RG-S5300-24GT4XS-E Switches - 1
RG-S5300-24GT4XS-E Switches - 2
RG-S5300-24GT4XS-E Switches - 3
RG-S5300-24GT4XS-E Switches - 4
RG-S5300-24GT4XS-E Switches - 5
RG-S5300-24GT4XS-E Switches - 6
RG-S5300-24GT4XS-E Switches - 7
RG-S5300-24GT4XS-E Switches - 8
RG-S5300-24GT4XS-E Switches - 9
RG-S5300-24GT4XS-E Switches - 10
RG-S5300-24GT4XS-E Switches - 11
RG-S5300-24GT4XS-E Switches - 12
RG-S5300-24GT4XS-E Switches - 13
RG-S5300-24GT4XS-E Switches - 14
RG-S5300-24GT4XS-E Switches - 15
RG-S5300-24GT4XS-E Switches - 16
RG-S5300-24GT4XS-E 24-Port GE Layer 3 Managed Access Switch, 4-Port 10GE Uplink
Full-gigabit access switch for large-sized enterprise and campus LANs, gigabit access switch for business applications such as hospitals, libraries, convention and exhibition centers, and websites
  • Rich port types, 24 x 10/100/1000BASE-T ports for access, 4 x 1GE/10GE SFP+ ports for uplink
  • Abundant QoS policies for flexible resource allocation, making congestion a thing of the past
Key Specification View More
Layer 3 GE Managed Access Switch RG-S5300-24GT4XS-E
Gigabit access switch for large-sized enterprise and campus LANs, with 4 x 1GE/10GE SFP+ uplink ports for high-speed data transmission,
24 x 10/100/1000BASE-T ports, providing high-speed network access for short-distance services and flexible networking
Enhanced Network Robustness
With multi-plane flow classification and control capabilities for MAC flow, IP flow and application flow, accurate resource allocation for multi-service traffic makes
congestion a thing of the past, delivering high-quality networks.
achieving automatic O&M.
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
RG-S5300-24GT4XS-P-E
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
115 Mpps
158 Mpps
115 Mpps
154 Gbps
211 Gbps
154 Gbps
3 MB
32,000
ND table size
2,500
1,200
Ingress: 3,500
Egress: 1,500
Number of IGMP groups
2,500
Number of MLD groups
Number of VRFs
512
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
AC input:
AC input:
Maximum input current: 2 A
AC input:
● Rated input voltage: 100 V to 240 V AC, 50/60 Hz
55 W
65 W (without PoE load)
410 W (full PoE load)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
442.0 mm x 220.0 mm x 43.6 mm(17.40 in. x 8.66 in. x 1.72 in.)
550 mm x 350 mm x 186 mm (21.65 in. x 13.78 in. x 7.32 in.)
2.7 kg (5.95 lbs)
3.0 kg (6.61 lbs)
3.0 kg (6.61 lbs)
3.83 kg (8.44 lbs)
4.20 kg (9.26 lbs)
4.60 kg (10.14 lbs)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
200,000 hours (about 22 years)
27°C (80.6°F): 40.9 dB
45°C (113°F): 48.8 dB
27°C (80.6°F): 40.3 dB
45°C (113°F): 53.1dB
27°C (80.6°F): 33.5 dB
45°C (113°F): 53.9 dB
Air discharge: 8 kV
Contact discharge: 6 kV
Service port: 10 kV (common mode)
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
RG-S5300-E Series
Super VLAN and private VLAN
Basic QinQ and selective QinQ
Auto errdisable recovery
BPDU filter
Port fast
Root guard
ERPS (G.8032 v1/v2), sing ring, tangent ring, intersecting ring, and load balancing
MAC address filtering
Non blocking
IPv6 addressing, IPv6 ping, and IPv6 tracert
GRE tunnel
IPv4 and IPv6 static routing
OSPFv2 and OSPFv3
Routing policy
IPv4/VRF
IPv4/IPv6 PBR
IGMPv1/v2 snooping
PIM-DM, PIM-SM, PIM-SSM, PIM SMv6, and PIM-SSMv6
MLDv1/v2 and MLD proxy
MLDv1/v2 snooping
Time based ACLs, ACL 80, and IPv6 ACL
RADIUS
Global IP-MAC binding
ICMP
Port- and MAC address-based 802.1X authentication
MAB authentication
Local and remote stacking
SNTP
CLI (Telnet/Console)
SNMP v1/v2c/c3
Web
Syslog/Debugging
MACC
RG-S5300-24GT4XS-P-E:
RG-S5300-24GT4XS-E
24 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports
RG-S5300-48GT4XS-E
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports
24 x 10/100/1000BASE-T ports, supporting PoE/PoE+ and a maximum PoE output power of 370 W, 4 x 1GE/10GE SFP+ ports
Mini-GBIC-SX-MM850
Mini-GBIC-LX-SM1310
Mini-GBIC-LH40-SM1310
XG-SFP-T
10GBASE-T, copper SFP+ transceiver, RJ45, 100 m over Cat 6a/7
