Applicable in VSU networking scenarios, provides two uplink splitting ports, and works together with RG-MUX-8LC/LC-H.
8-port modular transparent distribution device used with splitters
RG-MUX-8LC/LC8-port modular transparent distribution device
RG-MUX-EXTSplitter (transparent distribution expansion module)
RG-MUX-16LC/LC-H-BIDI1:16 high-density CWDM,10GE/2.5GE/1GE to rooms
RG-MUX-16LC/LC-V-BIDI1:16 high-density CWDM,Virtual Switch Unit (VSU) support,10GE/2.5GE/1GE to rooms
| Product Specifications |
RG-MUX-8LC/LC |
RG-MUX-8LC/LC-H |
RG-MUX-EXT |
| Fixed service port |
8 x demultiplexing ports, supporting 1GE/2.5GE/10GE 1 x multiplexing port |
8 x demultiplexing ports, supporting 1GE/2.5GE/10GE 1 x multiplexing port, supporting connection to a dual-uplink splitter |
1 x multiplexing port 2 x uplink ports for optical splitting |
| Wavelength range |
1271 nm to 1571 nm (CWDM) |
| Channel spacing |
20 nm |
20 nm |
20 nm |
| Channel bandwidth |
±6 nm |
±6 nm |
±6 nm |
| Insertion loss |
< 3.7 dB |
< 2.6 dB |
< 4.2 dB |
| Return loss |
> 45 dB |
> 45 dB |
> 45 dB |
| Polarization loss |
< 0.3 dB |
< 0.3 dB |
< 0.3 dB |
| Adjacent channel isolation |
> 25 dB |
> 25 dB |
| Non-adjacent channel isolation |
> 35 dB |
> 35 dB |
| Connector type |
LC/UPC |
LC/UPC |
LC/UPC |
149.0 mm x 140.5 mm x 22.0 mm (5.87 in. x 5.53 in. x 0.87 in.) |
405 mm x 378 mm x 425 mm (15.94 in. x 14.88 in. x 16.73 in.) |
| Unit weight |
0.25 kg (0.55 lbs) |
0.15 kg (0.33 lbs) |
| Shipping weight |
4.53 kg (9.99 lbs) |
| Mounting |
Mounting on a wall or in a rack (cabinet) |
| Temperature |
Operating temperature: 0°C to 55°C (32°F to 131°F) Storage temperature: –40°C to +85°C (–40°F to +185°F) |
| Humidity |
Operating humidity: 5% to 95% RH (non-condensing) Storage humidity: 5% to 95% RH (non-condensing) |
| Altitude |
Same as the specification of the SOE switch |
| Communication standard |
GR-1221-Core and GR-1209-Core |
RG-MUX-BOX |
| Module slot |
6 x transparent distribution module/dual-uplink splitter slots |
442 mm x 50 mm x 58 mm (17.4 in. x 1.97 in. x 2.28 in.) |
557 mm x 358 mm x 271 mm (21.93 in. x 14.09 in. x 10.67 in.) |
| Unit weight |
0.9 kg (1.98 lbs) |
| Shipping weight |
11.5 kg (25.35 lbs) |
| Mounting |
| Temperature |
Operating temperature: –40°C to +85°C (–40°F to +185°F) Storage temperature: –40°C to +85°C (–40°F to +185°F) |
| Humidity |
| Altitude |
> RG-MUX-16LC/LC-H-BIDI and RG-MUX-16LC/LC-V-BIDI
> RG-MUX-16LC/LC-H-BIDI |
> RG-MUX-16LC/LC-V-BIDI |
| Product description |
> Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports supporting 1GE/2.5GE/10GE rates, and a single uplink COM port, supporting standalone scenarios. |
> Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports supporting 1GE/2.5GE/10GE rates, built-in dual-uplink splitter, and dual uplink COM ports, supporting VSU scenarios. |
| Wavelength range |
> 1271--1571 nm (CWDM) |
| Channel spacing |
> 20 nm |
> 20 nm |
| Channel bandwidth |
> ±6 nm |
> ±6 nm |
| Insertion loss |
> < 5.8 dB |
> < 9.8 dB |
| Return loss |
> > 45 dB |
> > 45 dB |
| Polarization loss |
> < 0.5 dB |
> < 0.5 dB |
> > 25 dB |
> > 25 dB |
> > 35 dB |
> > 35 dB |
| Connector type |
> LC/APC (uplink COM port) > LC/UPC (downlink port) |
| Temperature |
Operating temperature: 0°C to 55°C (32°F to 131°F) > Storage temperature: –40°C to +85°C (–40°F to +185°F) |
| Humidity |
Operating humidity: 5% to 95% RH (non-condensing) > Storage humidity: 5% to 95% RH (non-condensing) |
> 149.0 mm x 140.5 mm x 34.0 mm (5.87 in. x 5.53 in. x 1.34 in.) |
| Unit weight |
> < 0.5 kg (1.10 lbs, excluding the package) |
RG-MUX-BOX-H |
> Subrack of the building-side transparent distribution module, 1 RU, providing three slots for inserting 16-port or 8-port transparent distribution modules or dual-uplink splitters. |
| Temperature |
Operating temperature: –40°C to +85°C (–40°F to +185°F) > Storage temperature: –40°C to +85°C (–40°F to +185°F) |
| Humidity |
> 442 mm x 50.4 mm x 43.6 mm (17.40 in. x 1.98 in. x 1.72 in., without rack mounting brackets) |
| Unit weight |
> 0.6 kg (1.32 lbs, excluding the package) |
1:8 Transparent Distribution Products in SOE Solution 3.0
| Model |
