RG-S6990-64OC2XS Data Center Networking - 1
RG-S6990-64OC2XS Data Center Networking - 2
RG-S6990-64OC2XS Data Center Networking - 3
RG-S6990-64OC2XS Data Center Networking - 4
RG-S6990-64OC2XS Data Center Networking - 5
RG-S6990-64OC2XS Data Center Networking - 6
RG-S6990-64OC2XS High-Density 64-Port 800GE Fixed Switch for AIGC Intelligent Computing
It supports Ruijie intelligent computing solution technologies including Remote Dynamic Load Balancing (RDLB), Global Dynamic Load Balancing (GDLB) and End-to-Network Load Balancing (ENLB), to improve bandwidth utilization in AIGC intelligent computing scenarios, reduce AI training time, and meet the network deployment requirements of AI and machine learning, high-performance computing, distributed storage, and big data applications.
  • Provides 64 x 800GE ports or 128 x 400GE ports, supports LPO optical transceivers, and provides 2 x 10GE ports;
  • Supports lossless data center networking with RoCE. Leveraging network flow control technologies such as Priority-based Flow Control (PFC) and Explicit Congestion Notification (ECN), together with memory management unit (MMU) optimization, it provides an end-to-end, lossless, and low-latency Remote Direct Memory Access (RDMA) bearer network;
  • Provides hardware-level redundancy to ensure business continuity and uninterrupted network operation;
  • Supports a wide range of link reliability technologies to minimize the impact of network failures on services and ensure stable network operation;
  • Supports automatic network parameter configuration and template-based zero-touch provisioning for rapid deployment and shorter project deployment cycles;
  • Enables AI-powered intelligent O&M with real-time telemetry of key RoCE network metrics, visualization of endpoint status and RoCE services, and support for congestion and packet loss analysis.
64-port 800GE high-density data center switch
RG-S6990-64OC2XS
High-speed, high-density core switch for data centers, delivering 64 x 800GE ports in a compact 2 RU form factor.
Provides scalable, high-performance, high-bandwidth connectivity to meet the networking needs of large-scale data centers.
RDMA enables lossless end-to-end data transmission, helping build a high-performance, low-latency data center network.
Based on PFC + ECN, the solution delivers intelligent traffic management and lossless transmission. RDMA enables direct data transfer without CPU processing, reducing CPU overhead and network latency. It also supports Ruijie AI-Fabric load balancing technologies, including RALB, AILB, and ENLB, to resolve equal-cost multipath routing (ECMP) hash collisions caused by conventional per-flow load balancing, maximize bandwidth utilization for AIGC workloads, and reduce AI training time.
Hardware-level reliability for uninterrupted business operations
Hot-swappable redundant power modules
Hot-swappable redundant fans
1+1 power redundancy enables failover within seconds. Power supplies can be replaced without interrupting network connectivity, providing dual-layer protection for network links.
AI-powered intelligent O&M for simpler, more efficient management
Supports AI-powered ECN auto-tuning, real-time telemetry of key RoCE network metrics, visualization of endpoint status and RoCE services, congestion analysis, and packet loss analysis.
RG-S6990-64OC2XS
440 mm x 760 mm x 86.1 mm (17.32 in. x 29.92 in. x 3.39 in.)
Height
26 kg (57.32 lbs.) (A chassis installed with two power modules and four fan modules)
Switching Capacity
102.4 Tbps
Packet Forwarding Rate
21000 Mpps
Service Port
64 x 800G OSFP ports, each supporting 1-to-2 or 1-to-4 breakout
2 x 1G/10G/25G SFP28 ports
Management Port
USB Port
Slot
4 x fan module slots
Power Consumption
Maximum power consumption: 2814 W
Typical power consumption: 2010 W
Static power consumption: 352 W
PA3000I-F (AC input)
Rated input current: 16 A (100 V AC to 240 V AC)
Power connector: C20
PA3000I-F (HVDC input)
Rated input voltage: 240 V DC
Maximum input voltage: 180 V DC to 320 V DC
Note: At altitudes ranging from 1800 m (5,905.51 ft.) to 3000 m (9,842.52 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 220 m (721.787 ft.) increase in elevation.
Operating altitude: ≤ 3000 m (9,842.52 ft.)
RG-S6990-64OC2XS
Layer 2 protocols
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
Layer 3 protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, LPM Routing, Policy-based Routing, Route-policy, ECMP, WCMP, VRRP
Basic IPv6 protocols
Neighbor Discovery (ND), ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, IPv6 TCP/UDP, SNMPv6, IPv6 Ping/Traceroute, IPv6 RADIUS, IPv6 Telnet/SSH, IPv6 FTP/TFTP, NTPv6, IPv6 MIB for SNMP, IPv6 VRRP, IPv6 QoS
IPv6 features
Data center features
VXLAN, BGP-EVPN
RDMA
PFC, ECN
AI ECN
ECN overlay
RALB, AILB, End-to-Network Load Balance (ENLB)
Visualization
Telemetry
INT
sFLOW/IPFIX
IEEE 802.1p, DSCP, and ToS mapping ACL-based traffic classification Priority marking and re-marking Multiple queue scheduling mechanisms, including SP, WRR, WFQ, DRR, SP+WRR, SP+WFQ, SP+DRR Congestion avoidance mechanisms such as WRED and tail discarding
High availability
GR for RIP/OSPF/BGP, BFD, Device Link Detection Protocol (DLDP), Rapid Ethernet Uplink Protection Protocol (REUP), Rapid Link Detection Protocol (RLDP), power redundancy, fan redundancy, and hot swapping of line cards and power modules
Security features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), RADIUS/TACACS, IPv4/IPv6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, broadcast packet suppression, and hierarchical user management
Management mode
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, temperature alarm
Other protocols
DHCP Client, DHCP Relay, DHCP Server, DNS Client, ARP Proxy, and Syslog
RG-S6990-64OC2XS
Fixed 64 x 800GE ports, 2 x 10GE ports, two power module slots, and four fan module slots.
