20 x SFG ports, 2 x 100GE QSFP28 ports
RG-S7620-20SFX2CQ20 x SFX ports, 2 x 100GE QSFP28 ports
RG-S7610-10SFG2CQ10 x SFG ports, 2 x 100GE QSFP28 ports
RG-S7610-10SFX2CQ10 x SFX ports, 2 x 100GE QSFP28 ports
RG-S7610-10SFXP2CQ10 x 10GE SFXP high-density CWDM ports (160 x 10GE optical ports),2 x 100GE optical ports
RG-S7610-10SFMP2CQ10 x 2.5GE SFMP high-density CWDM ports (160 x 2.5GE optical ports),2 x 100GE optical ports
| Port specifications |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
| Fixed service port |
10 x SFG ports (80 x 1GE logical channels) 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE) |
10 x SFX ports (80 x 10GE logical channels) 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE) |
20 x SFG ports (160 x 1GE logical channels) 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE) |
20 x SFX ports (160 x 10GE logical channels) 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE) |
| Module service port |
M7600-4GT4VS: ● 4 x 10/100/1000BASE-T ports ● 4 x 1GE/10GE/25GE SFP28 ports M7600-2CQ: ● 2 x 40GE/100GE QSFP28 ports |
| Module slot |
2 x power module slots 4 x fan module slots 1 x expansion module slot |
2 x power module slots 3 x fan module slots 1 x expansion module slot |
| Expansion module |
M7600-2CQ M7600-4GT4VS |
| Power module |
RG-PA550I II-F |
| Fan module |
S7610-FAN I-F |
S7620-FAN I-F |
| Fixed management port |
1 x RJ45 console port 1 x RJ45 MGMT port |
| USB |
1 x USB 2.0 port |
RG-S7610-10SFMP2CQ |
RG-S7610-10SFXP2CQ |
10 x SFMP ports (160 x 1GE logical channels) 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE) |
10 x SFXP ports (160 x 10GE/1GE logical channels) 2 x 40GE/100GE QSFP28 ports (supporting 4 x 10GE/4 x 25GE) |
| Module slot |
2 x power module slots 4 x fan module slots (3+1 redundancy, and at least three fan modules required) 1 x expansion module slot (1+1 redundancy) |
| Expansion module |
| Power module |
RG-PA550I II-F |
| Fan module |
S7610-FAN I-F |
| USB |
1 x USB 2.0 port |
| System specifications |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
| Packet forwarding rate ^*1^ |
714 Mpps |
1786 Mpps |
833 Mpps |
2976 Mpps |
| System switching capacity ^*2^ |
960 Gbps |
2.4 Tbps |
1.12 Tbps |
4 Tbps |
| CPU |
Quad-core CPU, each core with the clock speed of 2.0 GHz |
| BootROM |
16 MB |
| Flash memory |
8 GB |
| Memory |
4 GB DDR4 |
| Switch buffer |
36 MB |
1190 Mpps |
2976 Mpps |
1.6 Tbps |
4 Tbps |
| CPU |
| BootROM |
16 MB |
| Flash memory |
16 GB |
| Memory |
4 GB DDR4 |
| Switch buffer |
36 MB |
| Power supply and consumption |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
| Power supply |
2 x pluggable power modules |
| Power input |
RG-PA550I II-F (AC input): - Rated input voltage: 100 V AC to 240 V AC, 50/60 Hz - Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz - Rated input current: 3.5 A to 7.2 A - Maximum input current: 7.2 A |
| Maximum output power |
RG-PA550I II-F: 550 W |
| Module power consumption |
270 W |
450 W |
| Power supply |
| Power input |
RG-PA550I II-F (AC input): ● Rated input voltage: 100 V AC to 240 V AC, 50/60 Hz ● Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz ● Rated input current: 3.5 A to 7.2 A ● Maximum input current: 7.2 A |
400 W |
| Dimensions and Weight |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
442 mm x 388 mm x 44 mm (17.40 in. x 15.28 in. x 1.73 in.) |
442 mm x 388 mm x 88 mm (17.40 in. x 15.28 in. x 3.46 in.) |
590 mm x 543 mm x 196 mm (23.23 in. x 21.38 in. x 7.72 in.) |
590 mm x 543 mm x 259 mm (23.23 in. x 21.38 in. x 10.20 in.) |
| Rack height |
1 RU |
2 RU |
| Unit weight |
6.88 kg (15.17 lbs, with 4 fan modules) |
