RG-RSR20-XA-54 Routers - 1
RG-RSR20-XA-54 Routers - 2
RG-RSR20-XA-54 Routers - 3
RG-RSR20-XA-54 Routers - 4
RG-RSR20-XA-54 Routers - 5
RG-RSR20-XA-54 Routers - 6
RG-RSR20-XA-54 Routers - 7
RG-RSR20-XA-54 Routers - 8
RG-RSR20-XA-54 Routers - 9
RG-RSR20-XA-54 Routers - 10
RG-RSR20-XA-54 54-Port Multi-service Fixed Access Router
Rich port types and numbers are provided, and various network functions are integrated such as routing, switching, security, and wireless. The access router is suitable for access scenarios of small and medium-sized branches of enterprises and customers in financial, government, and other industries. The next-generation HSIC expansion module is supported and rich expansion modules are provided to meet various combination requirements.
4G/5G supported
Software-Level Dual-Boot
RG-RSR20-XA-24
RG-RSR20-XA-36
RG-RSR20-XA-54
WAN ports:
● 4 x 10GE SFP+ ports
● 4 x 1GE SPF ports
● 4 x 10/100/1000BASE-T ports
WAN ports:
● 4 x 1GE SPF ports
WAN ports:
● 2 x 10GE SFP+ ports
4 x expansion module slots
224 Gbps
4 Mpps
100,000
2,048
100,000
Number of IGMP Groups
Number of MLD Groups
150 W
● Maximum input current: 3 A
RG-PD150IB-F (DC input):
● Maximum input current: 5 A
Power output
● Output voltage: 12 V
RG-PD150IB-F: 150 W
6 kV
RG-RSR20-XA Series
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
Static multicast routing
MPLS forwarding
IPv6 ACLs
uRPF
GR for OSPF/IS-IS/BGP
SDN technology
SPAN and ERSPAN
NTP server and NTP client
RG-RSR20-XA-24
RG-RSR20-XA-36
RG-RSR20-XA-54
Expansion Module
HSIC-2E1/CE1
Power Module
RG-PD150IB-F
150 W DC power module
