2.5G-SFP-LX03-SM1550-BIDI-I Switches - 1
2.5G-SFP-LX03-SM1550-BIDI-I Switches - 2
2.5G-SFP-LX03-SM1550-BIDI-I Switches - 3
2.5G-SFP-LX03-SM1550-BIDI-I Switches - 4
2.5G-SFP-LX03-SM1550-BIDI-I Switches - 5
2.5G-SFP-LX03-SM1550-BIDI-I 2.5G BiDi SFP 1550nm-TX/1310nm-RX 3-km DOM Simplex LC SMF Transceiver Module
  • Max. power consumption 1 W.
The 2.5G-SFP-LX03-SM1550-BIDI-I is aligned to IEEE 2.5GBASE-LX optical specifications and supports a link length of up to 3 kilometers over an SMF with a BIDI LC connector. It adopts the SFP form factor and operates at a wavelength of 1550 nm. The transceiver conforms to SFF-8431, SFF-8472, and RoHS standards.
Optical Module Specifications
3.125 Gbps
FB
3 km (9,842.52 ft.)
≤ 1 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–9 dBm
Min. extinction ratio
≥ 6.5 dB
< –16 dBm
–3 dBm
35 g (0.08 lbs.)
