RG-SAP825-SP Vô tuyến - 1
RG-SAP825-SP Vô tuyến - 2
RG-SAP825-SP Vô tuyến - 3
RG-SAP825-SP Vô tuyến - 4
RG-SAP825-SP Vô tuyến - 5
RG-SAP825-SP, Wi-Fi 6 Dual-Radio 2.976 Gbps High-Density Indoor Access Point
Indoor high-density network scenarios in the higher education, medical industry, government and commerce
  • 2.5 Gbps combo port for flexible networking
  • Upgraded to Wi-Fi 6, high-speed access at 2.976 Gbps
Thông số chính
Product Overview
The RG-SAP825-SP is a Wi-Fi 6 wireless access point that integrates dual radios, high performance, and enterprise-grade encryption technology. Due to the hybrid cloud management mode and high-density access design, it is suitable for flexible deployment in high-quality network scenarios, such as classroom, dormitory, and office scenarios in the education industry, production workshop and warehouse scenarios in the manufacturing industry, and outpatient clinics and mobile ward rounds scenarios in the medical industry.
Product Highlights
Ultra-High Performance
Dual-band design (2.4 GHz + 5 GHz), four spatial streams, 1024-Quadrature Amplitude Modulation (QAM) high-speed access, and up to 2.976 Gbps peak data rate, realizing high-speed wireless access experience
Orthogonal Frequency-Division Multiple Access (OFDMA), Multi-User Multiple-Input Multiple-Output (MU-MIMO), and Wi-Fi Multimedia (WMM), increasing the average rate per user in high-density deployment environments
RF power adjustment and intelligent channel allocation to solve the problems such as co-channel interference and adjacent channel interference, thereby improving network transmission efficiency and stability
Flexible Networking
Local and cloud management modes, and intelligent wireless network optimization, reducing TCO and maximizing ROI
Access through optical and Ethernet cables for flexible networking and high-speed backhaul over 2.5 Gbps optical links
IEEE 802.11k/v/r support and roaming stickiness optimization, achieving seamless user roaming
Rich IoT features: PoE output, Bluetooth 5.1, and wireless locating
High Security and Reliability
Encryption and authentication technologies including Wi-Fi Protected Access 3 (WPA3), enhanced open security, 802.1X, and Private Pre-shared Key (PPSK), enhancing data security
Dynamic Frequency Selection (DFS), optimizing the use of available RF spectrum to prevent radar channel interference
Cyclic Delay/Shift Diversity (CDD/CSD), Maximum Ratio Combining (MRC), Space-Time Block Coding (STBC), and Low-Density Parity Check (LDPC), improving the signal quality, signal receiving, and reliability and performance of data transmission
Transmit beam-forming (TxBF) expands the signal coverage and enhances the reliability of specific devices, thereby improving the data rate
Intelligent identification and monitoring, multicast-to-unicast conversion, and other features, enhancing network security and reliability
Thông số kỹ thuật
RG-SAP825-SP
Four spatial streams
Channels:
● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS31)
Two spatial streams
Channels:
Channels:
Combined peak data rate: 2.976 Gbps:
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 5 dBi.
● 5 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 5.7 dBi.
● One onboard omnidirectional antenna, with peak antenna gain of 2.4 dBi.
1 x 10/100/1000BASE-T port
1 x 2.5GE SFP/RJ45 combo port, compatibility with 1GE module, shared with one 10/100/1000BASE-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 220 mm x 220 mm x 49 mm (8.66 in. x 8.66 in. x 1.93 in.)
Shipping: 507 mm x 319 mm x 278 mm (19.96 in. x 12.56 in. x 10.94 in.)
Main unit: 0.6 kg (1.33 lbs)
Shipping: 1.04 kg (2.29 lbs)
● 48 V/0.6 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power supply needs to be purchased independently.