RG-S6990-64OC2XS-X
Fixed 64 x 800GE ports, 2 x 10GE ports, two power module slots, and four fan module slots, equipped with high-performance CPUs.
PA3000I-F
Power module, hot-swappable, 1+1 redundancy, front-to-rear airflow
FAN80-02-F
Fan module, hot-swappable, 3+1 redundancy, front-to-rear airflow
800GE Optical Transceivers
800G-OSFP-DR8-L
800G DR8 LPO optical transceiver, OSFP form factor, MPO16/APC, 1310 nm, up to 500 m (1,640.42 ft.) transmission distance
800G-OSFP-2DR4-L
800G 2DR4 LPO optical transceiver, OSFP form factor, Dual-MPO12/APC, 1310 nm, up to 500 m (1,640.42 ft.) transmission distance
800G-OSFP-DR8-SM1310
800G DR8 optical transceiver, OSFP form factor, MPO16/APC, 1310 nm, up to 500 m (1,640.42 ft.) transmission distance
800G-OSFP-VR8-MM850
800G VR8 optical transceiver, OSFP form factor, MPO16/APC, 850 nm, up to 50 m (164.04 ft.) transmission distance for OM4 and 30 m (98.43 ft.) transmission distance for OM3
800G-OSFP-2VR4-MM850
800G 2VR4 optical transceiver, OSFP form factor, dual-MPO12/APC, 850 nm, up to 50 m (164.04 ft.) transmission distance for OM4 and 30 m (98.43 ft.) transmission distance for OM3
800G-OSFP-2DR4-SM1310
800G 2DR4 optical transceiver, OSFP form factor, dual-MPO12/APC, 1310 nm, up to 500 m (1,640.42 ft.) transmission distance
10GE Optical Transceivers
10GE Active Optical Cable (AOC), SFP+ form factor, 1 m (3.28 ft.)
10GE AOC, SFP+ form factor, 3 m (9.84 ft.)
10GE AOC, SFP+ form factor, 5 m (16.40 ft.)
10GE LR optical transceiver, SFP+ form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over single-mode fiber (SMF)
XG-SFP-iLR-SM1310-I
10GE LR optical transceiver, SFP+ form factor, Duplex LC, 1310 nm, 1.4 km (4,593.18 ft.) over SMF
XG-LR-SM1310
10G LR optical transceiver, SFP+ form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF
XG-SR-MM850
10G SR optical transceiver, SFP+ form factor, Duplex LC, 850 nm, 300 m (984.25 ft) over multimode fiber (MMF)
10G ER optical transceiver, SFP+ form factor, Duplex LC, 1550 nm, 40 km (131,233.60 ft.) over SMF
10G ZR optical transceiver, SFP+ form factor, Duplex LC, 1550 nm, 80 km (262,467.19 ft.) over SMF
10G LR optical transceiver, SFP+ form factor, BIDI LC, 1270 nm, 10 km (32,808.40 ft.) over SMF
10G LR optical transceiver, SFP+ form factor, BIDI LC, 1330 nm, 10 km (32,808.40 ft.) over SMF
1GE Optical Transceivers
1G SR optical transceiver, SFP form factor, Duplex LC, 850 nm, 550 m (1,804.46 ft.) over MMF
1G LX optical transceiver, SFP form factor, Duplex LC, 1310 nm, 10 km ( 32,808.40 ft.) over SMF
1G LH optical transceiver, SFP form factor, Duplex LC, 1310 nm, 40 km ( 131,233.60 ft.) over SMF
1G LX optical transceiver, SFP form factor, BIDI LC, 1550 nm, 20 km (65,616.80 ft.) over SMF
1G LX optical transceiver, SFP form factor, BIDI LC, 1310 nm, 20 km (65,616.80 ft.) over SMF
1G LX optical transceiver, SFP form factor, BIDI LC, 1550 nm, 3 km (9,842.52 ft.) over SMF
1G LX optical transceiver, SFP form factor, BIDI LC, 1310 nm, 3 km (9,842.52 ft.) over SMF
1G LH optical transceiver, SFP form factor, BIDI LC, 1550 nm, 40 km (131,233.60 ft.) over SMF
1G LH optical transceiver, SFP form factor, BIDI LC, 1310 nm, 40 km (131,233.60 ft.) over SMF
1G ZX optical transceiver, SFP form factor, Duplex LC, 1550 nm, 80 km ( 262,467.19 ft.) over SMF
