RG-S6160-48XMG4VS2CQ-UP-X Switches - 1
RG-S6160-48XMG4VS2CQ-UP-X Switches - 2
RG-S6160-48XMG4VS2CQ-UP-X Switches - 3
RG-S6160-48XMG4VS2CQ-UP-X Switches - 4
RG-S6160-48XMG4VS2CQ-UP-X Switches - 5
RG-S6160-48XMG4VS2CQ-UP-X Switches - 6
RG-S6160-48XMG4VS2CQ-UP-X 48-Port 10GE Managed Multi-GE Access Switches with 100GE Uplink Ports
100/1000/2.5G/5G/10GBASE-T ports, PoE/PoE+/PoE++, 4 x 25GE SFP28 ports and 2 x 100GE QSFP28 ports, offering flexible networking options to build high-performance campus networks
  • Rich port types, 48 x 100/1000/2.5G/5G/10GBASE-T ports, 4 x 10GE/25GE SFP28 ports and 2 x 40GE/100GE QSFP28 ports for uplink
  • VSU for flexible networking and high performance
  • Hardware redundancy for guaranteed service continuity and network connectivity
  • Layer 3 routing control, adaptive to multiple services, enabling efficient and guaranteed data transmission
  • Paired with RG-UNC for simplified and efficient O&M
RG-S6160-X series next-generation multi-GE switches are developed by Ruijie. With an advanced hardware architecture and Ruijie's modular operating system, the RG-S6160-X delivers fast hardware processing and smooth operation experience.
The RG-S6160-X offers flexible multi-GE access (10GE/5GE/2.5GE/1GE) and high-performance 40GE/100GE uplink ports, meeting the requirements of high-density access and high-performance aggregation. It also supports high-power PoE++ technology, with a maximum PoE output of 90 W to meet the power supply requirements of various terminals.
● Ports 1 to 24 support PoE/PoE+/PoE++
● Ports 25 to 48 support PoE/PoE+
Pre-installed 3
1160.64 Mpps
1560 Gbps
Number of global MAC addresses:
● 128K(Default)
● 384K(Max)
3 x pluggable fan modules
2+1 redundancy
Monitoring of the power supply model and status Power supply failure alarming
Automatic speed adjustment
● Maximum input current: 8 A
● Maximum input voltage: 90 V AC to 143 V AC, 47 Hz to 63 Hz
● Maximum input current: 12 A
● Maximum input voltage: 180 V AC to 264 V AC, 47 Hz to 63 Hz
Maximum PoE output power
The maximum power depends on the configured power supply 2 x RG-PA1000I-P-F: 1600 W (200 V AC to 240 V AC)
RG-S6160-X Series
Stateless Auto Configuration
IPv4/IPv6 PBR
IGMPv1/v2/v3 and IGMP proxy
MLD snooping
Multicast source IP address check Multicast source port check
ACL80 and IPv6 ACL
Multi-AAA
RADIUS and TACAS+
Filtering of invalid MAC addresses Broadcast storm suppression Hierarchical management of administrators and password protection BPDU guard
Loose and strict RPF uRPF ignoring default routes
GR for RIP, OSPF, and BGP
SPAN, RSPAN, and ERSPAN
SNMP v1/v2/c3
Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups RMON used to implement Ethernet statistics, historical statistics, and alarm functions
OpenFlow Special 1.3 Flow table analysis defined by all protocols Transmission of specified packets to the controller Configuring the controller's IP address and port Notifying port status changes to the controller
Ruijie Could-based management
Organization
Standards and Protocol
IETF
RFC 1058 Routing Information Protocol (RIP)
RFC 1157 A Simple Network Management Protocol (SNMP)
RFC 1305 Network Time Protocol Version 3 (NTP)
RFC 1349 Internet Protocol (IP)
RFC 1350 TFTP Protocol (revision 2)
RFC 1519 CIDR
RFC 1583 OSPF Version 2
RFC 1591 Domain Name System Structure and Delegation
RFC 1643 Ethernet Interface MIB
RFC 1757 Remote Network Monitoring (RMON)
RFC 1812 Requirements for IP Version 4 Router
