RG-S2915-10GT2MS-P-L 10-Port Gigabit Layer 2+ Managed PoE+ Switch with Two 2.5GE Uplink SFP Ports
Thông số chi tiết chính View More
Killer Layer 2+ Access Switch
Applications
and Wider Coverage
10 kV Surge Protection
and Uninterrupted Connection
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-24GT4MS-P-L
Interface Specifications
Fixed Service Ports
48 × 10/100/1000Base-T Ethernet ports with auto-negotiation, 4 × 2.5GE/1GE SFP ports
24 × 10/100/1000Base-T Ethernet ports with auto-negotiation, 4 × 2.5GE/1GE SFP ports
24 ×
4 × 2.5G/1GE SFP ports
10 × 10/100/1000Base-T Ethernet ports with auto-negotiation,
2 × 2.5GE/1GE SFP ports
Power modules
1 fixed power module
Fans modules
2 fixed fans
0
2 fixed fans
1 fixed fans
Fixed management ports
1 × RJ45 Console, 1 × USB port
87 Mpps
51 Mpps
51 Mpps
22.5 Mpps
116Gbps
68Gbps
68Gbps
30Gbps
MAC Table Capacity
ARP table
512
ACL entries
500
440 mm × 220 mm × 43.5 mm (17.32 in × 8.66 in × 1.71 in), 1 RU
440 mm × 292 mm × 43.6 mm (17.32 in × 11.50 in × 1.72 in), 1 RU
297 mm × 170 mm × 44.5 mm (11.69 in × 6.69 in × 1.75 in), 1 RU
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.5 kg (5.51 lbs)
CPU and Storage
Built-in CPU, single-core processor, with the clock speed of 1.2 GHz
Flash Memory
64 MB
SDRAM
512 MB
Data packet buffer
 512 KB
Power and Consumption
< 30 W
< 15.6 W
< 33 W (non-PoE)
< 403 W (PoE full load)
< 16 W (non-PoE)
< 141 W (PoE full load)
Rated input voltage
Maximum input voltage
90 V AC to 264 V AC, 50 Hz to 60 Hz
>200K
>200K
>200K
>200K
Operating Temperature
0°C to 45°C (32°F to 113°F)
Storage Temperature
-40°C to +70°C (-40°F to +158°F)
Operating Humidity
Storage Humidity
5% to 95% RH (non-condensing)
Operating noise
≤ 37 dB
≤ 39 dB
≤ 37 dB
Interface surge protection
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
RIP, RIPng
OSPFv2
ACL 80
SSHv1, SSHv2
IGMP V1,V2 snooping
IP Source Guard
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
RSPAN
NTP
TFTP client
RG-S2915-48GT4MS-L
48 × 10/100/1000Base-T copper ports with auto-negotiation, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply
RG-S2915-24GT4MS-L
24 × 10/100/1000Base-T copper ports with auto-negotiation, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply
24 × 10/100/1000Base-T copper ports with auto-negotiation, 4 × 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, 370 W PoE power supply
10 × 10/100/1000Base-T copper ports with auto-negotiation, 2 × 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, 125 W PoE power supply
SFP 2.5G BIDI transceiver-TX1310/RX1550, 3 km, LC
SFP 2.5G BIDI transceiver-TX1550/RX1310, 3 km, LC
1000BASE-SX, SFP transceiver, SM (850 nm, 500 m, LC).
1000BASE-LX, SFP transceiver, SM (1310 nm, 10 km, LC)
1000BASE-LH, SFP transceiver, SM (1310 nm, 40 km, LC)
1000BASE-ZX80, SFP transceiver, SM (1550 nm, 80 km, LC)
SFP BIDI Transceiver-TX1310/RX1550, 20 km, LC
SFP BIDI Transceiver-TX1550/RX1310, 20 km, LC
SFP BIDI Transceiver-TX1310/RX1550, 40 km, LC
SFP BIDI Transceiver-TX1550/RX1310, 40 km, LC
1000BASE-TX, SFP transceiver (100 m)
