RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 1
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 2
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 3
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 4
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 5
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 6
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 7
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 8
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 9
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 10
RG-MUX-8LC/LC-H Thiết bị chuyển mạch - 11
RG-MUX-8LC/LC-H Ethernet All-Optical Modular 8-Port Transparent Distribution Device Used with Splitters
Paired with splitters to realize dual uplinks on network links and suitable for scenarios with dual core switches
  • Combination of splitters and transparent distribution devices, achieving dual uplinks for all-optical links and improving the link reliability between the core network and building
RG-MUX-8LCI/LC-H 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded. The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
Thông số kỹ thuật
1:8 Transparent Distribution Products in SOE Solution 3.0
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
1 x multiplexing port
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
LC/UPC
LC/UPC
LC/UPC
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
6 x transparent distribution module/dual-uplink splitter slots
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
1:16 Transparent Distribution Products in SOE Solution 4.0
> RG-MUX-16LC/LC-H-BIDI and RG-MUX-16LC/LC-V-BIDI
Product description
> Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports supporting 1GE/2.5GE/10GE rates, and a single uplink COM port, supporting standalone scenarios.
> Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports supporting 1GE/2.5GE/10GE rates, built-in dual-uplink splitter, and dual uplink COM ports, supporting VSU scenarios.
Wavelength range
> 1271--1571 nm (CWDM)
Channel spacing
> 20 nm
> 20 nm
Channel bandwidth
> ±6 nm
> ±6 nm
Insertion loss
> < 5.8 dB
> < 9.8 dB
Return loss
> > 45 dB
> > 45 dB
Polarization loss
> < 0.5 dB
> < 0.5 dB
> > 25 dB
> > 25 dB
> > 35 dB
> > 35 dB
> LC/APC (uplink COM port)
> LC/UPC (downlink port)
> Storage humidity: 5% to 95% RH (non-condensing)
> 149.0 mm x 140.5 mm x 34.0 mm (5.87 in. x 5.53 in. x 1.34 in.)
> < 0.5 kg (1.10 lbs, excluding the package)
RG-MUX-BOX-H
Product description
> Subrack of the building-side transparent distribution module, 1 RU, providing three slots for inserting 16-port or 8-port transparent distribution modules or dual-uplink splitters.
> 442 mm x 50.4 mm x 43.6 mm (17.40 in. x 1.98 in. x 1.72 in., without rack mounting brackets)
> 0.6 kg (1.32 lbs, excluding the package)
Tài nguyên
Thông tin đặt hàng
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
RG-MUX-BOX
Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports with LC/UPC connectors, and a single uplink COM port with an LC/APC connector, supporting standalone scenarios
Building-side 16-port transparent distribution module, high-end version with low insertion loss, single-fiber BiDi downlink ports with LC/UPC connectors, and dual uplink COM ports with LC/APC connectors, supporting VSU scenarios
RG-MUX-BOX-H
Subrack of the building-side transparent distribution module, 1 RU, providing three slots, which can accommodate 16-port or 8-port transparent distribution modules or dual-uplink splitters
Note: The CWDM transceiver is not installed on the transparent distribution module.
  • CWDM transceivers are installed on core switches in the core equipment room, and are connected to the multiplexing port of the transparent distribution module through fiber trunk cables.
  • The access-side CWDM transceiver is installed on the access switch in the building's ELV room, and is interconnected with the demultiplexing port of the transparent distribution module through a short fiber.
1:8 CWDM Transceivers in SOE Solution 3.0
Core-side 1GE BASE-LR SFG transceiver, supporting 8 wavelengths, 10 km (6.21 miles), and LC connector
SFM-LR-SM
Core-side SFM 2.5GE CWDM transceiver, supporting 8 wavelengths (for eight access devices), single-fiber, single-mode, 10 km (6.21 miles), and LC connector
Core-side 10GE BASE-LR SFP+ transceiver, supporting 8 wavelengths, 10 km (6.21 miles), and LC connector
Access-side 1GE BASE-LR SFG transceiver, supporting 8 wavelengths, 10 km (6.21 miles), LC connector, and used in dual uplink scenarios
A group of access-side high-power quasi-industrial temperature 2.5GE CWDM transceivers, including 8 transceivers with different wavelengths, single-mode, 10 km (6.21 miles), and LC connectors
Access-side 10GE BASE-LR SFP+ transceiver, supporting 8 wavelengths, 10 km (6.21 miles), LC connector, and used in dual uplink scenarios
1:16 CWDM Transceivers in SOE Solution 4.0
SFGP-LR-SM
Core-side high-density CWDM 16GE SFGP transceiver, supporting 16 distinct wavelengths (corresponding to 16 1GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector
SFXP-LR-SM
Core-side high-density CWDM 160GE SFXP transceiver, supporting 16 distinct wavelengths (corresponding to 16 10GE access devices), SMF, 10 km (6.21 miles), and single-fiber LC/APC connector
GE-SFP-LR(A1-16)-H-BIDI
A group of 16 high-power commercial-temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector
GE-SFP-LR(A1-16)-H-E-BIDI
A group of 16 high-power quasi-industrial temperature 1GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector
XG-SFP-LR(A1-16)-H-BIDI
A group of 16 high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector, designed to be used with single-uplink transparent distribution modules
XG-SFP-LR(A1-16)-H-E-BIDI
A group of 16 high-power quasi-industrial temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector
XG-SFP-LR(A1-16)-P-BIDI
A group of 16 ultra-high-power commercial-temperature 10GE BiDi CWDM transceivers with different wavelengths for access-side deployment, SMF, 10 km (6.21 miles), and single-fiber LC/UPC connector, designed to be used with dual-uplink transparent distribution modules
Câu hỏi thường gặp