RFC 1901 Introduction to Community-based SNMPv2
RFC 1902-1907 SNMP v2
RFC 1918 Address Allocation for Private Internet
RFC 1981 Path MTU Discovery for IP version 6
RFC 1997 BGP Communities Attribute
RFC 2131 Dynamic Host Configuration Protocol (DHCP)
RFC 2132 DHCP Options and BOOTP Vendor Extensions
RFC 2236 IGMP
RFC 2328 OSPF Version 2
RFC 2385 Protection of BGP Sessions via the TCP MD5 Signature Option
RFC 2439 BGP Route Flap Damping
RFC 2460 Internet Protocol, Version 6 (IPv6)
RFC 2461 Neighbor Discovery for IP Version 6 (IPv6)
RFC 2462 IPv6 Stateless Address Auto configuration
RFC 2463 Internet Control Message Protocol for IPv6 (ICMPv6)
RFC 2545 Use of BGP 4 Multiprotocol Extensions for IPv6 Inter Domain Routing
RFC 2571 SNMP Management Frameworks
RFC 2711 IPv6 Router Alert Option
RFC 2787 Definitions of Managed Objects for the Virtual Router Redundancy Protocol
RFC 2863 The Interfaces Group MIB
RFC 2865 Remote Authentication Dial In User Service (RADIUS)
RFC 2918 Route Refresh Capability for BGP 4
RFC 2925 Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations (Ping only)
RFC 2934 Protocol Independent Multicast MIB for IPv4
RFC 3046 DHCP Option82
RFC 3065 Autonomous System Confederation for BGP
RFC 3101 OSPF Not so stubby area option
RFC 3137 OSPF Stub Router Advertisement sFlow
RFC 3417 (SNMP Transport Mappings)
RFC 3418 Management Information Base (MIB) for the Simple Network Management Protocol (SNMP)
RFC 3509 Alternative Implementations of OSPF Area Border Routers
RFC 3513 IP Version 6 Addressing Architecture
RFC 3575 IANA Considerations for RADIUS
RFC 3579 RADIUS Support For EAP
RFC 3623 Graceful OSPF Restart
RFC 3768 VRRP
RFC 3810 Multicast Listener Discovery Version 2 (MLDv2) for IPv6
RFC 3973 PIM Dense Mode
RFC 4022 MIB for TCP
RFC 4271 A Border Gateway Protocol 4 (BGP 4)
RFC 4273 Definitions of Managed Objects for BGP 4
RFC 4360 BGP Extended Communities Attribute
RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP)
RFC 4486 Subcodes for BGP Cease Notification Message
RFC 4552 Authentication/Confidentiality for OSPFv3
RFC 4724 Graceful Restart Mechanism for BGP
RFC 4750 OSPFv2 MIB partial support no SetMIB
RFC 4760 Multiprotocol Extensions for BGP 4
RFC 4940 IANA Considerations for OSPF
RFC 5065 Autonomous System Confederation for BGP
RFC 5187 OSPFv3 Graceful Restart
RFC 5340 OSPFv3 for IPv6
RFC 5492 Capabilities Advertisement with BGP 4
RFC 6620 FCFS SAVI
RFC 768 User Datagram Protocol (UDP)
RFC 783 TFTP Protocol (revision 2)
RFC 792 Internet Control Message Protocol (ICMP)
RFC 793 Transmission Control Protocol (TCP)
RFC 813 Window and Acknowledgement Strategy in TCP
RFC 815 IP datagram reassembly algorithms
RFC 826 Ethernet Address Resolution Protocol (ARP)
RFC 854 Telnet Protocol
RFC 959 File Transfer Protocol (FTP)
IEEE
IEEE 802.2 Logical Link Control
IEEE 802.1ab Link Layer Discovery Protocol
IEEE 802.1ad Provider Bridges
IEEE 802.1ax/IEEE802.3ad Link Aggregation
IEEE 802.1D Media Access Control (MAC) Bridges
IEEE 802.1D Spanning Tree Protocol
IEEE 802.1Q Virtual Bridged Local Area Networks (VLAN)
IEEE 802.1s Multiple Spanning Tree Protocol
IEEE 802.1w Rapid Spanning Tree Protocol
IEEE 802.3ad Link Aggregation Control Protocol (LACP)
IEEE Std 802.3x Full Duplex and flow control
*IEEE 802.3az Energy Efficient Ethernet
48 x 100/1000/2.5G/5G/10GBASE-T ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE/100GE QSFP+ ports
25GE
VG-SFP-AOC7M(M)
