gbps | 1.25 Gbps |
| Form factor | SFP+ | SFP+ | SFP+ | SFP | SFP |
| Connector type | RJ45 | Duplex LC | Duplex LC | Duplex LC | Duplex LC |
| Fiber type | Cat 6A/7 | MMF | SMF | MMF | SMF |
| Fiber end face finish type | N/A | UPC | UPC | UPC | UPC |
| Core/Cladding diameter | N/A | 50/125 μm | 9/125 μm | 50/125 μm | 9/125 μm |
| Modal bandwidth | N/A | OM3 MMF: 2000 MHz·km OM4 MMF: 4700 MHz·km |
N/A | N/A | N/A |
| Transmitter type | N/A | VCSEL | DFB | VCSEL | DFB |
| Receiver type | N/A | PIN | PIN | PIN | PIN |
| Maximum reach | 30 m (98.43 ft) | OM3: 300 m (984.25 ft) OM4: 400 m (1312.34 ft) |
10 km (32808.40 ft ) | OM2: 550 m (1804.46 ft) | 10 km (32808.40 ft ) |
| Pre-FEC BER | N/A | 1.00E-12 | 1.00E-12 | 1.00E-12 | 1.00E-12 |
| Data diagnostics (DDM/DOM) | No | Yes | Yes | Yes | Yes |
| EMC | N/A | Yes | Yes | Yes | Yes |
| Power consumption | ≤1.8 W | ≤1.5 W | ≤1.5 W | ≤1.5 W | ≤1.5 W |
| Protocol | IEEE 802.3an, SFF8472 | IEEE 802.3ae, SFF8472 | IEEE 802.3ae, SFF8472 | IEEE802.3z, INF-8074i | IEEE802.3z, INF-8074i |
| Transmitter Optical Parameters | |||||
| Operating wavelength | N/A | 850 nm | 1310 nm | 850 nm | 1310 nm |
| Maximum transmit power (AVG) | N/A | –1 dBm | 0.5dBm | 0dBm | –3dBm |
| Minimum transmit power (AVG) | N/A | –7.3 dBm | –8.2 dBm | –9.5dBm | –11dBm |
| Minimum extinction ratio | N/A | ≥3.0 dB | ≥3.5 dB | ≥9dB | ≥9 dB |
| Receiver Optical Parameters | |||||
| Receive sensitivity (OMA) | N/A | <–11.1 dBm | <–12.6 dBm | <–17 dBm | <–19 dBm |
| Overload optical power (AVG) | N/A | –1 dBm | 0.5 dBm | 0 dBm | –3 dBm |
| Environment and Reliability | |||||
| Operating temperature | 0°C to 70°C (32°F to 158°F) | 0°C to 70°C (32°F to 158°F) | 0°C to 70°C (32°F to 158°F) | 0°C to 70°C (32°F to 158°F) | 0°C to 70°C (32°F to 158°F) |
| Operating humidity | 10% to 90% RH (non-condensing) | 10% to 90% RH (non-condensing) | 10% to 90% RH (non-condensing) | 10% to 90% RH (non-condensing) | 10% to 90% RH (non-condensing) |
| Storage temperature | –40°C to 85°C (–40°F to 185°F) | –40°C to 85°C (–40°F to 185°F) | –40°C to 85°C (–40°F to 185°F) | –40°C to 85°C (–40°F to 185°F) | –40°C to 85°C (–40°F to 185°F) |
| Storage humidity | 10% to 90% (non-condensing) | 10% to 90% (non-condensing) | 10% to 90% (non-condensing) | 10% to 90% (non-condensing) | 10% to 90% (non-condensing) |
| Dimensions and Weight | |||||
| Dimensions (W x D x H) | 68 mm x 14 mm x 8.5 mm (2.68 in. x 0.55 in. x 0.33 in.) |
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.53 in. x 0.33 in.) |
| Weight | 37 g (0.08 lbs) | 31 g (0.07 lbs) | 31 g (0.07 lbs) | 31 g (0.07 lbs) | 31 g (0.07 lbs) |
| Compliance and Certification | |||||
| Compliance and certification | CE CB | CE CB | CE CB | CE CB | CE CB |
