RG-AP680P-L Small & Medium Enterprise Networking - 1
RG-AP680P-L Small & Medium Enterprise Networking - 2
RG-AP680P-L Small & Medium Enterprise Networking - 3
RG-AP680P-L Small & Medium Enterprise Networking - 4
RG-AP680P-L Small & Medium Enterprise Networking - 5
RG-AP680P-L Small & Medium Enterprise Networking - 6
RG-AP680P-L Small & Medium Enterprise Networking - 7
Product Overview
Product Highlights
Wi-Fi 6 certification
Up to 1024 client connections
RG-AP680P-L
Unit dimensions
Main unit: 3.3 kg (7.28 lbs)
6.5 kg (14.33 lbs)
RG-AP680P-L
Operating frequencies
Radio 1: 802.11b/g/n/ax
Radio 2: 802.11a/n/ac/ax
Data rates
Radio 1: 2.4 GHz, 1.147 Gbps
Radio 2: 5 GHz, 4.804 Gbps
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
Antenna gain
2.4 GHz: 5 dBi
5 GHz: 5.5 dBi
Maximum transmit power
Thailand
2.4 GHz to 2.4835 GHz: 20 dBm
Power increment
Increment of 1 dBm
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP680P-L
2.4 GHz 802.11b
24 dBm
–94 dBm
24 dBm
–91 dBm
23 dBm
–90 dBm
22 dBm
–88 dBm
2.4 GHz 802.11g
24 dBm
–89.5 dBm
–83 dBm
–79 dBm
21 dBm
–73 dBm
2.4 GHz 802.11n (HT20)
24 dBm
–86 dBm
21 dBm
–68 dBm
2.4 GHz 802.11n (HT40)
24 dBm
–83 dBm
21 dBm
–65 dBm
2.4 GHz 802.11ax (HE20)
24 dBm
–86 dBm
19 dBm
–68 dBm
2.4 GHz 802.11ax (HE40)
24 dBm
–83 dBm
19 dBm
–65 dBm
5 GHz 802.11a
23 dBm
–89.5 dBm
22 dBm
–83 dBm
22 dBm
–79 dBm
–73 dBm
5 GHz 802.11n (HT20)
23 dBm
–86 dBm
–68 dBm
5 GHz 802.11n (HT40)
23 dBm
–83 dBm
–65 dBm
5 GHz 802.11ac (VHT20)
23dBm
–86 dBm
19 dBm
–61 dBm
5 GHz 802.11ac (VHT40)
23 dBm
–83 dBm
19 dBm
–57 dBm
5 GHz 802.11ac (VHT80)
23 dBm
–80 dBm
19 dBm
5 GHz 802.11ax (HE20)
23 dBm
–86 dBm
16 dBm
–58 dBm
5 GHz 802.11ax (HE40)
23 dBm
–83 dBm
16 dBm
–54 dBm
5 GHz 802.11ax (HE80)
23 dBm
–80 dBm
16 dBm
–52 dBm
5 GHz 802.11ax (HE160)
23 dBm
–77 dBm
16 dBm
–49 dBm
Bluetooth Radio
RG-AP680P-L
Bluetooth 5.1
Maximum antenna gain
2 dBi
10 dBm
Receive sensitivity
–88 dBm (@BLE)
Ports Specifications
RG-AP680P-L
● Auto MDI/MDIX crossover
● 802.3az EEE
1 x 100/1000BASE-T port
● 802.3az EEE
3 x single-color RSSI LEDs
RG-AP680P-L
Overall power consumption
● Idle mode: 10 W
RG-AP680P-L
Anti-corrosion rating
EN300 0019 Class C
IP68
RG-AP680P-L
Security standards
EN 62368-1
EN 60950-22
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
EN IEC 62311
FCC Part 15
Applicable Software Version
RG-AP680P-L
RGOS11.9(6)W3B6 or higher
RG-AP680P-L
200
1024
 Note
Maximum number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP680P-L
Dynamic ACL assignment
Routing and Switching
RG-AP680P-L
IP service
NAT, FTP ALG, DNS ALG
IPv6 basics
RG-AP680P-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
RG-AP680P-L
Up to eight spatial streams
