RG-AM5832-SF-P Vô tuyến - 1
RG-AM5832-SF-P Vô tuyến - 2
RG-AM5832-SF-P Vô tuyến - 3
RG-AM5832-SF-P Vô tuyến - 4
RG-AM5832-SF-P Vô tuyến - 5
RG-AM5832-SF-P Vô tuyến - 6
RG-AM5832-SF-P, Simplified Optical Ethernet (SOE) Master Access Point
  • Hybrid cables, simplifying optical network deployment
  • Rich port options to adapt to various APs and achieve flexible service expansion
  • No license required for identifying and connecting to SOE micro APs
  • WIS digital twin network for superior network O&M effictiency
RG-AM5832-SF-P SOE Master AP
Uplink: 8 x 25GE SFP28 ports or 2 x 40GE QSFP+ ports, on-demand selection of cards to match the backbone network, offering flexible networking options. Downlink: All 10GE SFP+ ports, accommodating 24 APs, supporting hybrid cables, and enabling high-performance, easily scalable optical network access for all scenarios
Selection by Backbone Network
Uplink 40GE card
Uplink 25GE card
Hybrid Cables, Simplifying Optical Network Deployment
The optical-electrical parallel design allows the hybrid cable to be connected to APs, achieving data transmission over 1100 m (0.68 miles) with high bandwidth and PoE power supply delivered directly to the APs. This approach reduces the need for the ELV room on each floor, simplifies network cabling, and eliminates the requirement for local high-voltage reconstruction. Consequently, the deployment, construction, and maintenance of an all-optical network become significantly easier.
Multiple Ports, Easy Expansion with Various APs
Multi-Rate Ports
POE++ Ready
The RG-AM5832-SF-P offers 24 x 1GE/2.5GE/10GE SFP+ downlink ports, enabling an upgrade to Wi-Fi 7 networks without the need to replace the SOE master AP. This allows for seamless integration of 10GE APs and smooth bandwidth upgrades.
No License Required for Identifying and Connecting to SOE Micro APs
The RG-AM5832-SF-P can connect to SOE micro APs and regular APs. No license is required for identifying and connecting to micro APs. This reduces management costs compared to the previous generation of master APs.
Go to WIS Digital Twin Network  >
Thông số kỹ thuật
RG-AM5832-SF-P
Rack size
5.85 kg (12.90 lbs)
7.95 kg (17.53 lbs)
Rack-mount
RG-AM5832-SF-P
Uplink:
● RG-M5800-2QXS subcard (optional): 2 x 40GE QSFP+ ports
● RG-M5800-8VS subcard (optional): 8 x 25GE SFP28 ports, compatibility with 10GE and 1GE modules.
Downlink:
● 24 x 10GE SFP+ ports, compatibility with 2.5GE and 1GE modules.
● 24 x PoE-out ports, supporting PoE/PoE+/PoE++, with a maximum PoE output power of 90 W per port and a maximum PoE output power of 1,600 W.
1 x RJ45 10/100/1000Base-T auto-negotiation management port
24 x SFP+ port status LEDs, also indicating the PoE status
RG-M5800-2QXS subcard (optional): 2 x QSFP+ port status LEDs
RG-M5800-8VS subcard (optional): 8 x SFP28 port status LEDs
1 x system status LED
2 x power status LEDs
1 x management (MGMT) port status LED
● Press and hold the button for less than 2 seconds to reset the device.
● Press and hold the button for more than 5 seconds to restore the device to factory settings.
1 x LED mode button
● Used to switch the status LED to indicate either PoE status or Link/Act status.
RG-AM5832-SF-P
The RG-AM5832-SF-P supports two hot-swappable 1,000 W power modules, AC input, and DC output for system power supply.
The RG-AM5832-SF-P is delivered with only one AC power module, and you can purchase an additional AC power module.
