RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 1
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 2
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 3
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 4
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 5
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 6
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 7
RG-CS65-24SFP/8GT4XS-D Small & Medium Enterprise Networking - 8
RG-CS65-24SFP/8GT4XS-D, Layer 3 Core/Aggregation Switch with 10G Uplinks & Versatile Fiber/Copper Connectivity
  • Supports operating temperatures up to 50°C
  • N+1 power supply and fan redundancy design
  • Dual flash, dual boot, and dual bin
  • Circuit isolation protection based on optical ports
  • Supports up to 8 devices in a VSU
  • Comprehensive Layer 3 service features
Key Specifications
Current RG-CS65-24SFP/8GT4XS-D RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D RG-CS65-24XS8VS2QXS-D
Fixed service port 24 x 1GE SFP ports (Ports 17 to 24 are 10/100/1000BASE-T combo ports)
4 x 1GE/2.5GE/10GE SFP+ ports
12 x 1GE/2.5GE/10GE SFP+ ports
4 x 10GE/25GE SFP28 ports
2 x 40GE QSFP+ ports
24 x 1GE/2.5GE/10GE SFP+ ports
8 x 10GE/25GE SFP28 ports
Console port 1 1 1
MGMT port 1 1 1
USB 1 1 1
Switching capacity 128 Gbps (Gbit/s) 600 Gbps (Gbit/s) 1040 Gbps (Gbit/s)
Forwarding rate 95.23 Mpps 446.4 Mpps 773.76 Mpps
Unit dimensions (W x D x H) 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.) 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.) 442 mm x 420 mm x 43.6 mm (17.4 in. x 16.54 in. x 1.72 in.)
Unit weight 5.40 kg (11.90 lbs) 5.3 kg (11.68 lbs) 5.81kg (12.81 lbs)
Maximum power consumption 110 V: 100 W
220 V: 99 W
110 V: 105 W
220 V: 104 W
110 V: 189 W
220 V: 186 W
Operating temperature 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F) 0°C to 50°C (32°F to 122°F)
Fan 3 x hot-swappable fan modules (pre-installed) 4 x hot-swappable fan modules (pre-installed) 4 x hot-swappable fan modules (pre-installed)
Warranty 5 years 5 years 5 years
Aggregate interface LACP basics LACP basics LACP basics
RG‑CS65‑24SFP/8GT4XS‑D
Layer 3 Aggregation Switch with 10G Uplinks & Versatile Fiber/Copper Connectivity
    1G Access Switches with 10G Uplinks
    Cybrey switches offer 24 x 1GE SFP ports (with 8 combo ports) and 4 x 10G SFP+ uplinks, supporting multi‑rate access (1G/2.5G/10G) for flexible aggregation deployment.
    Layer 3 Core/Aggregation Switches
    Cybrey switches provide complete IPv4/IPv6 routing with OSPF, BGP, IS‑IS, and RIP. They are ideal for use as aggregation switches in large campus networks or core switches in SME networks, enabling flexible interconnection and service delivery.
  • 3
    8-Unit Stacking
    8-Unit Stacking
    3
    8-Unit Stacking
    8-unit stacking for flexible expansion helps maintain continuous service during device failures.
    Dual-boot & Dual-bin
    Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
  • 5
    Area-based Port Power Supply
    5
    When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
  • 6
    N+1 Redundancy
    N+1 Redundancy
    6
    N+1 Redundancy
    Cybrey switches provide full Layer 3 capabilities, supporting both Layer 2 flat deployment and Layer 3 networking. They deliver fast convergence and fault domain isolation, improve SLA performance, and reduce TCO.
  • 7
    10 kV Surge Protection & 50°C Operation
    7
    Compared with typical switches that support 6–8 kV surge protection and operation up to 45°C, Cybrey switches deliver 10 kV surge protection and stable performance at temperatures up to 50°C, making them suitable for harsh environments.
