RG-AP7176-R(V2) Vô tuyến - 1
RG-AP7176-R(V2) Vô tuyến - 2
RG-AP7176-R(V2) Vô tuyến - 3
RG-AP7176-R(V2) Vô tuyến - 4
RG-AP7176-R(V2) Vô tuyến - 5
RG-AP7176-R(V2) Vô tuyến - 6
RG-AP7176-R(V2), Wi-Fi 7 Quad-Radio 17.982 Gbps High-Density Indoor AP, Intelligent 5 GHz & 6 GHz Band Switching
  • 10GE combo port for flexible deployment
  • Enterprise-class Wi-Fi 7 delivering a data rate of up to 17.982 Gbps
  • 5 GHz & 6 GHz ready with smooth upgrade path
  • Independent AI radio delivers network security & superior roaming
  • WIS digital twin network for superior network O&M efficiency
Thông số chính
RG-AP7176-R(V2) High-Density Wi-Fi 7 Indoor AP
Experience fast, intelligent, and reliable wireless connectivity
10GE Combo Port for Flexible Deployment
The RG-AP7176-R(V2) comes with a 10GE combo port, which integrates Ethernet and optical interfaces for flexible deployment. Its 10GE SFP+ optical port supports Ruijie's SOE Solution. When paired with hybrid cables, it enables data and power transmission over 1,000m, delivers future-ready uplink performance for high-bandwidth applications, and simplifies network cabling.
Enterprise-Class Wi-Fi 7 Delivering a Data Rate of Up to 17.982 Gbps
Empowering seamless high-bandwidth applications with next-generation wireless performance.
5 GHz & 6 GHz Ready with Smooth Upgrade Path
The RG-AP7176-R(V2) supports intelligent switching between 5 GHz and 6 GHz frequency bands, providing optimal coverage, stability, and speed. It enables a hardware-free upgrade path to keep your network future-proof.
Independent AI Radio Delivers Superior Roaming & Network Security
Superior Roaming Experience
Security Safeguarding
AI Radio’s real-time client scanning enables better roaming policies, delivering a superior experience for mobile office, mobile video conferencing, or online learning.
Go to WIS Digital Twin Network>
Thông số kỹ thuật
RG-AP7176-R(V2)
12 spatial streams
●     Radio 1 - 2.4 GHz: 2x2 MIMO, two spatial streams
●     Radio 2 - 5 GHz: 4x4 MIMO, four spatial streams
●     Radio 3 - 5 GHz: 4x4 MIMO, four spatial streams
●     Radio 4 - AI Radio, 2.4 GHz/5 GHz: 2x2, MIMO two spatial streams
Channel:
●     Radio 1 - 2.4 GHz: 20 MHz and 40 MHz
●     Radio 2 - 5 GHz: 20 MHz and 40 MHz
●     Radio 3 - 5 GHz: 20 MHz and 40 MHz
●     Radio 4 - AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
Combined peak data rate: 1.5 Gbps
●     Radio 1 - 2.4 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS31)
●     Radio 2 - 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
●     Radio 3 - 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
●     Radio 4 - AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
●     Aggregate MAC Protocol Data Unit (A-MPDU)
●     Aggregate MAC Service Data Unit (A-MSDU)
10 spatial streams
●     Radio 2 - 5 GHz: 4x4 MU-MIMO, four spatial streams
●     Radio 4 - AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channel:
●     Radio 2 - 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
●     Radio 3 - 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
●     Radio 4 - AI Radio, 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 6.934 Gbps
●     Radio 2 - 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
●     Radio 3 - 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
●     Radio 4 - AI Radio, 5 GHz: AI Radio for scanning only
12 spatial streams
●     Radio 2 - 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
●     Radio 3 - 5 GHz/6 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
●     Radio 4 - AI Radio, 2.4 GHz/5 GHz: 2x2 uplink/downlink MU-MIMO, two spatial streams
