RG-CS63-24MG4XS-UPD
Layer 3 Access Switches with Multi‑Gig Ports and 10G SFP+ Uplinks
Access Switches with 10G Uplinks
1 -
Equipped with 24 x 10/100/1000/2.5GBASE-T ports and 4 x 10G SFP+ uplinks, the access switches deliver high‑speed access for next‑gen Wi‑Fi 8 APs and bandwidth‑hungry clients.
90 W PoE (Class 8)
90 W PoE (Class 8)
2 -
90 W PoE (Class 8)
Class 8 90 W PoE powers high‑power devices like industrial cameras, smart displays, and Wi-Fi 7 APs.
3
8-Unit Stacking
8-Unit Stacking
3 -
8-Unit Stacking
8-unit stacking for flexible expansion helps maintain continuous service during device failures.
Dual-boot & Dual-bin
4 -
Dual-boot for reliable device startup and reboot, and dual-bin for redundant system partitions help maintain stable service operation.
5
Area-based Port Power Supply
5 -
When an optical transceiver experiences a short-circuit fault, Cybrey switches support optical port isolation to help prevent broader system impact.
6
Layer 3 Capabilities
6 -
Cybrey switches provide full Layer 3 capabilities, supporting both Layer 2 flat deployment and Layer 3 networking. They deliver fast convergence and fault domain isolation, improve SLA performance, and reduce TCO.
7
10 kV Surge Protection & 50°C Operation
7 -
Compared with typical switches that support 6–8 kV surge protection and operation up to 45°C, Cybrey switches deliver 10 kV surge protection and stable performance at temperatures up to 50°C, making them suitable for harsh environments.
In the Box
RG-CS63-24MG4XS-UPD
× 1
Rack-mount bracket
× 2
Rack-mount guide
× 2
Rack-mount guide rail
× 2
M4 x 8 mm screws
× 10
Rubber pad
× 1
Grounding wire
× 1
Cybrey Cloud, Make Your Business Easy
Interface Configuration
MAC Address Management
Vlan Configuration
802.1X Authentication
