RG-SAP815-SP Vô tuyến - 1
RG-SAP815-SP Vô tuyến - 2
RG-SAP815-SP Vô tuyến - 3
RG-SAP815-SP Vô tuyến - 4
RG-SAP815-SP Vô tuyến - 5
RG-SAP815-SP, Wi-Fi 6 Dual-Radio 1.775 Gbps High-Density Indoor Access Point
Indoor high-density network scenarios in the higher education, medical industry, government and commerce
  • Cost-effective high-speed at 1.775 Gbps
Thông số chính
Product Overview
The RG-SAP815-SP is a Wi-Fi 6 wireless access point that integrates dual radios, high performance, and enterprise-grade encryption technology. Due to the hybrid cloud management mode and high-density access design, it is suitable for flexible deployment in high-quality network scenarios, such as classroom, dormitory, and office scenarios in the education industry, production workshop and warehouse scenarios in the manufacturing industry, outpatient clinics and mobile ward rounds scenarios in the medical industry, boutique hotels, and retail shops.
Product Highlights
Cost-effectiveness and High Speed
Dual-band design (2.4 GHz + 5 GHz), four spatial streams, 1024-Quadrature Amplitude Modulation (QAM) high-speed access, and up to 1.775 Gbps peak data rate, realizing high-speed wireless access experience
Orthogonal Frequency-Division Multiple Access (OFDMA), Multi-User Multiple-Input Multiple-Output (MU-MIMO), and Wi-Fi Multimedia (WMM), increasing the average rate per user in high-density deployment environments
RF power adjustment and intelligent channel allocation to solve the problems such as co-channel interference and adjacent channel interference, thereby improving network transmission efficiency and stability
Intelligent networking
Local and cloud management modes, and intelligent wireless network optimization, reducing TCO and maximizing ROI
Intelligent power monitoring, which monitors PoE output power and disables or enables some functions according to the available power to ensure normal operation of the AP
IEEE 802.11k/v/r support and roaming stickiness optimization, achieving seamless user roaming
Rich IoT features: PoE power, Bluetooth 5.1, support for iBeacon, and wireless locating
High Security and Reliability
Encryption and authentication technologies including Wi-Fi Protected Access 3 (WPA3), enhanced open security, 802.1X, and Private Pre-shared Key (PPSK), enhancing data security
Dynamic Frequency Selection (DFS), optimizing the use of available RF spectrum to prevent radar channel interference
Cyclic Delay/Shift Diversity (CDD/CSD), Maximum Ratio Combining (MRC), Space-Time Block Coding (STBC), and Low-Density Parity Check (LDPC), improving the signal quality, signal receiving, and reliability and performance of data transmission
Transmit beam-forming (TxBF) expands the signal coverage and enhances the reliability of specific devices, thereby improving the data rate
Intelligent identification and monitoring, multicast-to-unicast conversion, and other features, enhancing network security and reliability
Thông số kỹ thuật
RG-SAP815-SP
Four spatial streams
● Radio 1 – 2.4 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 1 – 2.4 GHz: 20 MHz and 40 MHz
● Radio 2 – 5 GHz: 20 MHz and 40 MHz
● Radio 1 – 2.4 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15)
● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15)
Two spatial streams
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 867 Mbps
● Radio 2 – 5 GHz: 6.5 Mbps to 867 Mbps (MCS0 to MCS9)
● Radio 1 – 2.4 GHz: 2x2 MIMO , two spatial streams
Channels:
Combined peak data rate: 1.775 Gbps
● Radio 1 – 2.4 GHz: 8.6 Mbps to 0.574 Gbps (MCS0 to MCS11)
● Radio 2 – 5 GHz: 8.6 Mbps to 1.201 Gbps (MCS0 to MCS11)
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 2.8 dBi.
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 4.8 dBi.
● One onboard Bluetooth with built-in omnidirectional antenna, with peak antenna gain of 2.4 dBi.
1 x 10/100/1000BASE-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 220 mm x 220 mm x 49 mm (8.66 in. x 8.66 in. x 1.93 in.)
Shipping: 507 mm x 319 mm x 278 mm (19.96 in. x 12.56 in. x 10.74 in.)
Main unit: 0.6kg (1.33 lbs)
Mounting bracket: 0.07kg (0.15 lbs)
Shipping: 1.04 kg (2.29 lbs)
● 48 V DC/0.3 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power supply needs to be purchased independently.
● DC powered: 12.95 W
● Idle mode: 6 W
Storage humidity: 5%RH to 95%RH (non-condensing)
512 MB DRAM, 128 MB flash
● Maximum transmit power: 26 dBm (398.11 mW)
RG-SAP815-SP
Maximum. Receive Sensitivity per Receive Chain
–91dBm
–90 dBm
–87 dBm
22 dBm
22 dBm
–78 dBm
–72 dBm
19 dBm
–67 dBm
19 dBm
–64 dBm
15 dBm
–58 dBm
15 dBm
22 dBm
22 dBm
–78 dBm
–72 dBm
19 dBm
–67 dBm
19 dBm
–64 dBm
–57 dBm
–58 dBm
–52 dBm
Note Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
RG-SAP815-SP
RGOS11.9(6)W1B4 or later
Maximum. number of associated STAs
80
Maximum number of WLAN IDs
Rate set settings
MU device locating
PSK, PPSK, web, 802.1X, PEAP, WPA, WPA2 and WPA3 authentication
MAC address table size: 1,024
Jumbo frame length: 1,518
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
DHCP snooping, DHCP server, and DHCP client
NAT, FTP ALG and DNS ALG
NTP server and NTP client
RG-WS series wireless controller and WIS Cloud
RG-SAP815-SP
Big data capabilities
RG-SAP815-SP
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-SAP815-SP] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-SAP815-SP] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Tài nguyên
Thông tin đặt hàng
RG-SAP815-SP
Wi-Fi 6 802.11ax-compliant indoor wireless access point
Dual radios, four spatial streams, peak data rate of 1.775 Gbps
●     Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 574 Mbps
●     Radio 2: 5 GHz: two spatial streams, 2x2 MIMO, peak data rate of 1.201 Gbps
1 x 10/100/1000M BASE-T uplink port, supporting PoE and local DC power supply
Binding Ruijie Cloud service lifetime license
●     The power source equipment (PSE) needs to be purchased separately. The PoE Power Injector can be purchased from Ruijie.
●     The DC power module has to be purchased separately from a third party. The output voltage/current must be 48 V/0.3 A.
RG-E-120(GE)
Single PoE Power Injector with 1000BASE-T support, supporting 802.3af
Câu hỏi thường gặp