Channel:
●     Radio 3 - 5 GHz/6 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
●     Radio 4 - AI Radio, 2.4 GHz/5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 10.182 Gbps
●     Radio 1 - 2.4 GHz: 7.3 Mbps to 0.574 Gbps (MCS0 to MCS11)
●     Radio 2 - 5 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
●     Radio 3 - 5 GHz/6 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
802.11be
10 spatial streams
Channel:
●     Radio 3 - 5 GHz/6 GHz: 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz
Combined peak data rate: 12.218 Gbps/17.982 Gbps
●     Radio 1 - 2.4 GHz: 7.3 Mbps to 0.688 Gbps (MCS0 to MCS13)
●     Radio 2 - 5 GHz: 7.3 Mbps to 5.765 Gbps (MCS0 to MCS13)
●     Radio 3:
       6 GHz: 7.3 Mbps to 11.529 Gbps (MCS0 to MCS13)
●     2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi
●     5 GHz: four built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi
●     5 GHz/6 GHz: four built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi
●     One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 3 dBi
1 x 100/1000/2.5G/5G/10GBASE-T port , shared with one 10GE SFP+ port
1 x 10GE SFP+ port, compatibility with 1GE/2.5GE/10GE modules, shared with one 10GE RJ45 port
1 x 10/100/1000BASE-T port, supplying IEEE 802.3af power to an IoT unit
1 x USB 2.0 (Type-A connector)
1 x Bluetooth 5.3
●     AP power-on status
●     Software initialization status and upgrade status
●     Uplink service interface status
●     Wireless user online status
●     CAPWAP tunnel timeout
●     Specific AP locating
●     Press the button for shorter than 2 seconds. Then the device restarts.
●     Press the button for longer than 5 seconds. Then the device restores to factory settings.
Main unit: 220 mm x 220 mm x 42.7 mm (8.66 in. x 8.66 in. x 1.68 in.)
Shipping: 495mm x 379mm x 261mm (19.49 in. x 14.92 in. x 10.28 in.)
Main unit: 1.2 kg (2.65 lbs)
Mounting bracket: 0.05 kg (0.11 lbs)
Shipping: 1.5 kg (3.31 lbs)
●     54 V DC/1.25 A power input over DC connector
●     PoE/PoE+/PoE++ input, in compliance with IEEE 802.3af/at/bt standard
Maximum power consumption: 55 W
●     DC power: 55 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 4x4, Radio 3 (5 GHz/6 GHz) 4x4, Radio 4 (AI Radio) 2x2, LAN 1 for PoE power supply (48 V/12.95 W), USB port for external power supply (5 V/2.5 W)
●     802.3bt (PoE++): 55 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 4x4, Radio 3 (5 GHz/6 GHz) 4x4, Radio 4 (AI Radio) 2x2, LAN 1 for PoE power supply (48 V/12.95 W), USB port for external power supply (5 V/2.5 W)
●     802.3at (PoE+): 25.5 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz/6 GHz) 2x2, Radio 4 (AI Radio) is disabled, LAN 1 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
●     802.3af (PoE): 12.95 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) , Radio 3 (5 GHz/6 GHz) , Radio 4 (AI Radio) is disabled, LAN 1 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
●     Idle mode: 12.2 W
External power supply
●     The USB port can source 5 V/2.5 W power to an attached device.
●     The LAN 1 port can source IEEE 802.3af power to an IoT unit.
1024 MB DRAM, 256 MB flash
●     Maximum transmit power: 23 dBm (199.53 mW)
●     Minimum transmit power: 6 dBm (3.98 mW)
6 GHz
●     Maximum transmit power: 22 dBm (158.49 mW)
●     Adjusting the transmit power by percentage (recommended) and in 1dBm increments.
●     The transmit power adjusted in percentage. The transmit power is limited by local regulatory requirements. For details, see WLAN Country or Region Codes and Channel Compliance.