Description |
| RG-MUX-8LC/LC |
Building-side 8-port transparent distribution module, 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port |
| RG-MUX-8LC/LC-H |
Building-side 8-port transparent distribution module (high-end version with low insertion loss), 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port, supporting connection to a dual-uplink splitter |
| RG-MUX-EXT |
Building-side transparent distribution module's expansion module, or optical dual-uplink splitter (delivered with short fiber jumpers), which connects to the transparent distribution module and provides 1-to-2 optical signal splitting to realize dual-uplink networking; 1 x multiplexing port, 2 x uplink ports for optical splitting |
| RG-MUX-BOX |
Building-side transparent distribution module subrack, 6 x transparent distribution module/dual-uplink splitter slots |
1:16 Transparent Distribution Products in SOE Solution 4.0
| Model |
Description |
Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports with LC/UPC connectors, and a single uplink COM port with an LC/APC connector, supporting standalone scenarios |
Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports with LC/UPC connectors, and dual uplink COM ports with LC/APC connectors, supporting VSU scenarios |
| RG-MUX-BOX-H |
Subrack of the building-side transparent distribution module, 1 RU, providing three slots, which can accommodate 16-port or 8-port transparent distribution modules or dual-uplink splitters |
Note: The CWDM transceiver is not installed on the transparent distribution module.
CWDM transceivers are installed on core switches in the core equipment room, and are connected to the multiplexing port of the transparent distribution module through fiber trunk cables.
The access-side CWDM transceiver is installed on the access switch in the building's ELV room, and is interconnected with the demultiplexing port of the transparent distribution module through a short fiber.
1:8 CWDM Transceivers in SOE Solution 3.0
| Model |
Description |
| SFG-LR-SM |
Core-side 1GE BASE-LR SFG transceiver, supporting 8 wavelengths, 10 km (6.21 miles), and LC connector |
| SFM-LR-SM |
Core-side SFM 2.5GE CWDM transceiver, supporting 8 wavelengths (for eight access devices), single-fiber, single-mode, 10 km (6.21 miles), and LC connector |
| SFX-LR-SM |
Core-side 10GE BASE-LR SFP+ transceiver, supporting 8 wavelengths, 10 km (6.21 miles), and LC connector |
| GE-SFP-LR(A1-8)-H |
Access-side 1GE BASE-LR SFG transceiver, supporting 8 wavelengths, 10 km (6.21 miles), LC connector, and used in dual uplink scenarios |
| MG-SFP-LR(A1-8)-H-E |
A group of access-side high-power quasi-industrial temperature 2.5GE CWDM transceivers, including 8 transceivers with different wavelengths, single-mode, 10 km (6.21 miles), and LC connectors |
| XG-SFP-LR(A1-8)-H |
Access-side 10GE BASE-LR SFP+ transceiver, supporting 8 wavelengths, 10 km (6.21 miles), LC connector, and used in dual uplink scenarios |
1:16 CWDM Transceivers in SOE Solution 4.0
| Model |
Description |
| SFGP-LR-SM |
Core-side high-density CWDM 16GE SFGP transceiver, supporting 16 distinct wavelengths (corresponding to 16 1GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector |
| SFXP-LR-SM |
Core-side high-density CWDM 160GE SFXP transceiver, supporting 16 distinct wavelengths (corresponding to 16 10GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector |
| GE-SFP-LR(A1-16)-H-BIDI |
A group of 16 high-power commercial-temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector |
| GE-SFP-LR(A1-16)-H-E-BIDI |
A group of 16 high-power quasi-industrial temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector |
| XG-SFP-LR(A1-16)-H-BIDI |
A group of 16 high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector, designed to be used with single-uplink transparent distribution modules |
| XG-SFP-LR(A1-16)-H-E-BIDI |
A group of 16 high-power quasi-industrial temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector |
| XG-SFP-LR(A1-16)-P-BIDI |
A group of 16 ultra-high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector, designed to be used with dual-uplink transparent distribution modules |
