RG-SAP185-SP-W Vô tuyến - 1
RG-SAP185-SP-W Vô tuyến - 2
RG-SAP185-SP-W Vô tuyến - 3
RG-SAP185-SP-W Vô tuyến - 4
RG-SAP185-SP-W Vô tuyến - 5
RG-SAP185-SP-W Vô tuyến - 6
RG-SAP185-SP-W Vô tuyến - 7
RG-SAP185-SP-W Vô tuyến - 8
RG-SAP185-SP-W Vô tuyến - 9
RG-SAP185-SP-W, Wi-Fi 6 Dual-Radio 2.976 Gbps Wall-Plate Access Point
Indoor scenarios covering higher education, government, general education, finance, and commerce sectors
  • Upgraded to Wi-Fi 6, high-speed access at 2.976 Gbps
Thông số chính
Ruijie WaaS Series Wall-Plate Access Point
(86 mm Junction Box-Mount) RG-SAP185-SP-W
Scenarios
PoE Input
2.4 GHz/5 GHz Dual-Radio
Four Spatial Streams
Max Data Rate 2.976 Gbps
Max Power Consumption 8 W
Upgraded to Wi-Fi 6, Up to 2.976 Gbps Data Rate
2.976
Gbps
High Speed
1024-QAM used in Wi-Fi 6, delivering a data rate of up to 2.976 Gbps
High Concurrency
OFDMA and MU-MIMO technologies, increasing the concurrent capacity to four times that of Wi-Fi 5 and ensuring stable connections for multiple clients
Low Latency
OFDMA and RRM2.0 technologies, reducing latency to 20 ms and enabling fast speed for playing mobile games and watching live videos
Secure Access for All Scenarios,
Enterprise-Level Security Protection
Comprehensive Authentication
Security Protection
PSK, WPA, WPA2,
and WAP Authentication
802.1X
Authentication
Web-based
Authentication
QR Code-based Guest
Authentication
SMS-based
Authentication
MAB
Authentication
One Ethernet Cable for Power and Data Transmission
PoE input is adopted, eliminating the need for external power supply and high-voltage construction. This saves both time and effort during installation.
The AP can be installed wherever the Ethernet cable is routed, enabling plug-and-play and convenient network connection.
WIS Cloud enables network-wide configuration and optimization, eliminating the need for on-site operations.
Network issue warnings allows wireless networks to be monitored anytime and anywhere.
Go to WIS Cloud >>
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
Thông số kỹ thuật
RG-SAP185-SP-W
Four spatial streams
● Radio 2 – 5 GHz: 2x2 MIMO, two spatial streams
Channels:
Two spatial streams
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, and 80 MHz
● Radio 2 – 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, 80 MHz and 160 MHz
● Radio 1 – 2.4 GHz: 8.6 Mbps to 574 Mbps (MCS0 to MCS11)
● 2.4 GHz: two built-in smart antennas with the peak gain of 2 dBi
● 5 GHz: two built-in smart antennas with the peak gain of 3 dBi
Uplink:
1 x 10/100/1000BASE-T port, compliant with IEEE 802.3af/at standard (PoE/PoE+)
1 x pass-through port
Downlink:
● CAPWAP tunnel timeout
Main unit: 86 mm x 86 mm x 38 mm (3.39 in. x 3.39 in. x 1.50 in.)
Shipping: 125 mm x 115 mm x 60 mm (4.93 in. x 4.53 in. x 2.37 in.)
Main unit: 0.21 kg (0.47 lbs)
Shipping: 0.24 kg (0.53 lbs)
86 mm junction box-mount
PoE input over the WAN port: compliance with 802.3af/at (PoE/PoE+)
Maximum power consumption: 8 W
● DC power: 8 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● 802.3af/at (PoE/PoE+) : 8 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● Idle mode: 5 W
256 MB DRAM, 128 MB flash
RG-SAP185-SP-W
2.4GHz 802.11b
17 dBm
–90 dBm
15 dBm
–87 dBm
2.4GHz 802.11g
–78 dBm
15 dBm
–72 dBm
2.4GHz 802.11n (HT20)
15 dBm
–67 dBm
2.4GHz 802.11n (HT40)
15 dBm
–64 dBm
2.4GHz 802.11ax (HE20)
12 dBm
–58 dBm
2.4GHz 802.11ax (HE40)
12 dBm
5GHz 802.11a
–78 dBm
15 dBm
–72 dBm
5GHz 802.11n (HT20)
15 dBm
–67 dBm
5GHz 802.11n (HT40)
15 dBm
–64 dBm
5GHz 802.11ac (VHT20)
15 dBm
5GHz 802.11ac (VHT40)
15 dBm
–57 dBm
5GHz 802.11ac (VHT80)
13 dBm
5GHz 802.11ax (HE20)
12 dBm
–58 dBm
5GHz 802.11ax (HE40)
12 dBm
5GHz 802.11ax (HE80)
12 dBm
–52 dBm
Note: Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
Basic Functions
RG-SAP185-SP-W
RGOS 11.9(6)W3B7 or later
512 (up to 256 STAs per radio)
16 (up to 8 BSSIDs per radio)
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
PSK and web authentication
MAC address table size: 1,024
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 100
VLAN ID range: 1–4,094
ARP entry aging and proxy ARP
IP address conflict detection between downlink users
NAT, FTP ALG and DNS ALG
NTP server and NTP client
Telnet and TFTP management
RG-SAP185-SP-W
RG-SAP185-SP-W
EN 55032, EN 55035,  EN IEC 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, and EN IEC 62311
Tài nguyên
Thông tin đặt hàng
RG-SAP185-SP-W
Wi-Fi 6 ultra-thin wall plate wireless access point
It can be installed on an 86-type panel, and complies with IEEE 802.11a/b/g/n/ac and IEEE 802.11ax. It can switch between Fat, Fit, and cloud modes, and provides IEEE 802.3af/at power supply.
Câu hỏi thường gặp
