RG-SAP750-SP Wireless - 1
RG-SAP750-SP Wireless - 2
RG-SAP750-SP Wireless - 3
RG-SAP750-SP Wireless - 4
RG-SAP750-SP Wireless - 5
RG-SAP750-SP Wireless - 6
RG-SAP750-SP Wireless - 7
RG-SAP750-SP Wireless - 8
WaaS Series Indoor Access Point
RG-SAP750-SP
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
Dual-Radio Design, Up to 1.167 Gbps Data Rate
5 GHz signals provide stable and uninterrupted connection, while 2.4 GHz signals enable long-distance transmission, ensuring stable access for numerous wireless clients.
300Mbps
867Mbps
Built-in Smart Antennas,
Superior Roaming Experience and Service Continuity
The built-in smart antennas can identify the directions of clients around the AP. Integrated with Ruijie's proprietary roaming algorithm, the AP also supports 802.11k/v/r protocols. Intelligent channel planning and accurate wireless positioning enable clients to associate with the optimal AP.
Automatic Provisioning, Simplified Deployment
Ruije's wireless controller delivers the configuration in batches, eliminating the need to pre-configure the AP before installation. This enables automatic provisioning and simplified deployment, reducing implementation and maintenance complexity.
WIS Cloud enables network-wide configuration and optimization, eliminating the need for onsite operations.
Network issue warnings allow wireless networks to be monitored anytime and anywhere.
Go to WIS Cloud >>
Cloud O&M
Real-Time Warning
Fault Locating
RG-SAP750-SP
Four spatial streams
Channels:
● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15 )
Two spatial streams
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 867 Mbps
● Radio 2 – 5 GHz: 6.5 Mbps to 867 Mbps (MCS0 to MCS9)
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 4.3 dBi.
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.7 dBi.
1 x 10/100/1000BASE-T port
● Software initialization status
● Wireless user online status
Main unit: 194 mm x 194 mm x 37 mm (7.64 in. x 7.64 in. x 1.46 in.)
Shipping: 460 mm x 360 mm x 242 mm (18.11 in. x 14.17 in. x 9.53 in.)
Main unit: 0.42 kg (1.0 lbs)
Mounting bracket: 0.07 kg (0.2 lbs)
Shipping: 0.87 kg (2.0 lbs)
● 12 V DC/1.5 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power supply needs to be purchased independently.
● DC power: 12.95 W
● 802.3af (PoE): 12.95 W
● Idle mode: 6 W
Storage altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.)
Operating altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.)
128 MB DRAM, 32 MB flash
● Maximum transmit power: 26 dBm (398.11 mW)
RG-SAP750-SP
2.4 GHz 802.11b
–88 dBm
2.4 GHz 802.11g
21 dBm
–76 dBm
19 dBm
–70 dBm
2.4 GHz 802.11n (HT20)
21 dBm
–83 dBm
19 dBm
–65 dBm
2.4 GHz 802.11n (HT40)
21 dBm
–62 dBm
5 GHz 802.11a
21 dBm
–76 dBm
19 dBm
–70 dBm
5 GHz 802.11n (HT20)
–83 dBm
–65 dBm
5 GHz 802.11n (HT40)
19 dBm
–62 dBm
5 GHz 802.11ac (VHT20)
17 dBm
–57 dBm
5 GHz 802.11ac (VHT40)
19 dBm
5 GHz 802.11ac (VHT80)
19 dBm
–76 dBm
–51 dBm
Note Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
RG-SAP750-SP
AP_RGOS 11.1(9)B1P37 or later
256
● Radio 1: 2.4 GHz, up to 100 connected STAs
● Radio 2: 5 GHz, up to 156 connected STAs
75
Maximum number of WLAN IDs
Maximum number of associated STAs per WLAN: 256
MU and TAG device locating
PSK , web, 802.1x and MSCHAPv2 authentication
SMS-based and QR code-based guest authentication, and MAB authentication (used with RG-WS series wireless controller)
Inbound ACL based on Layer 2 interfaces
Inbound ACL based on Layer 3 interfaces
Inbound ACL based on wireless interfaces
MAC address table size: 1,024
Jumbo frame length: 1,518
Ethernet II
IEEE802.1p and IEEE802.1Q
Maximum number of CVIs: 40
Maximum number of SVIs: 40
VLAN ID range: 1–4,094
ARP entry aging, proxy ARP, and IP address conflict detection between downlink users
NAT, FTP ALG and DNS ALG
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 ping, IPv6 tracert
Maximum number of IPv6 addresses configured on each Layer 3 interface: 16
Multicast, Multicast-to-unicast conversion
RG-SAP750-SP
Big data capabilities
RG-SAP750-SP
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, IEC 62368-1, EN 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, and EN IEC 62311
Note:Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
RG-SAP750-SP
Four spatial streams, peak data rate of 1.167 Gbps
●     Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 300 Mbps
●     Radio 2: 5 GHz: two spatial streams, 2x2 MU-MIMO, peak data rate of 867 Mbps
Compliance with IEEE 802.11a/b/g/n and 802.11ac Wave2 standards
Fat/Fit/Cloud mode switchover
One uplink electrical port
●     The DC power supply needs to be purchased separately, and the output voltage/current must be 12 V/1.5 A.