RG-AP7176-R(V2)
2.4 GHz 802.11g
-91 dBm
-85 dBm
-80 dBm
21 dBm
-74 dBm
2.4 GHz 802.11n (HT20)
-85 dBm
-67 dBm
2.4 GHz 802.11n (HT40)
-82 dBm
-64 dBm
2.4 GHz 802.11ax (HE20)
-85 dBm
17 dBm
-58 dBm
2.4 GHz 802.11ax (HE40)
23dBm
-82 dBm
17dBm
-54 dBm
2.4 GHz 802.11be(EHT20)
-85 dBm
MCS13
-52 dBm
2.4 GHz 802.11be(EHT40)
23dBm
-82 dBm
MCS13
16dBm
-49 dBm
5 GHz 802.11a
-91 dBm
-85 dBm
-80 dBm
21 dBm
-74 dBm
5 GHz 802.11n (HT20)
-85 dBm
-67 dBm
5 GHz 802.11n (HT40)
-82 dBm
-64 dBm
5 GHz 802.11ac (VHT20)
-85 dBm
-60 dBm
5 GHz 802.11ac (VHT40)
-82 dBm
-57 dBm
5 GHz 802.11ac (VHT80)
-82 dBm
-56 dBm
5 GHz, 802.11ac (VHT160)
5 GHz 802.11ax (HE20)
-85 dBm
17 dBm
-58dBm
5 GHz 802.11ax (HE40)
-82dBm
17 dBm
-54dBm
5 GHz 802.11ax (HE80)
-82 dBm
-56 dBm
17 dBm
-52dBm
5 GHz 802.11ax (HE160)
-79 dBm
-53 dBm
17 dBm
-50 dBm
5 GHz 802.11be (EHT80)
-82 dBm
-56 dBm
17 dBm
-52 dBm
MCS13
15 dBm
-46 dBm
5 GHz 802.11be (EHT160)
-79 dBm
-53 dBm
17 dBm
-50 dBm
MCS13
15 dBm
-44 dBm
6 GHz, 802.11ax (HE20)
–88 dBm
–58dBm
6 GHz, 802.11ax (HE40)
–85dBm
–55dBm
6 GHz, 802.11ax (HE80)
–57 dBm
–52 dBm
6 GHz, 802.11ax (HE160)
–49 dBm
6 GHz, 802.11be (EHT20)
–88 dBm
–58dBm
6 GHz, 802.11be (EHT40)
–85dBm
–55dBm
6 GHz, 802.11be (EHT80)
–57 dBm
–52 dBm
MCS13
–46 dBm
6 GHz, 802.11be (EHT160)
–49 dBm
MCS13
–43 dBm
6 GHz, 802.11be (EHT320)
–76 dBm
–51 dBm
–46 dBm
MCS13
–40 dBm
RG-AP7176-R(V2)
RGOS11.9(6)W5B9 or later
1280
●     Radio 1: Up to 256 STAs
●     Radio 2: Up to 512 STAs
●     Radio 3: Up to 512 STAs
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
PSK, PPSK, Web, 802.1X, WPA, WPA2, and WPA3 authentication
QR code-based guest authentication, SMS-based authentication, and MAC address bypass (MAB) authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP, GCMP), WPA3-OWE
MAC address table size: 4,096
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
Identification of IP address conflicts between downlink users
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
RG-AP7176-R(V2)
Big data capabilities
Note:Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
Tài nguyên
Thông tin đặt hàng
RG-AP7176-R(V2)
Wi-Fi 7 quad-radio indoor high-density wireless access point
Up to 12 spatial streams, peak data rate of 17.982 Gbps
●     Radio1 - 2.4 GHz: 2 spatial streams, 2x2 MIMO, peak data rate of 0.688 Gbps
●     Radio2 - 5 GHz: 4 spatial streams, 4x4 MU-MIMO, peak data rate of 5.765 Gbps
●     Radio3 - 5 GHz/6 GHz: 4 spatial streams, 4x4 MU-MIMO, peak data rate of 11.529 Gbps
●     Radio4 - AI Radio, 2.4 GHz/5 GHz: 2 spatial streams, 2x2 MIMO, for scanning only
The AP consumes one license of an AC.
Fat/Fit/Cloud mode switching. IEEE 802.3af/at/bt-compliant (PoE/PoE+/PoE++) and DC power supply
●     The DC power supply needs to be purchased separately, and the output voltage/current must be 54 V/1.25 A.
SFP BIDI Transceiver-TX1550/RX1310,20km,LC
2.5G-SFP-LX03-SM1550-BIDI
SFP+ BIDI Transceiver-TX1330/RX1270, 10km, LC