11.02 kg (24.29 lbs, with 3 fan modules) |
| Shipping weight |
9.73 kg (21.45 lbs) |
14.4 kg (31.75 lbs) |
442 mm x 420 mm x 43.6 mm (17.40 in. X 16.54 in. X 1.72 in.) (excluding fan modules and power handles) 482.6 mm x 420 mm x 43.6 mm (19.00 in. X 16.54 in. X 1.72 in.) (including mounting brackets, and excluding fan modules and power handles) |
| Rack height |
1 RU |
| Unit weight |
7.0 kg (15.43 lbs) (fan modules included during delivery, excluding power modules, expansion modules, and packaging materials) |
| Environment and reliability |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
| Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: --40°C to +70°C (--40°F to +158°F) Note: At an altitude between 1,800 m (5,905.51 ft.) and 5,000 m (16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F). |
| Humidity |
| Altitude |
Operating altitude: 0 m to 5000 m (0 ft. to 16,404.20 ft.) Storage altitude: 0 m to 5000 m (0 ft. to 16,404.20 ft.) |
| Mean time between failure (MTBF) |
683,104.8 hours (about 78 years) |
360,474 hours (about 41 years) |
| Fan |
4 x pluggable fan modules (pre-installed) |
3 x pluggable fan modules (pre-installed) |
| Heat dissipation |
Front-to-back airflow |
| Acoustic noise |
27°C (80.6°F): 56 dB 45°C (113°F): 72 dB |
| Power module redundancy |
1+1 redundancy |
| Fan redundancy |
3+1 redundancy, and at least three fan modules required |
2+1 redundancy, and at least two fan modules required |
| Module hot swapping |
Supported |
| Power module hot swapping |
Supported |
| Fan module hot swapping |
Supported |
| Cable hot swapping |
Supported |
| Power supply monitoring |
Monitoring of the power supply model and status Power supply failure alarming |
| Fan monitoring |
Fan speed adjustment: 256 levels (Only automatic adjustment is supported.) Fan failure alarm |
| Temperature monitoring |
Temperature alarm and over-temperature protection |
| ESD |
| Surge protection |
MGMT port: 4 kV Power port: 6 kV |
| Temperature |
| Humidity |
| Altitude |
302000 hours (about 34 years) |
| Fan |
| Heat dissipation |
| Acoustic noise |
1+1 redundancy |
| Fan redundancy |
Supported |
Supported |
Supported |
Supported |
| Fan monitoring |
| ESD |
| Surge protection |
Management port: 4 kV (management port) 4GT port of the M7600-4GT4VS expansion module: 6 kV |
| Certifications and regulatory compliance |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
| Safety regulation |
IEC 62368-1: 2018 EN 62368-1: 2014+A11:2017 |
| EMC regulation |
EN 55032:2015+A1:2020 EN 61000-3-2013+A1:2019+A2:2021 EN IEC 61000-3-2:2019+A1:2021 EN 55035:2017+A11:2020 EN 300386 V2.2.1 |
| RoHS |
European RoHS Directive 2011/65/EU & Amendment(EU) 2015/863 |
| Device Model |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
4 |
| VSU bandwidth |
400 Gbps |
| Maximum number of SVIs |
4,094 |
128,000 |
96,000 |
80,000 |
350,000 (shared with IPv6 routes) |
65,000 |
4,000 |
2,000 |
4,000 |
2,000 |
1,024 |
| Maximum number of ACEs |
In: 28,000, Out: 4,000 |
| Device Model |
RG-S7610-10SFG2CQ |
RG-S7610-10SFX2CQ |
RG-S7620-20SFG2CQ |
RG-S7620-20SFX2CQ |
| Ethernet switching |
| Maximum number of VLANs that can be created: 4,094 |
| Voice VLAN |
| MAC address-based, port-based, protocol-based, and IP subnet-based VLAN assignment |
| GVRP |
| Basic QinQ and selective QinQ |
| STP (IEEE 802.1.d), RSTP (IEEE 802.1w), and MSTP (IEEE 802.1s) |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| IP service |
Static ARP |
| DHCP client |
| DHCP relay |
| DHCP server |
| DHCP snooping |
| DHCPv6 server, DHCPv6 client, DHCPv6 relay, and DHCPv6 snooping |
| GRE tunnel |
| IP routing |
