RG-S7610-10SFMP2CQ Switches - 1
RG-S7610-10SFMP2CQ Switches - 2
RG-S7610-10SFMP2CQ Switches - 3
RG-S7610-10SFMP2CQ Switches - 4
RG-S7610-10SFMP2CQ Switches - 5
RG-S7610-10SFMP2CQ Switches - 6
RG-S7610-10SFMP2CQ, 10-Port 1 RU SFMP 2.5GE Ultra-High-Density Fixed CWDM Core Switch
  • 10 x SFMP ports (160 x 2.5GE ports) and 2 x 100GE uplink ports, backward compatible with 40GE, supporting flexible configuration
  • Integration of traditional fixed switches and CWDM multiplexers for simplified management and easy deployment
  • Virtual Switch Unit (VSU) for flexible networking and high performance
  • Multiple hardware-level protection, ensuring continuous device operation without downtime
  • Ruijie Unified Networking Central (RG-UNC) for unified, simplified, automated, and effortless network management
RG-S7610-10SFMP2CQ, 1 RU Ultra-High-Density Fixed CWDM Core Switch
The core switch provides 10 x SFMP high-density CWDM ports, supporting a total of 160 access devices, implementing ultra-high-density connections in a 1 RU space. It also provides 2 x 100GE QSFP28 uplink ports, and one expansion slot for connecting to servers, common switches, and other devices, offering flexible configuration.
Integration of Traditional Fixed Switches and CWDM Multiplexing for Simplified Management and Easy Deployment
The core switch integrates the CWDM technology based on traditional Ethernet interfaces. This enables transparent service transmission from core to access, effectively reduces the number of interfaces occupied on the core device, and greatly simplifies cabling.
Multiple Hardware-Level Protection, Ensuring Continuous Device Operation Without Downtime
RG-UNC for Unified, Simplified, Automated, and Effortless Network Management
RG-UNC enables management via a unified platform and supports real-time monitoring of network status, full-link insights, and intelligent analysis and diagnosis of user experiences, fully guaranteeing service experiences.
RG-UNC supports end-to-end O&M of optical links, achieving visualized, manageable, and controllable optical networks.
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Module service port
M7600-4GT4VS:
● 4 x 10/100/1000BASE-T ports
M7600-2CQ:
● 2 x 40GE/100GE QSFP28 ports
4 x fan module slots
M7600-2CQ
M7600-4GT4VS
RG-PA550I II-F
S7610-FAN I-F
S7620-FAN I-F
RG-S7610-10SFMP2CQ
RG-S7610-10SFXP2CQ
Module service port
M7600-4GT4VS:
M7600-2CQ:
M7600-2CQ
M7600-4GT4VS
RG-PA550I II-F
S7610-FAN I-F
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Packet forwarding rate ^*1^
714 Mpps
1786 Mpps
833 Mpps
2976 Mpps
960 Gbps
2.4 Tbps
1.12 Tbps
4 Tbps
8 GB
4 GB DDR4
36 MB
RG-S7610-10SFMP2CQ
RG-S7610-10SFXP2CQ
1190 Mpps
2976 Mpps
1.6 Tbps
4 Tbps
16 GB
4 GB DDR4
36 MB
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
RG-PA550I II-F (AC input):
RG-PA550I II-F: 550 W
270 W
450 W
RG-S7610-10SFMP2CQ
RG-S7610-10SFXP2CQ
400 W
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
9.73 kg (21.45 lbs)
14.4 kg (31.75 lbs)
RG-S7610-10SFMP2CQ
RG-S7610-10SFXP2CQ
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Front-to-back airflow
27°C (80.6°F): 56 dB
45°C (113°F): 72 dB
Fan failure alarm
Power port: 6 kV
RG-S7610-10SFMP2CQ
RG-S7610-10SFXP2CQ
302000 hours (about 34 years)
45°C (113°F): 72 dB
Fan failure alarm
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IEC 62368-1: 2018
EN 62368-1: 2014+A11:2017
EN 55032:2015+A1:2020
EN IEC 61000-3-2:2019+A1:2021
EN 55035:2017+A11:2020
EN 300386 V2.2.1
Device Model
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
400 Gbps
128,000
96,000
80,000
65,000
In: 28,000, Out: 4,000
Device Model
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Static ARP
GRE tunnel
Graceful restart (GR)
IPv4 IS-IS
IPv6 IS-IS
IPv4/IPv6 PBR
PIM-SM
PIM-DM
MLDv1 and MLDv2
MLD snooping
ACL 80
Port-based rate limiting
IPv4 uRPF and IPv6 uRPF
Strict and loose uRPF
Device Virtualization
RSPAN and ERSPAN
FTP and S TFTP
VLAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
VXLAN EVPN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
RG-S7610-10SFMP2CQ
RG-S7610-10SFXP2CQ
M7600-2CQ
M7600-4GT4VS
RG-PA550I II-F
1GE Optical Transceiver
10GE Optical Transceiver
25GE Optical Transceiver
VG-SFP-AOC5M
40GE Optical Transceiver
100GE Optical Transceiver
SFM-LR-SM
MG-SFP-LR(A1-4)-H
SFGP-LR-SM
SFXP-LR-SM
XG-SFP-LR(A1-16)-H-BIDI
GE-SFP-LR(A1-16)-H-BIDI
XG-SFP-LR(A1-16)-P-BIDI
XG-SFP-LR(A1-16)-H-E-BIDI
GE-SFP-LR(A1-16)-H-E-BIDI
RG-MUX-8LC/LC-H
RG-MUX-8LC/LC
RG-MUX-EXT
RG-MUX-BOX
RG-MUX-16LC/LC-H-BIDI
RG-MUX-16LC/LC-V-BIDI
RG-MUX-BOX-H
