RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 1
RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 2
RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 3
RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 4
RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 5
RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 6
RG-S6920-4C Kết nối mạng trung tâm dữ liệu - 7
RG-S6920-4C – Next-Generation Data Center 100GE Switch with 100GE/400GE Line Cards
Compared with the traditional networking with modular core switches, the entire network with RG-S6920-4C switches uses the Clos architecture, reducing the TCO by 25% and power consumption by 31%. Furthermore, RG-S6920-4C switches help build stable and lossless networks.
  • Diverse ports, four service slots, up to 128 × 100GE ports or 32 × 400GE QSFP-DD ports
  • Highly-efficient heat dissipation and energy saving, with power consumption less than 1950 W and power conversion efficiency up to 94%
Thông số chính
Data Center 100GE Core Switch RG-S6920-4C
Four service slots, with 100GE and 400GE line cards, allowing for easy expansion and satisfying future bandwidth expansion needs
Various ports, up to 128 × 100GE ports or 32 × 400GE QSFP-DD ports., which are fit for different scenarios of data center networks
Power modules in 2+2 redundancy mode, failover in seconds, and power module replacement without
network interruption, providing double protection for links
and Zero Packet Loss
Thông số kỹ thuật
RG-S6920-4C
(W × D × H)
442 mm x 735 mm x 173.6 mm (17.40 in. x 28.94 in. x 6.83 in.)
4 RU
25.15 kg (55.45 lbs., empty chassis)
34.25 kg (75.51 lbs., a chassis with four power modules and six fan modules)
25.6 Tbps
8000 Mpps
Management port
4 x expansion module slots
4 x power module slots
6 x fan module slots
Maximum power consumption: 1950 W
Typical power consumption: 1469 W
Static power consumption: 516 W
RG-PA1200I-F (AC input)
Rated input voltage: 100 V AC to 127 V AC, 200 V AC to 240 V AC, 50 Hz/60 Hz
8.5 A (200 V AC to 240 V AC)
Power port type: C14
RG-PA1200I-F (HVDC input):
Rated input voltage: 240 V DC
Rated current: 6.5 A
Operating temperature: 0°C to 40°C (32°F to 104°F)
Operating altitude: ≤ 5,000 m (16,404.20 ft.)
Storage altitude: ≤ 5000 m (16,404.20 ft.)
RG-S6920-4C
Layer 2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and selective QinQ), GVRP
Layer 3 Protocols (IPv4)
IPv6 Basic Protocols
IPv6 Features
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunnel and IPv4 over IPv6 tunnel
Data Center Features
M-LAG
RDMA
OpenFlow 1.3
BGP-EVPN
Global load balancing technologies such as RALB and AILB
Visualization
sFLOW sampling
INT
Priority marking/remarking
HA Design
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, ARP check, and hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm function, temperature alarm function, and configuration rollback
Other Protocols
Tài nguyên
Thông tin đặt hàng
Chassis, Fan, and Power Supply Modules
RG-S6920-4C
Four expansion slots, four power supply module slots, and six fan module slots
The power supply module model is RG-PA1200I-F and the fan model is M2EFAN I-F.
RG-PA1200I-F
M2EFAN I-F
Fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design
Expansion Modules
M6900-32CQ
32 x 40GE /100GE optical ports (QSFP28)
M6900-16CQ4QC
16 × 100GE optical ports (QSFP28) + 4 × 400GE optical ports (QSFP-DD)
M6900-08QC
8 x 400GE optical ports (QSFP-DD)
40GE Optical Transceivers
40G iLR4 optical transceiver, QSFP+, Duplex LC, 2 km (6,561.68 ft.) over single-mode fiber (SMF)
40G SR optical transceiver, QSFP+ form factor, MPO, 400 m (1312.34 ft.) over multimode fiber (MMF)
100GE Optical Transceivers
200GE Optical Transceivers
200G-Q56-SR4-MM850(D)
200GE SR4 optical transceiver, QSFP56 form factor, MPO12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MPO MMF, CMIS-compliance
400GE Optical Transceivers
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G-QDD-SR8-MM850
400G-QDD-AOCxM
400G AOC, QSFP-DD form factor, X = 3 m (9.84 ft.)/5 m (16.40 ft.)/10 m (32.81 ft.)/15 m (49.21 ft.)/20 m (65.62 ft.)/30 m (98.43 ft.)/50 m (164.04 ft.)
For more information about optical transceiver compatibility, refer to Ruijie RG-S6920 Series Data Center Switches Optical Transceiver Compatibility Matrix.
