RG-S6980-128DC Kết nối mạng trung tâm dữ liệu - 1
RG-S6980-128DC Kết nối mạng trung tâm dữ liệu - 2
RG-S6980-128DC Kết nối mạng trung tâm dữ liệu - 3
RG-S6980-128DC Kết nối mạng trung tâm dữ liệu - 4
RG-S6980-128DC Kết nối mạng trung tâm dữ liệu - 5
RG-S6980-128DC Kết nối mạng trung tâm dữ liệu - 6
RG-S6980-128DC – 128-Port 200GE Data Center Fixed Core Switch
High-density 200GE fixed switch, support for 200GE optical transceivers
  • High-density 200GE switch with 128 x 200GE QSFP56 ports housed in a 4-RU enclosure
  • Hardware-level redundancy, ensuring service continuity and preventing network downtime
  • Telemetry-based network monitoring and automated O&M, making management easy and efficient
RG-S6980-128DC – 128-Port 200GE Data Center Core Switch
The high-speed and high-density core switch provides 128 x 200GE QSFP56 ports housed in a 4-RU enclosure,
delivering scalable, high-performance, and high-bandwidth services for large-scale DCI networks.
Hardware-Level Redundancy, Ensuring Service Continuity and Preventing Network Downtime
The switch supports 2+2 power redundancy, enables failover in seconds, and ensures network connectivity during power replacement. This provides dual protection for links.
Lossless Ethernet, Ensuring Zero Packet Loss During RDMA E2E Communication
With the RDMA technology, data does not need to be handled by the CPU during device communication. This reduces the CPU load
and addresses network latency issues.
PFC and ECN are leveraged to implement intelligent data exchange and eliminate packet loss, ensuring lossless transmission of data.
Telemetry-based Network Monitoring and Automated O&M, Making Management Easy and Efficient
The switch enabled with telemetry provides a comprehensive view of data status and hierarchy.
The switch proactively collects and pushes information to provide sub-second-level network monitoring in real time,
Thông số kỹ thuật
RG-S6980-128DC
Height
4 RU
39.65 kg (87.41 lbs.) (A chassis installed with four power modules and eight fan modules)
Switching Capacity
51.2 Tbps
Packet Forwarding Rate
10300 Mpps
Service Port
128 x 100GE/200GE QSFP56 ports
Management Port
USB Port
Slot
4 x power module slots
8 x fan module slots
Power Consumption
Maximum power consumption: 2550 W
Typical power consumption: 1800 W
Static power consumption: 250 W
PSA1300CRPS-F-RJ (AC input)
Rated input current: 12 A (100 V AC to 127 V AC)
8 A (200 V AC to 240 V AC)
Power connector: C14
PSA1300CRPS-F-RJ (HVDC input):
Rated input voltage: 240 V DC (For Chinese mainland only)
Rated input current: 6.5 A
Operating altitude: ≤ 5000 m (16,404.20 ft.)
RG-S6980-128DC
Layer 2 protocols
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
IPv4 features
BGP4, OSPFv2, RIPv1, RIPv2, LPM Routing, Policy-based Routing, Route-policy, ECMP, WCMP, VRRP
IPv6 features
Neighbor Discovery (ND), ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, IPv6 TCP/UDP, SNMPv6, IPv6 Ping/Traceroute, IPv6 RADIUS, IPv6 Telnet/SSH, IPv6 FTP/TFTP, NTPv6, IPv6 MIB for SNMP, IPv6 VRRP, IPv6 QoS, static routing, ECMP, PBR, OSPFv3, RIPng, and BGP4+
Data center features
PFC and ECN
RDMA
VXLAN, BGP-EVPN
PFC deadlock prevention
RALB, AILB
Visualization
Telemetry for collecting basic switch information, real-time status of RoCE-related buffer, interface QoS queue and interface utilization status, key events such as ECN and PFC
IEEE 802.1p, DSCP, and ToS mapping
Priority marking and re-marking
Multiple queue scheduling mechanisms, including SP, WRR, WFQ, DRR, SP+WRR, SP+WFQ, SP+DRR
High availability
GR for RIP/OSPF/BGP, BFD, Device Link Detection Protocol (DLDP), Rapid Ethernet Uplink Protection Protocol (REUP), Rapid Link Detection Protocol (RLDP), 2+2 power redundancy, fan redundancy, and hot swapping of line cards and power modules
Security features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), RADIUS/TACACS, IPv4/IPv6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, broadcast packet suppression, and hierarchical user management
Management mode
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm
Other protocols
DHCP Client, DHCP Relay, DHCP Server, DNS Client, ARP Proxy, and Syslog
Tài nguyên
Thông tin đặt hàng
RG-S6980-128DC
Providing fixed 128 x 200G ports, four power module slots, and eight fan module slots
PSA1300CRPS-F-RJ
Power module, hot swappable 2+2 redundancy, front-to-rear airflow
FAN12K8080-F-RJ
Fan module, hot swappable 7+1 redundancy, front-to-rear airflow
100GE Optical Transceivers
100G-AOC-1M
100G active optical cable (AOC), QSFP28 form factor, 1 m (3.28 ft.)
100G AOC cable, QSFP28 form factor, 10 m (32.81 ft.)
200GE Optical Transceivers
200G-Q56-SR4-MM850(D)
200GE SR4 optical transceiver, QSFP56 form factor, MPO12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MPO MMF, CMIS-compliance, applicable to the switch side
200G-Q56-SR4-MM850
200GE SR4 optical transceiver, QSFP56 form factor, MPO12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MPO MMF, SFF-8636-compliance, applicable to the server side