In the Box
  • RG‑CS65‑24SFP/8GT4XS‑D
    × 1
  • Rack-mount bracket
    × 2
  • Rack-mount guide
    × 2
  • Rack-mount guide rail
    × 2
  • M4 x 8 mm screws
    × 10
  • Rubber pad
    × 1
  • Grounding wire
    × 1
Cybrey Cloud, Make Your Business Easy
  • Interface Configuration
  • MAC Address Management
  • Vlan Configuration
  • 802.1X Authentication
Port Specifications RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Port restrictions - Note: The four 10GE/25GE SFP28 ports must operate in the same speed mode; 10 Gbps and 25 Gbps speed modes cannot be mixed. Note:
1. 24 x 1GE/2.5GE/10GE SFP+ ports: Divided into 4-port groups by number. Speed modes (1/2.5/10 Gbps) cannot be mixed per group. If one port in a group is configured as a VSL port, the other three are automatically designated as VSL ports.
2. 8 x 10GE/25GE SFP28 ports: Divided into 4-port groups by number. Speed modes (10/25 Gbps) cannot be mixed per group. If one port in a group is configured as a VSL port, the other three are automatically designated as VSL ports.
Console port 1
MGMT port 1
USB 1
System Specifications RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Packet buffer size 32 Mbit 32 Mbit 64 Mbit
CPU Quad-core ARMv8 Cortex-A72 CPU frequency up to 2000 MHz
SDRAM 4 GB+8 bit ECC
Flash memory 1 GB
BootROM 16 MB
Real-time clock (RTC) Yes
Dimensions and Weight RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Rack height 1 RU
Packaging dimensions (W x D x H) 570 mm x 565 mm x 225 mm (22.44 in. x 22.24 in. x 8.86 in.)
Packaging weight 8.01 kg (17.66 lbs) 7.93 kg (17.48 lbs) 8.45 kg (18.63 lbs)
Power Supply and Consumption RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Power module RG-PA150IB-FC RG-PA150IB-FC RG-PA550I-FC
Power supply mode 2 x pluggable power modules (not pre-installed)
220 V: 99 W
110 V: 105 W
220 V: 104 W
110 V: 189 W
220 V: 186 W
Power input RG-PA150IB-FC (AC input):
● Maximum input current: 3 A
RG-PA550I-FC (AC input):
Environment and Reliability RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Operating humidity 10% RH to 90% RH (non-condensing)
Storage humidity 5% RH to 95% RH (non-condensing)
Operating altitude 0 m to 5000 m (0 ft. to 16,404.20 ft.)
Cooling Air cooling, front-to-rear airflow, left-to-rear airflow
Noise 27°C (80.6°F): 40 dB 27°C (80.6°F): 40 dB 27°C (80.6°F): 52 dB
Fan speed adjustment Intelligent speed adjustment
Power redundancy Yes
Hot swapping of power modules Yes
Hot swapping of cables Yes
USB hot swapping Yes
Surge protection Service port: ±10 kV for common mode
MGMT port:±10 kV for common mode
Power connector: ±6 kV for common mode and ±6 kV for differential mode
ESD prevention Contact discharge: 6 kV
Air discharge: 8 kV
Temperature monitoring and protection Temperature monitoring, temperature alarm, and over-temperature protection
Fan monitoring Fault alarm
Power supply monitoring Monitoring of power supply model and status
MTBF > 400,000 hours
Energy efficiency Yes - -
Certification and Regulatory Compliance RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Safety regulations IEC 62368-1 EN 62368-1
EMC regulations EN 300386, EN 55032 Class A, EN 55035,
EN IEC 61000-3-2, EN 61000-3-3, EN 61000-4-2, EN IEC 61000-4-3,
EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN IEC 61000-4-11
Product Information RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Warranty 5 years
Layer 2 Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
VLAN IEEE 802.1Q
Port-based VLAN
MAC-based VLAN
IP/Subnet-based VLAN
Protocol-based VLAN
Super VLAN
Spanning tree IEEE802.1d STP
IEEE802.1w RSTP
Standard 802.1s MSTP
LLDP LLDP
LLDP-MED
Basic QinQ Basic QinQ
Transparent transmission of double-tagged packets
Selective QinQ Selective QinQ
REUP REUP
RLDP RLDP
ERPS(G.8032) ERPS(G.8032)
Layer 3 Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
ARP ARP
anyIP
ND Neighbor discovery
VRF IPv4 and IPv6 VRF
Routing Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Static routing IPv4 static routing