IPv4/IPv6 static routing |
| RIP and RIPng |
| OSPFv2 and OSPFv3 Graceful restart (GR) |
| IPv4 IS-IS IPv6 IS-IS |
| BGP4 and BGP4+ |
| IPv4/IPv6 VRF |
| IPv4/IPv6 PBR |
| Multicast |
IGMPv1/v2/v3 |
| IGMPv1/v2/v3 snooping |
| IGMP fast leave |
| PIM-SM |
| PIM-DM |
| PIM-SSM for IPv4 and IPv6 |
| MSDP to achieve inter-domain multicast |
| MLDv1 and MLDv2 |
| MLD snooping |
| PIM-SMv6 |
| Multicast querier |
| MPLS |
6PE/6VPE model interconnection with the IPv4/IPv6 MPLS backbone network |
| MPLS MIB (RFC 1273, RFC 4265, and RFC 4382) (MPLS MIB, MPLS L3VPN STD MIB, MPLS LSR STD MIB, and MPLS VPN MIB) |
| ACL and QoS |
Standard IP ACLs (hardware ACLs based on IP addresses) |
| Expert-level ACLs (hardware ACLs based on the source and destination IP addresses and ports, and protocol type) |
| IPv6 ACL |
| ACL 80 |
| Expert-level ACLs (hardware ACLs based on |
| ACL redirection |
| Port-based rate limiting |
| Traffic classification based on 802.1p priorities, DSCP priorities, and IP precedences |
| Congestion management: SP, WRR, DRR, WFQ, SP+WRR, SP+DRR, and SP+WFQ |
| Eight queues on each port |
| Security |
Multiple AAA modes |
| TACACS+ |
| IEEE 802.1X authentication, MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
| Web authentication |
| Hypertext Transfer Protocol Secure (HTTPS) |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| Port security |
| IP source guard |
| SAVI |
| ARP spoofing prevention |
| CPP and NFPP |
| Various attack defense functions including NFPP, ARP anti-spoofing, DHCP/DHCPv6 attack defense, ICMP attack defense, ND attack defense, IP scanning attack defense, and customizing attack defense packet types |
| IPv4 uRPF and IPv6 uRPF Strict and loose uRPF Default route exclusion configuration during uRPF checks |
| Reliability |
REUP |
| Rapid Link Detection Protocol (RLDP), Layer 2 link connectivity detection, unidirectional link detection, and VLAN-based loop control |
| Data Link Detection Protocol (DLDP) |
| IPv4 VRRP v2/v3 and IPv6 VRRP v3 |
| BFD |
| Link monitoring, fault notification, and remote loopback based on 802.3ah (EFM) |
| Hot swapping of power modules and fan modules |
| Device Virtualization |
VSU |
| NMS and Maintenance |
RSPAN and ERSPAN |
| sFlow (network detection technology based on packet sampling, which is mainly used for traffic statistics and analysis in heavy-traffic scenarios) |
| NTP and SNTP |
| FTP and S TFTP |
| SNMP v1/v2/v3 |
| RMON (1, 2, 3, 9) Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups |
| NETCONF |
| CWMP |
| gRPC |
| OpenFlow Special 1.0/1.3 Flow table analysis defined by all protocols Transmission of specified packets to the controller Configuring the controller's IP address and port Notifying port status changes to the controller |
| VXLAN |
EVPN VXLAN tunnel establishment VLAN access to VXLAN IPv4 over IPv4 Distributed gateway IPv6 over IPv4 Using an SVI to connect to the VXLAN network Using a routed interface to connect to the VXLAN network Proxy ARP (replying with the actual MAC address)) ND proxy (replying with the actual MAC address) ND reply (replying with the actual MAC address) VXLAN EVPN VXLAN static route Anycast gateway VXLAN bridging mode VXLAN routing mode Proxy ARP (replying with the gateway MAC address) Configuring the UDP port number in VXLAN packets Static VXLAN tunnel creation |
| Model |
Description |
| RG-S7610-10SFG2CQ |
CWDM switch, 1 RU, 10 x SFG ports (80 x 1GE logical channels), 2 x 40GE/100GE QSFP28 ports, 2 x power module slots, 1 x expansion module slot. |
| RG-S7610-10SFX2CQ |
CWDM switch, 1 RU, 10 x SFX ports (80 x 10GE logical channels), 2 x 40GE/100GE QSFP28 ports, 2 x power module slots, 1 x expansion module slot. |
