Rich port types and numbers are provided, and various network functions are integrated such as routing, switching, security, and wireless. The access router is suitable for access scenarios of small and medium-sized branches of enterprises and customers in financial, government, and other industries. The next-generation HSIC expansion module is supported and rich expansion modules are provided to meet various combination requirements.
4G/5G supported
Software-Level Dual-Boot
The two power modules support redundant backups and hot swapping, ensuring continuous power supply.
Similarly, a line card can also be hot-swapped without affecting other services, ensuring nonstop services.
RG-RSR20-XA-24
RG-RSR20-XA-36
RG-RSR20-XA-54
Interface Specifications
Fixed WAN port
4 x 10GE optical ports
4 x 1GE optical ports
4 x 1GE electrical ports
2 x 10GE optical ports
Fixed LAN port (LAN/WAN port switching)
12 x 1GE electrical ports
24 x 1GE electrical ports
48 x 1GE electrical ports
Power modules
2 (1+1 redundancy)
2 (1+1 redundancy)
2 (1+1 redundancy)
Fixed management ports
1 x console port and 1 x USB 2.0 port
Expansion slot
10 Gbps
100,000
2,048
Ingress: 4,000
Egress: 4,000
440 mm x 420 mm x 44 mm (17.32 inch. x 16.56 in. x 1.73 in.), 1 RU
Weight (Full configuration)
< 7.8 kg (17.20 lbs) (excluding packaging)
Power and Consumption
< 150 W
RG-PA150IB-F: 150 W @ 10 A power cord
Rated input voltage
RG-PA150IB-F: 100 V AC to 240 V AC, 50 Hz to 60 Hz
Maximum input voltage
RG-PA150IB-F: 90 V AC to 264 V AC, 47Hz~63Hz
> 100,000 hours
0°C to 50°C (32°F to 122°F)
5% to 95% RH (non-condensing)
Interface surge protection
6 kV
Operating altitude
0–3000 m (0–9,842.52 ft.)
RG-RSR20-XA Series
Jumbo frame length: 9216 bytes
Number of created VLANs: 4,088
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
Static multicast routing
MPLS forwarding
Expert-level ACLs (ACLs based on source and destination IP addresses and ports, and specified protocol)
IPv6 ACLs
L2TP, IPsec, and GRE
uRPF
GR for OSPF/IS-IS/BGP
SDN technology
SPAN and ERSPAN
NTP server and NTP client
RG-RSR20-XA-24 chassis, 12 x fixed WAN ports (4 x 10GE optical ports, 4 x 1GE optical ports, and 4 x 1GE electrical ports) and 12 x 1GE electrical LAN ports (LAN/WAN port switching), 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
RG-RSR20-XA-36
RG-RSR20-XA-36 chassis, 12 x fixed WAN ports (4 x 10GE optical ports, 4 x 1GE optical ports, and 4 x 1GE electrical ports) and 24 x 1GE electrical LAN ports (LAN/WAN port switching), 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
RG-RSR20-XA-54
RG-RSR20-XA-54 chassis, 6 x fixed WAN ports (2 x 10GE optical ports and 4 x 1GE electrical ports) and 48 x 1GE electrical LAN ports (LAN/WAN port switching), 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
Power Modules
Line Card
HSIC-2E1/CE1
2-port E1/CE1 module (the cable needs to be purchased separately)
HSIC-4G-LTE
1-port full-mode 4G and encryption module (the antenna needs to be purchased separately)
*HSIC-5G-NR
1-port full-mode 5G and encryption module (the antenna needs to be purchased separately)
*HSIC-1POS-STM1
1-port OC-3c/STM-1c POS interface card (the optical module needs to be purchased separately)
Tips: Product information and performance will be affected by upgrade iteration, specific environment and other factors, so FAQ content is for reference only. For further information, please contact
online support.
your cookie settings.
When you visit any website, the website will store or retrieve the information on your
browser. This process is mostly in the form of cookies. Such information may involve your
personal information, preferences or equipment, and is mainly used to enable the website to
provide services in accordance with your expectations. Such information usually does not
directly identify your personal information, but it can provide you with a more personalized
network experience. We fully respect your privacy, so you can choose not to allow certain
types of cookies. You only need to click on the names of different cookie categories to
learn more and change the default settings. However, blocking certain types of cookies may
affect your website experience and the services we can provide you.
Performance cookies
Through this type of cookie, we can count website visits and traffic sources in
order to evaluate and improve the performance of our website. This type of
cookie can also help us understand the popularity of the page and the activity
of visitors on the site. All information collected by such cookies will be
aggregated to ensure the anonymity of the information. If you do not allow such
cookies, we will have no way of knowing when you visited our website, and we
will not be able to monitor website performance.
Essential cookies
This type of cookie is necessary for the normal operation of the website and
cannot be turned off in our system. Usually, they are only set for the actions
you do, which are equivalent to service requests, such as setting your privacy
preferences, logging in, or filling out forms. You can set your browser to block
or remind you of such cookies, but certain functions of the website will not be
available. Such cookies do not store any personally identifiable information.
