RG-CS65-12XS4VS2QXS-D
Layer 3 Core/Aggregation Switches with 40G Uplinks
High‑Speed Multi‑Rate Ports
1 -
Cybrey switches offer a combination of 1G/2.5G SFP, 10G SFP+, 25G SFP28, and 40G QSFP+ ports, delivering high switching capacity and forwarding performance for bandwidth‑intensive environments.
2 -
Cybrey switches provide complete IPv4/IPv6 routing with OSPF, BGP, IS‑IS, and RIP. They are ideal for use as aggregation switches in large campus networks or core switches in SME networks, enabling flexible interconnection and service delivery.
3
8-Unit Stacking
8-Unit Stacking
3 -
8-Unit Stacking
8-unit stacking for flexible expansion helps maintain continuous service during device failures.
Dual-boot & Dual-bin
4 -
Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
5
Area-based Port Power Supply
5 -
When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
6
N+1 Redundancy
N+1 Redundancy
6 -
N+1 Redundancy
Cybrey switches provide full Layer 3 capabilities, supporting both Layer 2 flat deployment and Layer 3 networking. They deliver fast convergence and fault domain isolation, improve SLA performance, and reduce TCO.
In the Box
× 1
Rack-mount bracket
× 2
Rack-mount guide
× 2
Rack-mount guide rail
× 2
M4 x 8 mm screws
× 10
Rubber pad
× 1
Grounding wire
× 1
Cybrey Cloud, Make Your Business Easy
Interface Configuration
MAC Address Management
Vlan Configuration
802.1X Authentication
RG-CS65-24XS8VS2QXS-D