| RG-S7620-20SFG2CQ |
CWDM switch, 2 RU, 20 x SFG ports (160 x 1GE logical channels), 2 x 40GE/100GE QSFP28 ports, 2 x power module slots, 1 x expansion module slot. |
| RG-S7620-20SFX2CQ |
CWDM switch, 2 RU, 20 x SFX ports (160 x 10GE logical channels), 2 x 40GE/100GE QSFP28 ports, 2 x power module slots, 1 x expansion module slot. |
CWDM switch, 1 RU, 10 x SFMP 40GE ports, 2 x fixed 100GE uplink ports, and 1 x expansion slot. Port speeds support backward compatibility. |
CWDM switch, 1 RU, 10 x SFXP 160GE ports, 2 x fixed 100GE uplink ports, and 1 x expansion slot. Port speeds support backward compatibility. |
| Model |
Description |
| M7600-2CQ |
Expansion module, 2 x 40GE/100GE QSFP28 ports. |
| M7600-4GT4VS |
Expansion module, 4 x 10/100/1000BASE-T ports, 4 x 1GE/10GE/25GE SFP28 ports. |
10 x SFX ports and 20 x SFX ports support SFG-LR-SM and SFX-LR-SM.
4 x 1GE/10GE/25GE SFP28 ports support 1GE SFP transceivers, 10GE SFP+ transceivers and 25GE SFP28 transceivers.
2 x 40GE/100GE QSFP28 ports support 40GE QSFP+ transceivers and 100GE QSFP28 transceivers.
| Model |
Description |
| RG-PA550I II-F |
550 W AC power module, supporting redundancy, 10 A power cord |
1GE Optical Transceiver
| Model |
Description |
| Mini-GBIC-GT |
| MINI-GBIC-SX-MM850 |
| MINI-GBIC-LX-SM1310 |
| MINI-GBIC-LH40-SM1310 |
| MINI-GBIC-ZX80-SM1550 |
| GE-SFP-LX20-SM1310-BIDI |
1000BASE-LX, SFP transceiver, TX1310/RX1550, BiDi LC, 20 km over SMF |
| GE-SFP-LX20-SM1550-BIDI |
1000BASE-LX, SFP transceiver, TX1550/RX1310, BiDi LC, 20 km over SMF |
10GE Optical Transceiver
| Model |
Description |
| XG-SFP-SR-MM850 |
| XG-SFP-LR-SM1310 |
| XG-SFP-ER-SM1550 |
| XG-SFP-ZR-SM1550 |
| XG-SFP-AOC1M |
| XG-SFP-AOC5M |
25GE Optical Transceiver
| Model |
Description |
| VG-SFP-SR-MM850 |
25GBASE-SR, SFP28 transceiver, 850 nm, Duplex LC, 100 m over OM4 MMF, 70 m over OM3 MMF |
| VG-SFP-LR-SM1310 |
25GBASE-LR, SFP28 transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| VG-SFP-AOC5M |
25GBASE, SFP28 active optical cable (AOC), 5 m, including one cable and two optical transceivers |
40GE Optical Transceiver
| Model |
Description |
| 40G-QSFP-LSR-MM850 |
40GBASE-LSR, QSFP+ transceiver, 850 nm, MPO 1 x 12, 400 m over OM4 MMF, 300 m over OM3 MMF |
| 40G-QSFP-LR4-SM1310 |
40GBASE-LR4, QSFP+ transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| 40G-QSFP-iLR4-SM1310 |
40GBASE-iLR4, QSFP+ transceiver, 1310 nm, Duplex LC, 2 km over SMF |
| 40G-QSFP-LX4-SM1310 |
40GBASE-LX4, QSFP+ transceiver, 1310 nm, Duplex LC, 150 m over OM3/OM4 MMF, 2 km over SMF |
| 40G-AOC-5M |
40GBASE, QSFP+ active optical cable (AOC), 5 m, including one cable and two optical transceivers |
100GE Optical Transceiver
| Model |
Description |
| 100G-QSFP-SR-MM850 |
100GBASE-SR, QSFP28 transceiver, 850 nm, MPO 1 x 12, 100 m over OM4 MMF, 70 m over OM3 MMF |
| 100G-QSFP-LR4-SM1310 |
100GBASE-LR4, QSFP28 transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| 100G-AOC-10M |
100GBASE, QSFP28 active optical cable (AOC), 10 m, including one cable and two optical transceivers |
| Model |
Description |
| SFG-LR-SM |
1GBASE-LR, core switch-side SFG CWDM transceiver, integration of 8 different wavelengths, BiDi LC, 10 km over SMF |
| SFM-LR-SM |
2.5GBASE-LR, core switch-side SFM CWDM transceiver, integration of 8 different wavelengths, BiDi LC, 10 km over SMF |
| SFX-LR-SM |
10GBASE-LR, core switch-side SFX CWDM transceiver, integration of 8 different wavelengths, BiDi LC, 10 km over SMF |
| GE-SFP-LR(A1-8)-H |
A group of 8 high-power 1GE CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| MG-SFP-LR(A1-8)-H |
