RG-IS5200-24GT4XS-UP-DC Switches - 1
RG-IS5200-24GT4XS-UP-DC Switches - 2
RG-IS5200-24GT4XS-UP-DC Switches - 3
RG-IS5200-24GT4XS-UP-DC Switches - 4
RG-IS5200-24GT4XS-UP-DC Switches - 5
RG-IS5200-24GT4XS-UP-DC Switches - 6
RG-IS5200-24GT4XS-UP-DC Switches - 7
RG-IS5200-24GT4XS-UP-DC Industrial Ethernet Switch
RG-IS5200 Series Industrial Switch
This next-generation Gigabit Industrial Ethernet switch is engineered for high resilience, reliability, and performance in demanding industrial environments. It features robust-design and supports easy, flexible DIN rail mounting for seamless integration into industrial control systems.
Engineered for Extreme Environments, Rugged, Reliable, and Resilient
With robust environmental protection and industrial-grade reliability, this switch ensures stable operation under extreme conditions, making it ideal for challenging deployment scenarios.
IP40 Protection
Dust-Resistant for Reliable Indoor Performance
Wide Temperature Tolerance
-40°C to +75°C Industrial-Grade Design
Surge Protection
Built-In 10 kV Lightning Protection
Rugged & Shielded
Anti-Corrosion, Shockproof, and EMC Shielding
Wide Voltage Range and 400m Long-Distance PoE for Convenient Network Deployment
All ports support 90 W output, delivering 400m ultra-long-distance PoE, 4 times farther than typical solutions, ensuring consistent power and connectivity
*1,000Mbps over 200m and 100Mbps over 400m
Unified Networking Central (UNC)
Streamlined Network Management and Maintenance
UNC delivers intelligent operation and maintenance with centralised management, real-time diagnostics, and rapid fault recovery, ensuring reliable performance in complex industrial environments.
RG-IS5200-8GT4XS
RG-IS5200- 8GT4XS-DC
RG-IS5200-8GT4XS-UP-DC
Fixed ports
8x10/100/1000BASE-T ports
8 x 10/100/1000BASE-T ports
RS-485 Port
DIDO
1 x DI, 1 x DO
PoE-REP
Fixed ports
RG-IS5200-8GT4XS
72Mpps
72Mpps
72Mpps
96 Mpps
96 Gbps
96 Gbps
96 Gbps
128 Gbps
512 MB
1GB DDR4
PoE-REP
4Gbps
RG-IS5200-8GT4XS
150mm x 133mm x 86mm
442mm x 220mm x 43.6mm
1.49kg
1.5kg
1.53kg
2.85kg
installation method
PoE-REP
Power supply and Consumption
RG-IS5200-8GT4XS
Power connector type
Terminal block
Not Supported
AC input:
● Rated current:0.6A
HVDC input:
● Rated voltage:240V DC
● Rated current:0.3A
● Rated current: 2 A to 0.5 A
110 V AC:16.7W
220 V AC:16.8W
240 V AC:16.8W
12 V DC: 19.8W
48 V DC: 17.5W
Leakage current
≤3.5mA
Terminal block
● Rated voltage: 56 V DC
● Maximum voltage:
PoE only: 48 V DC
● Rated current: 10 A
PoE not supported: 12 V DC
PoE only: 48 V DC
23.8W (Without PoE)
503.8W (full PoE load)
12V DC input: 36.8W
56V DC input:
● 35.5W (Without PoE)
● 515.5W (full PoE load)
PoE budget: 480 W
PoE budget: 480 W
PoE distance
PoE-REP used:
Ports 5 to 8:
PoE-REP used:
Ports 21 to 24:
PoE-REP
PoE Powered (Input)
PoE power (output)
RG-IS5200-8GT4XS
IP40
AC power port:
Service ports:
DI/DO/RS-485 port:
Service ports:
DI/DO/RS-485 port:
Conducted immunity
Performance criterion: A
AC power port: 3 V
Service port: 3 V
DI/DO/RS-485 port: 3 V
AC power port: 3 V
Service port: 3 V
Voltage dip
AC power port:
Vibration
Shock
IEC61000-3-3,GB17625.2
European Limits
PoE-REP
10 kV
RG-IS5200-8GT4XS
RG-IS5200 Series
40 Gbps
990
Maximum number of MAC address
entries
16000
Maximum number of ARP address
entries
4000
4000
routes
6000
routes
2000
routes
1000
routes
750
1000
750
255
In: 1750, Out: 800
RG-IS5200 Series
ND and ND snooping
 TACAS+
REUP, RLDP, and DLDP
Dual-boot redundancy
Fan fault alarming
Virtualization
SPAN, RSPAN
SNMPv1/v2/v3
RMON (groups 1, 2, 3, and 9)
RG-IS5200-8GT4XS
RG-IS5200-
8GT4XS-DC
RG-IS5200-
8GT4XS-UP-DC
RG-IS5200-
24GT4XS-UP-DC
IPA240-P
IPA60
Accessories
PoE-REP
IS52-shield
GE-SFP-SR-MM850-I
GE-SFP-LR-SM1310-I
XG-SFP-SR-MM850-I
XG-SFP-LR-SM1310-I