● DC power: 12.95 W
● 802.3bt (PoE++): 12.95 W
● 802.3at (PoE+): 12.95 W
● 802.3af (PoE): 12.95 W
● Idle mode: 6 W
Operating humidity: 0% RH to 95% RH (non-condensing)
Note: At an altitude in the range of 1,800–4,000 m (5,905.51–13,123.36 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
512 MB DRAM, 128 MB flash
Maximum transmit power
● Maximum transmit power: 26 dBm (398.11 mW)
RG-SAP825-SP
2.4 GHz 802.11b
–90 dBm
–87 dBm
2.4 GHz 802.11g
22 dBm
22 dBm
–78 dBm
–72 dBm
2.4 GHz 802.11n (HT20)
19 dBm
–67 dBm
2.4 GHz 802.11n (HT40)
19 dBm
–64 dBm
2.4 GHz 802.11ax (HE20)
15 dBm
–58 dBm
2.4 GHz 802.11ax (HE40)
15 dBm
5 GHz 802.11a
22 dBm
22 dBm
–78 dBm
–72 dBm
5 GHz 802.11n (HT20)
19 dBm
–67 dBm
5 GHz 802.11n (HT40)
19 dBm
–64 dBm
5 GHz 802.11ac (VHT20)
5 GHz 802.11ac (VHT40)
–57 dBm
5 GHz 802.11ac (VHT80)
5 GHz 802.11ax (HE20)
–58 dBm
5 GHz 802.11ax (HE40)
5 GHz 802.11ax (HE80)
–52 dBm
5 GHz 802.11ax (HE160)
–77 dBm
–50 dBm
 Note Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
Basic Functions
RG-SAP825-SP
RGOS11.9(6)W1B4 or later
128
Maximum number of BSSIDs
WLAN service
Maximum number of WLAN IDs: 16
Maximum number of associated STAs per WLAN: 32
MU device locating
PSK and web authentication
QR code-based guest authentication, SMS authentication, and MAC address bypass (MAB) authentication (used with RG-WS series ACs)
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal, WPA2-Enterprise, WPA3-Personal (SAE), WPA3-Personal (WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP)
ACL Remark
MAC address table size: 1,024
Maximum number of static MAC addresses: 1,024
Maximum number of filtered MAC addresses: 1,024
Jumbo frame length: 1,518
Ethernet II frame format
1000M SFP ports
2.5GE interfaces
Maximum. number of SVIs (IPv4): 200
Maximum number of SVIs (IPv6): 200
VLAN ID range: 1–4,094
Maximum number of ARP entries: 1,024
NAT, FTP ALG and DNS ALG
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 ping, IPv6 tracert
Maximum number of IPv6 addresses configured on each Layer 3 interface: 400
Maximum number of ND entries: 4,096
Maximum number of static IPv6 routes: 1,000
RG-WS series wireless controller and Ruijie Cloud
Wireless marketing: WMC/MCP
When the AP works in cloud mode, it can be managed through WIS Cloud.
RG-SAP825-SP
Big data capabilities
RG-SAP825-SP
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1,
EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440,
FCC Part 15, EN IEC 62311, IEC 62368-1, EN 62368-1, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-SAP825-SP] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-SAP825-SP] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Tài nguyên
Thông tin đặt hàng
RG-SAP825-SP
Wi-Fi 6 (802.11ax) indoor wireless access point
● Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 574 Mbps
● Radio 2: 5 GHz: two spatial streams, 2x2 MIMO, peak data rate of 2.402 Gbps
802.11a/b/g/n/ac/ax, switching between Fat, Fit, and cloud modes, and 802.3af PoE and local DC power supply
● The power source equipment (PSE) needs to be purchased separately. The PoE Power Injector can be purchased from Ruijie.
● The DC power module has to be purchased separately from a third party. The output voltage/current must be 54 V/1.1 A.
RG-E-120(GE)
Single PoE Power Injector with 1000BASE-T support, supporting 802.3af
1000BASE-SX mini-GBIC module
1000BASE-LX mini-GBIC module
Câu hỏi thường gặp