A group of 8 high-power 2.5GE CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| MG-SFP-LR(A1-4)-H |
A group of 4 high-power 2.5GE CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| XG-SFP-LR(A1-8)-H |
A group of 8 high-power 10GE CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| XG-SFP-LR(A1-8)-H-E |
A group of 8 high-power quasi-industrial temperature 10GE CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| MG-SFP-LR(A1-8)-H-E |
A group of 8 high-power quasi-industrial temperature 2.5GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| GE-SFP-LR(A1-8)-H-E |
A group of 8 high-power quasi-industrial temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), dual-fiber LC/UPC connectors, supporting single-uplink and dual-uplink scenarios |
| Model |
Description |
| SFGP-LR-SM |
Core-side high-density CWDM 16GE SFGP transceiver, supporting 16 distinct wavelengths (corresponding to 16 gigabit access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector |
| SFXP-LR-SM |
Core-side high-density CWDM 160GE SFXP transceiver, supporting 16 distinct wavelengths (corresponding to 16 10 GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector |
| XG-SFP-LR(A1-16)-H-BIDI |
A group of 16 high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single LC/UPC connector, designed to be used with single-uplink transparent distribution modules |
| GE-SFP-LR(A1-16)-H-BIDI |
A group of 16 high-power commercial-temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single LC/UPC connector |
| XG-SFP-LR(A1-16)-P-BIDI |
A group of 16 ultra-high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single LC/UPC connector, designed to be used with dual-uplink transparent distribution modules |
| XG-SFP-LR(A1-16)-H-E-BIDI |
A group of 16 high-power quasi-industrial temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single LC/UPC connector |
| GE-SFP-LR(A1-16)-H-E-BIDI |
A group of 16 high-power quasi-industrial temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single LC/UPC connector |
| Model |
Description |
| RG-MUX-8LC/LC-H |
Building-side 8-port transparent distribution module (high-end version with low insertion loss), 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port, supporting connection to a dual-uplink splitter |
| RG-MUX-8LC/LC |
Building-side 8-port transparent distribution module, 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port |
| RG-MUX-EXT |
Building-side transparent distribution module's expansion module, or optical dual-uplink splitter (delivered with short fiber jumpers), which connects to the transparent distribution module and provides 1-to-2 optical signal splitting to realize dual-uplink networking; 1 x multiplexing port, 2 x uplink ports for optical splitting |
| RG-MUX-BOX |
Building-side transparent distribution module subrack, 6 x transparent distribution module/dual-uplink splitter slots |
| Chassis |
Description |
| RG-MUX-16LC/LC-H-BIDI |
Building-side 16-port transparent distribution module, single-fiber bidirectional BiDi downlink ports with LC/UPC connectors, and a single uplink COM port with an LC/APC connector, supporting standalone scenarios |
| RG-MUX-16LC/LC-V-BIDI |
Building-side 16-port transparent distribution module, single-fiber bidirectional BiDi downlink ports with LC/UPC connectors, and dual uplink COM ports with LC/APC connectors, supporting VSU scenarios |
| RG-MUX-BOX-H |
Subrack of the building-side transparent distribution module, providing three slots, which can accommodate 1:16 or 1:8 transparent distribution modules or dual-uplink splitters, supporting rack mounting and wall mounting |
