RG-RSR20-XA-24 24-Port Multi-service Fixed Access Router
Rich port types and quantity, and various network functions including routing, switching, security, and wireless.
Suitable for access scenarios of small and medium-sized enterprise branches in financial, government, and other industries.
4G/5G supported
Software-Level Dual-Boot
RG-RSR20-XA-24
RG-RSR20-XA-36
RG-RSR20-XA-54
Interface Specifications
Fixed WAN port
4 x 10GE optical ports
4 x 1GE optical ports
4 x 1GE electrical ports
2 x 10GE optical ports
Fixed LAN port (LAN/WAN port switching)
12 x 1GE electrical ports
24 x 1GE electrical ports
48 x 1GE electrical ports
Power modules
2 (1+1 redundancy)
2 (1+1 redundancy)
2 (1+1 redundancy)
Fixed management ports
1 x console port and 1 x USB 2.0 port
Expansion slot
10 Gbps
100,000
2,048
Ingress: 4,000
Egress: 4,000
440 mm x 420 mm x 44 mm (17.32 inch. x 16.56 in. x 1.73 in.), 1 RU
Weight (Full configuration)
< 7.8 kg (17.20 lbs) (excluding packaging)
Power and Consumption
< 150 W
RG-PA150IB-F: 150 W @ 10 A power cord
Rated input voltage
RG-PA150IB-F: 100 V AC to 240 V AC, 50 Hz to 60 Hz
Maximum input voltage
RG-PA150IB-F: 90 V AC to 264 V AC, 47Hz~63Hz
> 100,000 hours
0°C to 50°C (32°F to 122°F)
5% to 95% RH (non-condensing)
Interface surge protection
6 kV
Operating altitude
0–3000 m (0–9,842.52 ft.)
RG-RSR20-XA Series
Jumbo frame length: 1578 bytes
Number of created VLANs: 4,088
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
Static multicast routing
MPLS forwarding
Expert-level ACLs (ACLs based on source and destination IP addresses and ports, and specified protocol)
IPv6 ACLs
L2TP, IPsec, and GRE
uRPF
GR for OSPF/IS-IS/BGP
SDN technology
SPAN and ERSPAN
NTP server and NTP client
RG-RSR20-XA-24
RG-RSR20-XA-24 chassis, 12 x fixed WAN ports (4 x 10GE optical ports, 4 x 1GE optical ports, and 4 x 1GE electrical ports) and 12 x 1GE electrical LAN ports (LAN/WAN port switching), 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
RG-RSR20-XA-36
RG-RSR20-XA-36 chassis, 12 x fixed WAN ports (4 x 10GE optical ports, 4 x 1GE optical ports, and 4 x 1GE electrical ports) and 24 x 1GE electrical LAN ports (LAN/WAN port switching), 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
RG-RSR20-XA-54
RG-RSR20-XA-54 chassis, 6 x fixed WAN ports (2 x 10GE optical ports and 4 x 1GE electrical ports) and 48 x 1GE electrical LAN ports (LAN/WAN port switching), 4 x Expansion slots, 1 x USB 2.0 port, 1 x console port
Power Modules
Line Card
HSIC-2E1/CE1
2-port E1/CE1 module (the cable needs to be purchased separately)
HSIC-4G-LTE-G
1-port full-mode 4G and encryption module (the antenna needs to be purchased separately)
*HSIC-5G-NR
1-port full-mode 5G and encryption module (the antenna needs to be purchased separately)
*HSIC-1POS-STM1
1-port OC-3c/STM-1c POS interface card (the optical module needs to be purchased separately)