Rated input voltage range:
● AC input: 100 V AC to 130 V AC, 50/60 Hz
● AC input: 200 V AC to 240 V AC, 50/60 Hz
● HVDC input: 240 V DC
Maximum input current:
● 12 A (input voltage: 100 V AC to 130 V AC)
● 8 A (input voltage: 200 V AC to 240 V AC)
● 8A (input voltage: 240 V DC)
Output voltage: 56 V DC for sourcing power to the RG-AM5832-SF-P and 56 V DC for external power supply
External power supply
24 x PoE-out ports, supporting PoE, PoE+, and PoE++
Max. output current per port: 1.6 A
Max. PoE output power per port: 90 W
Max. PoE output power: 1,600 W
Max. power consumption
< 200 W (without load)
< 2,000 W (full load)
RG-AM5832-SF-P
Operating temperature: 0°C to 45°C (32°F to 113°F) at an altitude in the range of 0 m to 1,800 m (5,905.51 ft.)
At an altitude in the range of 1,800 m to 5,000 m (5,905.51 ft. to 16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
Operating altitude: --500 m to 5,000 m (--1,640.42 ft. to 16,404.20 ft.)
Storage altitude: --500 m to 5,000 m (--1,640.42 ft. to 16,404.20 ft.)
Lightning protection
AC power connector: differential mode ±6 kV, common mode ±6 kV
PoE-out port: differential mode ±2 kV, common mode ±6 kV
Fault alarming and speed adjustment
Software Specification
RG-AM5832-SF-P
RGOS12.6(3)B0401 or later
1,536
Max. number of BSSIDs
Band steering (When used with an AC, the master AP enables STAs to preferentially access the 5 GHz band.)
PSK, Web-based authentication, and 802.1X authentication
Data encryption: WPA (TKIP), WPA-PSK, WPA2 (AES), WEP (64/128-bit)
QR code-based guest authentication, SMS-based authentication, and MAB authentication (The master AP needs to work with an RG-WS series AC.)
Dynamic ACL assignment based on 802.1X authentication (The master AP needs to work with an AC.)
MAC address auto-learning and MAC address entry aging
Static and dynamic MAC address entries
Source MAC address filtering
MAC address limit learned on an interface
Jumbo frame length: 9,216
IEEE 802.1p and IEEE 802.1Q
Optical module information displaying, fault alarming, and diagnostic parameter measurement (QSFP+/SFP28/SFP+/SFP)
Port-based VLAN
Max. number of SVIs: 1,000
Number of VLANs that can be created: 4,094
Available VLAN ID range: 1 to 4,094
ARP entries: 24,000
DHCP server and DHCP client
DNS client and DNS proxy
NTP server, NTP client, and SNTP client
Manually configured and automatically created IPv6 addresses
IPv6 CAPWAP tunnel
IPv6 neighbor discovery (ND), IPv6 ND proxy, ICMPv6, and IPv6 ping
DNSv6 client
NTPv6 server and NTPv6 client
Static IPv4 routing table: 24,000
Static IPv6 routing table: 14,000
Static blackhole route
Fault detection and alarming
RG-AM5832-SF-P
Tài nguyên
Thông tin đặt hàng
RG-AM5832-SF-P
Optical i-Share master AP for Ruijie Simplified Optical Ethernet Solution
Downlink:
Uplink:
Low noise
1 x power module
Each master AP occupies eight AC licenses. One uplink subcard must be ordered upon delivery.
RG-M5800-8VS
Uplink subcard of the RG-AM5832-SF-P
Eight 25GE SFP28 ports need to be switched simultaneously to support 10GE SFP+ and cannot be configured separately.
RG-M5800-2QXS
RG-MAP852-SF-S
Dual-radio Wi-Fi 6 wall-plate optical micro AP for Ruijie Simplified Optical Ethernet Solution
1 × SFP port
BOB structure
1 x 1GE optical module for the master AP
RG-MAP852-SF-M
1 x 2.5GE SFP port
4 x 10/100/1000Base-T Ethernet ports with auto-negotiation
Wall/Ceiling/Junction box-mount
1 x 2.5GE optical module for the optical micro AP
1 x 2.5GE optical module for the master AP
RG-MAP920-SF-M
Wi-Fi 7 dual-radio optical micro access point for Ruijie SOE Solution
1 x 2.5GE SFP port
RG-24DUP1DB48LC
1 x DB-78 power connector
RG-OEHC-SM-1B6A2-2x0.5-I-305
RG-OEHC-SM-2B6A2-2x1.0-I-305
Indoor dual-core 2 x 1.0 mm² hybrid cable, single roll, 305 m (1,000.66 ft) in length
RG-OEHC-SM-2B6A2-2x1.5-O-1000
