RG-CS62-48GT4XS-P
Layer 3 Access Switches with 10G Uplinks
1 -
Equipped with 10G uplinks, access switches eliminate congestion in high-concurrency traffic scenarios.
8-Unit Stacking
8-Unit Stacking
2 -
8-Unit Stacking
8-unit stacking for flexible expansion helps maintain continuous service during device failures.
3
Dual-boot & Dual-bin
3 -
Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
Area-based Port Power Supply
4 -
When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
5
Layer 3 Capabilities
5 -
Access switches with Layer 3 capabilities, including OSPF and 6,000 route entries, help contain the impact of network failures and enable faster recovery than traditional Layer 2 access switches.
6
10 kV Surge Protection & 50°C Operation
6 -
Compared with typical switches that support 6–8 kV surge protection and operation up to 45°C, Cybrey switches deliver 10 kV surge protection and stable performance at temperatures up to 50°C, making them suitable for harsh environments.
In the Box
RG-CS62-48GT4XS-P
× 1
Power cord
× 1
Rack-mount bracket
× 2
M4 x 8 mm screws
× 6
Rubber pad
× 1
Grounding wire
× 1
Power cord retention clip
× 1
Cybrey Cloud, Make Your Business Easy
Interface Configuration
MAC Address Management
Vlan Configuration
802.1X Authentication
