RG-S5350-48GT4SFP-E Switches - 1
RG-S5350-48GT4SFP-E Switches - 2
RG-S5350-48GT4SFP-E Switches - 3
RG-S5350-48GT4SFP-E Switches - 4
RG-S5350-48GT4SFP-E Switches - 5
RG-S5350-48GT4SFP-E Switches - 6
RG-S5350-48GT4SFP-E 48-Port GE Layer 3 Managed Access Switch, 4-Port 1GE Uplink
Layer 3 Compact Access Switch for 1GE Uplink RG-S5350-48GT4SFP-E
Passed anti-corrosion tests, with the proven capability to withstand exposure to moisture, ensuring durability in severe environments
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-24GT4XS-P-E
RG-S5350-48GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
RG-S5350-24GT4SFP-P-E
RG-S5350-48GT4SFP-P-E
Fixed service ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
115 Mpps
158 Mpps
94 Mpps
115 Mpps
158 Mpps
Switching capacity *2
128 Gbps / 336 Gbps
176 Gbps / 336 Gbps
104 Gbps / 336 Gbps
128 Gbps / 336 Gbps
176 Gbps / 336 Gbps
512 MB
DDR4 1GB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
50 Mpps
94 Mpps
50 Mpps
94 Mpps
56 Gbps / 336 Gbps
104 Gbps / 336 Gbps
56 Gbps / 336 Gbps
104 Gbps / 336 Gbps
512 MB
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
3.25 kg (7.17 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Power supply and Consumption
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 25 W
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
● Maximum input current: 6 A
Built-in power supply: 409 W
Built-in power supply: 460 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
460 W (full PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
Built-in power supply: 40 W
Leakage current
≤ 3.5 mA
●AC input
Fixed power supply: 409 W
Fixed power supply: 460 W
Leakage current
≤ 3.5 mA
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
No fan
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
S5350-24GT4XS-E: 40 Gbps
S5350-24GT4XS-P-E: 40 Gbps
S5350-48GT4XS-E: 40 Gbps
S5350-48GT4XS-P-E: 40 Gbps
S5350-12GT4XS-P-E: 40 Gbps
S5350-24GT4SFP-E: 4 Gbps
S5350-24GT4SFP-P-E: 4 Gbps
S5350-48GT4SFP-E: 4 Gbps
S5350-48GT4SFP-P-E: 4 Gbps
990
750
750
255
In: 1,750 Out: 800
RG-S5350-E Series
IPv4 and IPv6 VRF
IGMP v1/v2 snooping
PIM SMv6, and PIM-SSMv6
MLDv1/v2 and MLD proxy
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
RADIUS and TACAS+
BFD, NSR, VRRR, VRRP+
Basic LACP
Dual-Boot Redundancy
SPAN, RSPAN
CLI (Telnet/Console)
Web
Syslog/Debug
1:1 mirroring
N:1 mirroring
1:N mirroring
Warm start
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
