RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 1
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 2
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 3
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 4
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 5
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 6
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 7
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 8
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 9
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 10
RG-CS83-24GT4XS-PD Small & Medium Enterprise Networking - 11
RG-CS83-24GT4XS-PD 24-Port 1GE RJ45 Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
RG-CS83-24GT4XS-PD
24 x 1GE RJ45 ports, 4 x 10GE SFP+ ports, PoE/PoE+
RG-CS83-48GT4XS-PD
48 x 1GE RJ45 ports, 4 x 10GE SFP+ ports, PoE/PoE+
  • 24 x 10/100/1000BASE-T ports and 4 x 1GE/10GE SFP+ uplink ports
Layer 3 Access Switch for 10GE Uplink RG-CS83-24GT4XS-PD
24 x 10/100/1000BASE-T ports, PoE+ supported, providing high-speed network experience for short-distance services
  • Monitor switch statisticsat anytime anywhere
  • Ease of maintenance, saving onsite labor and cost
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
Fixed management ports
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
96 Mpps
132 Mpps
128 Gbps
176 Gbps
3 MB
32,000
8,000
2,500
1,200
Ingress: 3,500
Egress:1,500
VLAN translation
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
4.3 kg (9.48 lbs)
4.6 kg (10.14 lbs)
6.78 kg (14.95 lbs)
6.98 kg (15.39 lbs)
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
RG-PA600I-P-F: 600 W
65 W (non-PoE)
810 W (full PoE load)
75 W (non-PoE)
1570 W (full PoE load)
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
27°C (80.6°F): 51.6 dB
45°C (113°F): 57.4 dB
45°C (113°F): 58.3 dB
Power supply fault alarming
Automatic speed adjustment
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
Communication standard
RG-CS83-PD Series
Super VLAN and private VLAN
Non blocking
RIP, RIPng
PIM-SMv6, PIM-SSM v6
Traffic policing: CAR
Allowlist
ICMP
IP Source Guard
Gateway ARP anti-spoofing
CPP(CPU Protection Policy)
FTP and TFTP
RG-CS83-24GT4XS-PD
RG-CS83-48GT4XS-PD
Mini-GBIC-SX-MM850
Mini-GBIC-LX-SM1310
Mini-GBIC-LH40-SM1310