IPv6 static routing
OSPF OSPFv2 basics
OSPFv3 basics
BGP4 BGP4 basics
BGP4+ BGP4+ basics
IS-ISv4 IS-ISv4 basics
IS-ISv6 IS-ISv6 basics
RIP RIP
RIPv2
RIPng RIPng
PBR IPv4 PBR
IPv6 PBR
Multicast Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
IGMP snooping IGMP snooping v1/v2
IGMP snooping v3
IGMP IGMPv1/v2/v3
IGMP proxy
MLD snooping MLD snooping
MLD snooping v2
MLD MLDv1/v2
PIM-SMv4 PIM-SMv4
PIM-SSMv4
PIM-DMv4 PIM-DMv4
PIM-SMv6 PIM-SMv6
PIM-SSMv6
MSDP MSDP
ACL and QoS RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
ACL IP standard ACL
IP extended ACL
MAC extended ACL
Expert ACL
Time-based ACL
ACL-based redirection
QoS Traffic classification based on 802.1p priorities, DSCP priorities, and IP precedences
SP
WRR
SP+WRR
DRR
SP+DRR
WFQ
SP+WFQ
RED/WRED
Traffic shaping (ingress/egress)
Security Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
802.1X Port-based authentication
MAC-based authentication
AAA AAA
Web-based authentication HTTP-based authentication
HTTPS-based authentication
IP source guard IP source guard
IPv6 source guard IPv6 source guard
SAVI SAVI
Global IP-MAC binding Configuring global IP-MAC binding entries
IPv4 uRPF Supporting strict and loose modes, and allowing default routes to be used for uRPF checks.
TACACS+ TACACS+
CPP Hardware CPP
Port isolation Port isolation
RADIUS RADIUS
Port Security Port Security
NFPP NFPP
URPF URPF
High Availability RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
VSU Device virtualization
VRRP IPv4 VRRPv2
IPv4 VRRPv3
IPv6 VRRP
VRRP+ IPv4 VRRP+
IPv6 VRRP+
BFD BFD detection
DLDP DLDP
Interface Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Mirroring SPAN
RSPAN
ERSPAN
Management Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
SNMP SNMPv1/v2c/v3
SSH SSHv2
SSHv1
sFlow sFlow
gRPC gRPC framework
NETCONF NETCONF
SON SON
Cybrey Cloud Cybrey Cloud
IP Services RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
DHCP DHCPv4 client
DHCPv4 server
DHCPv4 relay
DHCPv4 snooping
DHCPv6 client
DHCPv6 relay
ND snooping ND snooping
DNS DNS client
DNSv6 client
NTP NTP client
NTP server
SNTP SNTP client
SNTP
FTP FTP client
FTP server
TFTP TFTP client
TFTP server
System Features RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
USB USB 2.0
Capacity Specifications
Maximum number of global MAC addresses (The device must be able to learn the maximum number of MAC addresses in the full-mesh test model.) Default: 32000 (subject to the UFT capacity) Default: 32000 (subject to the UFT capacity) Default: 80000 (subject to the UFT capacity)
Maximum number of created VLANs 4094
Jumbo frame length / Port MTU 9216
Layer 2 traffic convergence time RJ45 port: 800 ms
Optical port: 200 ms
RJ45 port: 800 ms
≤ 200 ms
Maximum number of ARP entries 14000 14000 Recommended default: 32000 (subject to the UFT capacity)
IPv4 routing table size 16000 16000 Recommended default: 12000 (subject to the UFT capacity)
IPv6 routing table size 8000 (resources shared with IPv4 routing) 8000 (resources shared with IPv4 routing) Recommended default: 6000 (resources shared with IPv4 routing) (subject to the UFT capacity)
Maximum number of IPv4 multicast routing table entries 4000 4000 8000
Maximum number of IPv6 multicast routing table entries 2000 2000 4000
Maximum number of inbound ACE entries 2500 2500 5000
Maximum number of outbound ACE entries 1000
Maximum number of QoS hardware queues 8 (shared by unicast and multicast traffic) 8 (shared by unicast and multicast traffic) 8 unicast queues + 8 multicast queues
Maximum number of VSU members 8
Package Contents
Device RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Main unit 1
Accessories RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
Rack-mount bracket 2
Rack-mount guide 2
Rack-mount guide rail 2
Screw 10 x M4 x 8 mm screws
Rubber pad 4
Grounding wire 1
Manual RG-CS65-24SFP/8GT4XS-D RG-CS65-12XS4VS2QXS-D RG-CS65-24XS8VS2QXS-D
User Manual 1
Warranty Card 1
