12 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-24GT4XS-P24 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-24GT4XS24 x GE Electrical Ports, 4 x 10GE SFP+ Ports
RG-CS83-48GT4XS-P48 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-48GT4XS48 x GE Electrical Ports, 4 x 10GE SFP+ Ports
| Hardware Specifications |
RG-CS83-12GT4XS-P |
RG-CS83-24GT4XS |
RG-CS83-48GT4XS |
RG-CS83-24GT4XS-P |
RG-CS83-48GT4XS-P |
| Interface Specifications |
| Fixed ports |
12 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports support PoE+ |
24 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports |
48 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports |
24 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports support PoE+ |
48 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports support PoE+ |
| Fan module |
1 x fixed fan module |
No fan |
| Power module |
1 x fixed power module |
| Fixed management port |
1 x console, and 1 x USB 2.0 port |
| System Specifications |
| Packet forwarding rate |
78 Mpps |
96 Mpps |
132 Mpps |
96 Mpps |
132 Mpps |
| Switching capacity |
104 Gbps |
128 Gbps |
176 Gbps |
128 Gbps |
176 Gbps |
| MAC address table size |
16,000 |
| ARP table size |
4,000 |
4,000 |
4,000 |
4,000 |
4,000 |
| Number of IPv4 unicast routes |
6,000 |
| Number of IPv4 multicast routes |
1,000 |
| Number of IPv6 unicast routes |
2,000 |
| Number of IPv6 multicast routes |
750 |
| Number of ACEs |
Ingress: 1,750 Egress: 800 |
| Number of VSU members |
4 |
4 |
4 |
4 |
4 |
| Dimensions and Weight |
| Dimensions (W x D x H) |
| Weight |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
3.75 kg (8.27 lbs) |
| CPU and Storage |
| CPU |
1.0 GHz dual-core CPU |
| Flash memory |
512 MB |
512 MB |
512 MB |
512 MB |
512 MB |
| BootROM |
16 MB |
16 MB |
16 MB |
16 MB |
16 MB |
| SDRAM |
1 GB |
1 GB |
1 GB |
1 GB |
1 GB |
| Data packet buffer |
4 MB |
4 MB |
4 MB |
4 MB |
4 MB |
| Power and Consumption |
| Maximum power consumption |
< 35 W (non-PoE) < 405 W (PoE full load) |
< 25 W |
< 40 W |
< 52 W (non-PoE) < 460 W (PoE full load) |
| Maximum output power |
409 W Maximum PoE output :370W |
25 W |
40 W |
460 W Maximum PoE output :405W |
| Rated input voltage |
100 V AC to 240 V AC |
| Maximum input voltage |
90 V AC to 264 V AC, 50 Hz to 60 Hz |
| MTBF |
24.14 years |
23.74 years |
23.85 years |
23.94 years |
22.86 years |
| Primary airflow |
| Operating temperature |
0°C to 45°C (32°F to 113°F) |
| Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
| Operating humidity |
10% to 90% RH (non-condensing) |
| Storage humidity |
5% to 95% RH (non-condensing) |
| Operating noise |
27℃: < 35 dB |
< 20 dB |
27℃: < 32 dB |
27℃: < 35 dB |
27℃: < 35 dB |
| Interface surge protection |
Power port: 6 kV(common mode)/8 kV (differential mode) Communication port: 10 kV |
Power port: 6 kV(common mode)/6 kV (differential mode) Communication port: 10 kV |
| Coating Conformal |
Conformal coating supported (key components only) |
| RG-CS83 Series |
| Feature |
Description |
| Ethernet switching |
| 802.3az EEE |
| IEEE 802.1Q (4K VLANs) |
| Voice VLAN |
| GVRP |
| Basic QinQ Selective QinQ |
| STP, RSTP, and MSTP |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| IP service |
ARP |
| DHCP snooping |
| DNS |
| DHCPv6 snooping |
| IP routing |
Static routing |
| RIP and RIPng |
| OSPFv2 and OSPFv3 |
| IPv4 and IPv6 VRF |
| IPv4 and IPv6 PBR |
| Multicast |
| IGMP v1/v2 snooping |
| MSDP |
| MLD v1/v2 |
| MLD snooping v1/v2 |
| PIM-SMv6 and PIM-SSM v6 |
| ACL and QoS |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs Time-based ACLs Expert-level ACLs ACL80 IPv6 ACL |
| ACL redirection |
| Security |
Multiple AAA modes |
| RADIUS and TACAS+ |
| Interface-based and MAC address-based 802.1x authentication |
| Web authentication |
| HTTPS |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| IP source guard |
| SAVI |
| CPP and NFPP |
| Reliability |
REUP, RLDP, DLDP |
| BFD |
| Hot swapping of power modules and cables |
| Device virtualization |
| NMS and maintenance |
SPAN, RSPAN |
| sFlow |
| NTP and SNTP |
| FTP and TFTP |
| SNMP v1/v2/v3 |
| RMON (1, 2, 3, 9) |
| NETCONF |
| CWMP (TR-069) |
| gRPC |
| Cloud and SON |
| PoE |
RG-CS83-12GT4XS-P, RG-CS83-24GT4XS-P, and RG-CS83-48GT4XS-P: IEEE 802.3af and 802.3at Warm start Interface priority |
| Model |
Description |
| RG-CS83-12GT4XS-P |
12 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 370 W PoE output, and built-in power module |
| RG-CS83-24GT4XS |
24 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, and built-in power module |
| RG-CS83-48GT4XS |
48 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, and built-in power module |
| RG-CS83-24GT4XS-P |
24 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 370 W PoE output, and built-in power module |
| RG-CS83-48GT4XS-P |
48 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 405 W PoE output, and built-in power module |
| Mini-GBIC-GT |
1000BASE-GT mini GBIC module |
| MINI-GBIC-SX-MM850 |
Single-port 1000BASE-SX mini GBIC module (LC connector) |
| MINI-GBIC-LX-SM1310 |
Single-port 1000BASE-LX mini GBIC module (LC connector) |
| MINI-GBIC-LH40-SM1310 |
Single-port 1000BASE-LH mini GBIC module (LC connector), supporting a transmission distance of 40 km (24.85 miles) |
| MINI-GBIC-ZX50-SM1550 |
Single-port 1000BASE-ZX mini GBIC module (LC connector), supporting a transmission distance of 50 km (24.85 miles) |
| MINI-GBIC-ZX80-SM1550 |
Single-port 1000BASE-ZX mini GBIC module (LC connector), supporting a transmission distance of 80 km (24.85 miles) |
| MINI-GBIC-ZX100-SM1550 |
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km (62.14 miles) |
| XG-SFP-SR-MM850 |
10GE LC module (62.5/125 μm: 33 m (108.27 ft.); 50/125 μm: 66 m (216.54 ft.); transmit for 300 m (984.25 ft.) when modal bandwidth is 2000 MHz * km), applicable to SFP+ ports |
| XG-SFP-LR-SM1310 |
10GE LC interface module (1310 nm), 10 km (6.21 miles), applicable to SFP+ ports |
| XG-SFP-ER-SM1550 |
10GE LC interface module (1550 nm), 40 km (24.85 miles), applicable to SFP+ ports |
| XG-SFP-AOC1M |
10GE SFP+ fiber-optic cable, 1 m (3.28 ft.), including one cable and two interface modules |
| XG-SFP-AOC3M |
10GE SFP+ fiber-optic cable, 3 m (3.28 ft.), including one cable and two interface modules |
| XG-SFP-AOC5M |
10GE SFP+ fiber-optic cable, 5 m (3.28 ft.), including one cable and two interface modules |
